Question about Home
Is an oven bag made of plastic? - Home
    Problem Solver:
  • 16 Answers
The bag can be made from plastic or nylon. It has to be a material that can reach high temperatures without being affected.
Posted on Jan 14, 2013
Beef tri tip roast in oven
Directions
  1. Rub roast all over with thyme, basil, marjoram, mustard, salt, and black pepper. Place meat in a sealable plastic bag, seal the bag, and refrigerate, 8 hours to overnight. ...
  2. Preheat oven to 450 degrees F (230 degrees C). ...
  3. Place meat in the prepared roasting pan.
  4. Roast in the preheated oven for 15 minutes.
Tri Tip Roast Recipe - Allrecipes.com
allrecipes.com/recipe/240779/tri-tip-roast/ Beef tri tip roast in oven Google Search
Dec 21, 2016 | Ovens
Melted plastic on heating coil
you can not remove the plastic safely please replace the heating element
Sep 30, 2013 | Frigidaire (FEB30S7D) Oven
At what temperatures can an oven bag resist without burning or leaking?
Most oven bags are made of a very heat resistant plastic or naylon so they can stand cooking in the oven at very high temperatures. Most companies write on the box the maximum temperature that the bag can stand without breaking, melting or leaking. However i'd suggest not cooking over 180 or 200 degrees celsius, especially for more than one hour, because the bags tend to leak a little bit.
In case there is a need for a long cooking at high temperature i'd suggest placing two bags one into the other, and then placing the whole thing on an alluminium tray or the ceramic or pyrex container where the food will be served (if it can go in the oven). This way, if both bags end up having little holes and the juice or sauce leaks, it will be caught by the tray and it can be reused, instead of dirtying the oven.
Sep 11, 2013 | Home
How do I prevent leakage from oven bags?
I suggest cooking food into oven bags at maximum 180 degrees celsius to prevent leakage, and for less than one hour. However it's always a good idea to put a tray or container under the bag so that in case there is some leakage, the sauce can be retrieved and it won't burn on the oven's floor. Another solution to prevent leakage is putting two bags one into the other, so to provide double protection.
In any case, whatever temperature you cook at or for however long, never put the bag too close to the sides of the oven or too close to its top or bottom. Closeness to very hot surfaces raises the chances of melting the plastic and therefore causing leakage.
Sep 11, 2013 | Home
What is an oven bag?
This is a bag that keeps the moisture in the bag and not floating around the oven. It is used when cooking food especially meat in an oven. The bag does the same job as basting. The bag should not touch the heating part of the oven or the racks because it can melt or catch fire.
Jan 14, 2013 | Home
I have dried on grease stains on the bottom of my pots and also there is a whitish colored film that remains after the pots are washed and dried. I need to know how to clean them.
Spray Oven Cleaner all over stains, SEAL inside plastic garbage bag, leave bag for 2 days, wash pans with scrubber pad, stains should be soft and come off with a little rubbing.
Nov 20, 2010 | Microwave Ovens
Can you put the top oven grates in the oven while it is self cleaning
The top burner grates are designed to handle direct heat in excess of self clean temperatures.
You can put the grates in to the oven during self clean... but it will not clean them. The baked on residue needs some chemical reaction to break down the reside on them. I would suggest soaking them in an oven cleaner like easy off. Spray them down good then using rubber gloves put them into a plastic garbage bag, spray them again in the bag and close it up. Let them sit and soak for an hour or so then wash them off. This is best done outside so the odors will not be in the home in an enclosed area.
Apr 26, 2010 | GE Profile JGP636 Gas Cooktop
Cleaning grates of GE profile gas stove
Sounds crazy, but this works. Soak the grates in warm to hot water with 2 dryer sheets (Bounce), let them soak for an hour or two. Unbeliveable how they came clean. I did have to use a Scotch Brite pad on the two that I use most, but it sure beats replacing them.
Jul 02, 2008 | GE Profile JGP636 Gas Cooktop
I have a Jenn-Air slide-in range with a gas top and electric oven. I have tried to clean the gas grates without much success. I have also tried to clean my white exhaust cover for the down-draft. It has...
i would NOT recommend putting grates in oven while self cleaning, dont even leave the racks in there!!!! ammonia supposedly cleans them pretty good, get yourself a plastic garbage bag and a measuring cup full of ammonia. place the grates in the bag and stand the cup up in the bag with them, close the bag and place on the back stoop over night. the FUMES do all the heavy work you rinse off under the sink.DO NOT pour over the grates but stand up the cup next to them.make sue to seal the bag as well!!!
Mar 08, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Home Logo
659 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
