Question about Motorola Mobility RAZR V3
Motorola razor 3 black
Hi, The keys of my motorola razor v3 (black) has stopped working, except for the on/off button. Seems this is a common issue with this model. Any help will be highly appreciated. Thanks
  • 944 Answers
Check this link; http://www.mobileplanet.com/ft.aspx?k=48401 There are a few possible solutions discussed; Dry it out (in a warm cupboard or similar, not in the sun or on a heater). Replace the keyboard membrane. check the keyboard connectors to the rest of the phone - the power button has a seperate connector, so could well be the case. If there is still a warranty on the phone, then take it back as opening it up will void the warranty. Hope this helps - please ask again if you need more help :)
Posted on Jul 09, 2007
SOURCE:
Hi my Motorola Razor has a display problem i dropped it this morning and it still works the keys light up but the screen has its back light still working not white light but a dim light but there is no...
Hi!Looks like the cable which connects the screen to the motherboard is loose. Although nothing seems to be broken, the disassembley is still required to put the cable in it's place. If you decide to do it yourself, you can find lots of guides and videos in the net. Here is one, for example: Disassembly-Guide">http://www.scribd.com/doc/3534195/Motorola-v3-Disassembly-Guide
Hope this helps!
Mar 13, 2011 | Motorola Mobility RAZR V3
I have a Motorola Razor V3 mobile. Currently I m
software corruptd.. take it to moto service center and re-install ur software
Apr 13, 2010 | Motorola Mobility RAZR V3
Motorola Razor V3xx has frozen keys except on/off button
Take the battery out and set it under a hot laptop for a half hour.
Jun 12, 2009 | Motorola Mobility RAZR V3
Keypad does not work
I had a common problem which none of my keys worked except the "off" key. I baked my phone in the oven on the lowest setting for 20-30 minutes and it works now. It is a humidity issue.
Mar 16, 2008 | Motorola Mobility RAZR V3
My screen.
this is a common problem with razors it busted and you won't be able to fix it. time to get a new phone
Jan 17, 2008 | Motorola Mobility RAZR V3
Frozen buttons except red end call button
it seems you have the common v3 keypad flex problem - normal issue - it costs $25-40 to replace depending where you do it.
we charge $25 + shipping
http://horizonwirelessonline.com
Dec 25, 2007 | Motorola Mobility Razor Behind-the-Head...
ALL BUTTON OF RAZOR V3 FROZEN
That happened to my phone and I had to return it, there was no fix.
Sep 22, 2007 | Motorola Mobility RAZR V3
Razor is frozen up
u need new key pad ribbon might be ic on board http://www.mobilephoneservicecentre.co.uk/
Jun 18, 2007 | Motorola Mobility RAZR V3
Razor problems
http://cnn.cn/shop/motorola-razr-button-cable-memory-battery-p-632.html :)
May 06, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
170 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
