Question about Megatronix - PASSLOCK-SL2 - GM Passlock Data Bypass Kit - Self Learning Byp
My steering wheel is locked and the key is stuck in the ignition .The car won't start
Car won't start, key stuck in ignition. im recieving power to the vechile but it wont't start
  • 139 Answers
Check to make sure the gear select lever is in the park position. Try starting the vehicle with the gear select in neutral.
Posted on Jan 17, 2013
Key won't turn in ignition
The list of possible causes includes the key, the lock cylinder, the steering wheel lock, and other things.
Have you tried another key ?
May 03, 2013 | 2003 Honda Odyssey
1997 taurus key won't turn in the ignition, gear selector won't go into gears
Usually a sign the tumblers in the lock cylinder have worn out or jammed.
You may have to get the lock cylinder drilled out and replaced.
Jan 13, 2013 | 1997 Ford Taurus
Steering wheel won't lock, key won't come out
If the ignition normally only locks with the vehicle in park position, then check the switch on the gear lever mechanism is working.
If not, then you'll have to jiggle and wiggle that key out or replace the ignition lock.
Nov 10, 2012 | Volkswagen Cars & Trucks
Ignition stuck key won't turn to start car!
Gear shift is not totally in the park position - had the same problem with a 2011 Acura TL - a rubber band kept the gear shift lever from totally seating in the park position.
Oct 02, 2012 | 2003 Ford Focus
Stuck eldorado key in DTS ignition now car won't start
Make sure your steering wheel isn't locked. Sometimes a key won't turn until you jiggle the wheel while trying to turn the key.
Aug 21, 2012 | 2004 Cadillac DeVille DTS
Ignition is in lock position and won't turn on. saab 2000/ 900 3
make sure the stick is in reverse and the key is all the way in the ignition
May 01, 2012 | Saab 9 3 Cars & Trucks
Key stuck in ignition and car won't start
I assume you have tried jiggling the steering wheel to free up the interlock. If all else fails you will have to remove the key cylinder and replace it.
Dec 10, 2011 | Cars & Trucks
I put my key into the keyhole near the steering wheel so I could start the car, but for some reason my key won't turn, like it's stuck, what can I do to fix that?
Try moving your steering wheel to the left then jiggle the key until it releases, if no luck try the same thing moving the steering wheel to the right, or combination of both ways, If this works then there is nothing to worry about, it can happen almost to any vehicle, you are just in between the wheel locking mechanism and the ignition start or the removal of the key, a common problem in the design of the wheel lock, to prevent it from happening again, just have your steering wheel were you want it before starting or turning off you car. Rick
Aug 21, 2011 | 2009 Acura TL
My steering wheel is stuck and when I put my key in it won't turn either. It starts to turn but won't go all the way
hi,it maybe a good idea to remove the steering collum covers to visually inspect it can be the ignition bolt just being loose or the steering lock or ignition it self is on its way out.
May 19, 2011 | Volkswagen Jetta Cars & Trucks
Key stuck in ignition but it will turn, and steering column won't lock and car won't start.
you most likely have a bad key switch cylinder assembly. you can try to spray wd40 solvent into the switch before you have the switch replaced,but sometimes it's a switch replacement that repairs the problem. have you inspected your ignition key to look for damage to the key itself? try a spare key to make sure it's the key,and not the key switch. you can also try turning the key while turning the steering wheel at the same time to get the key to work.sometimes the switch locks when parked in a bind,such as on a hill,or against a curb and so on. try this 1st before you have the ignition switch replaced. AAA auto club,if you're a member covers part of the replacement costs for a replacement switch also. you may have coverage through a cell phone also.one more thing to try, if you have a tilt steering column,try to reposition the steering wheel to see if you can get the key to turn. remember never force it enough to break your key off into the switch! thank you for choosing fixya.com!
May 13, 2011 | 2002 Chevrolet TrailBlazer
Megatronix - PASSLOCK-SL2 - GM Passlock Data Bypass Kit - Self Learning Byp Logo
101 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
