Question about Shuttle XPC SD32G2 Barebone
Message from asus live update: please install asus winflash first if you want to update bios. my nb asus f3jp
    Scholar:
  • 50 Answers
Asus liveupdate, from everything Ive read, is very unreliable... Dont try to rely on it, try to go to the asus website if you need a bios update and take care of it there. theyll have read me's on how to do it-- it's not that hard, but you should have a good reason to update the bios as if you do it wrong, you could be in more trouble than you need.
Posted on Feb 02, 2009
Hang update bios
You have to remove the bios chip from the mainboard and flash it with the right bios version out side the laptop.
Feb 08, 2014 | Computers & Internet
Bat bios checksum problems solve
Step 1:
Update ASUS BIOS b> Insert bootable floppy disk or USB drive. Copy the updated BIOS file to floppy disk or USB drive.
(Note: BIOS file and boot files should fit on a floppy disk. If the BIOS file is too large to fit with boot files, consider using the EZ Flash method described below.) Insert the motherboard support CD into optical drive. Copy AFUDOS.EXE from CD to a floppy disk or USB drive. Reboot. When the DOS prompt appears, type the following: afudos /i[name of BIOS file]For example, "p4c800b.rom" might be the name of the new BIOS file. "afudos
/ip4c800b.rom" is the command that will install it. Wait. Your monitor will display the update's progress with a series of messages: "Reading file," then "Erasing flash," then "Writing flash." The "writing flash" message will be followed with a percentage counter that tells you how far the write has proceeded. The final message will be
"Verifying flash." DO NOT switch off or reboot at any point in this process or you will ruin your motherboard. After the update is complete, the utility will return to the DOS prompt. Remove your floppy disk and reboot. Enter the BIOS Menu and load "Setup Default." Save and reboot. You're finished. b> Update Using EZ Flash Copy your new BIOS files to a floppy disk or USB drive. Reboot. When the system is at POST, press "Alt" + "F2" to enter EZ-Flash. Alternatively, on late model motherboards you may press "Delete" to enter BIOS setup, then access EZ-Flash from the "Tools" option on the navigation bar. (Select Tools > ASUS EZ Flash 2 > YES) Wait for your system to check current BIOS information. Insert your floppy or USB with the new BIOS file. Select the drive letter with the BIOS update file, then select the file. Wait for your system to check the update file. After the file check is finished, click "Yes" to update your BIOS. Wait. Let the update procedure run until it finishes. Do not switch off or reboot or you will ruin your motherboard. When the update is finished, remove the floppy or USB drive and reboot. Enter the BIOS Menu and load "Setup Default." Reboot. You're finished. b> Update Through the Internet If it isn't installed already, install the ASUS Update utility. You can either download it or use the copy on your motherboard's support CD. Close all Windows applications if any are running. Launch the ASUS Update utility from the Windows desktop by clicking "Start>Programs>ASUS>ASUSUpdate>ASUSUpdate." The "ASUS Update" main window will then appear. Select "Update BIOS" from the "Internet option" drop-down menu. Click "Next." Select the ASUS FTP site nearest you, or choose "Auto Select." Click "Next." From the FTP site, select the BIOS version that you wish to download. Click "Next." Start the update. Wait for it to complete.
http://support.asus.com/technicaldocuments/technicaldocuments.aspx?root=198&SLanguage=en-us
Feb 05, 2013 | ASUS Eee PC 900 Notebook
How to make boot able disk of SP42854 bios update. Can't get bios to take flash.
I would liek to inform you that, no need to make any bootable disk to flash the BIOS. Most of the DV9000 series notebook BIOS update is Winflash means it can be install just by double clicking the softpq.
and follow the onscreen instactions.
May 19, 2010 | HP Pavilion dv9000z Notebook
Asus bios problem
Unless there is a compelling reason to update the bios it should be left alone. Apparently this is one reason for that sage advice.
Go back to asus, download an older version of the bios and install it. Fortunately you didn't end up unable to boot or you would be buying a new board.
Apr 29, 2009 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
Asus P5VDC-TVM Bios update
Please do not update BIOS unnecessarily. Only when you face problems and the error message request for BIOS update only then do so. On asus site enter all the required details & try, but my advice is to leave it alone if its in working condition....sodeep
Mar 20, 2009 | ASUS Computers & Internet
Asus live update,cannot update..wont let me.
You are welcome... you can rate my solution if you like... thanks
Mar 17, 2009 | Shuttle XPC SD32G2 Barebone
Asus f3jp
there are no manuals for the disassembling of this machine, i am a pc tech and find it a ball ache to strip the machines down, have a look around the lid hinges to remove the top panel
Nov 13, 2008 | ASUS F3Jp Notebook
Problem regarding installing network controller
Driver for LAN :
http://dlcdnet.asus.com/pub/ASUS/nb/Drivers/LAN/LAN_XP_080624.zip
Driver for Wireless LAN :
Option1 : http://dlcdnet.asus.com/pub/ASUS/nb/Drivers/WLAN/WLAN_NE-770_XP_081015.zip
Option2 :
  1. http://dlcdnet.asus.com/pub/ASUS/nb/Apps/Wireless_Console/Wireless_Console_XP_080624.zip
  2. http://dlcdnet.asus.com/pub/ASUS/nb/F7E/WLAN_Azurewave_GE-780_XP.zip
Oct 20, 2008 | ASUS M2N-MX Motherboard
M2n4-sli & athlon 6400 x2 64bit processor
yes.. supposed to be bios 1202 but don't know if you can get it any more may have to use1204
download from asus.com/download/download.aspx?
you can find the manual for your computer there also. use the global link.
you can download how to flash bios there under How to Upgrade Bios. you will want the Asus Winflash Procerdure for M2
it is easy and free
Sep 17, 2008 | Microsoft Windows XP Professional x64...
Shuttle XPC SD32G2 Barebone Logo
272 people viewed this question
Top Shuttle Computers & Internet Experts
Iqbal Husain
Iqbal Husain
David
David
Alun Cox
Are you a Shuttle Computer and Internet Expert? Answer questions, earn points and help others
