Question about LG WM-2277HW Front Load Washer
Soap in LG
How much soap does it take in LG for large wash
    Scholar:
  • 140 Answers
Hello, to answer your question, it depends. Are you using liquid detergent or powder? How dirty are your clothes? How bulky are your clothes?
For average size clothes and normal dirt I use about a cup of powder. If the clothes are dirty and/or bulky I just hit the "water plus" button. These machines are so efficient you don't want too much soap, just add water.
If your using liquid make sure it's approved for front load washers and use it sparingly. The most I have put in is about half up on the dispensing cup in the washer. Remember to remove this if your using powder. Any more questions just ask. Good luck.
Posted on Jan 23, 2009
  • David Robinson Jan 28, 2009
    Hello, just checking to see if I helped you with your soap issue. I am not only an experienced appliance repairman but, I also own an LG washer and dryer.
    If you need anymore help you can click on my dmr0dmr and your question will go directly to me
    Please remember to rate me at a fixya if I helped. Thanks.
4 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: Soap powder remains in the soap compartment
Depending on which compartment the powder is remaining in, it could be low water pressure causing the problem.
If it is taking some down, but not all the powder, then try putting the powder towards the front of the compartment.
If all else fails then I suggest you get one of these dispenser balls that you put straight in the drum with the washing.
Plz rate this solution.
thanks.
Posted on Dec 28, 2008
beltronic205
  • 1474 Answers
SOURCE: Lg. amt of water in soap dispenser after each wash.
Could be floor leveling ..Adjust and try
Posted on Oct 03, 2009
Testimonial: "Thx, won't worry about the water puddling in door boot seal, am concerned about water in soap disp., will see if there was an issue with installation"
pride applia
  • 232 Answers
SOURCE: soap coming out of washer
wrong soap check your use care guide for proper soap. check door gasket for anything on it. the smallest peice of debri can make it leak. over loading can make it leak
Posted on Dec 25, 2009
Issues with leftover soap and water in soap dispenser when wash is done. Cleaned dispenser and still doing it!!! PLEASE HELP
Remove the soap drawer completely, and wash it in warm water. Clean the roof of the hole where the dispenser drawer is using a plastic pot brush and some hot water. There are holes where the water comes from and they get splashed with soap.
Jan 31, 2016 | LG WM2140CW Washer
Washer can't remove the soap , and have to wash the clothes handly to clean soap
Remove the soap build up between the wash tub and the outer basin with a fridge or dryer lint brush. The soap accumulates and builds up between the two tubs. Clean it after a recent load of laundry so it has a chance to soften up. Make sure the washer is unplugged when you clean this area.
Use Borax and half the amount of soap in future wash loads to prevent this build up.
Mar 23, 2014 | LG Washing Machines
LG tromm washer soap not empty after wash cycle
I have a front load He LG Tromm model 2455 HG. I never use more than 3 tablespoons for any load. This soap is so concentrated that is all you need, which really isn't very much. Too much soap could possibly cause foam to back up. Starting with the basics, could this be your problem?
Feb 19, 2013 | Washing Machines
Soap coming out of washer
Dec 25, 2009 | LG WM2487H Front Load Washer
Oct 03, 2009 | Washing Machines
LG WM2496HSM
Take a few of your washed towels and start washing them again with no soap or fabric softner. After the washer tumbles a couple minutes pause the machine. You should see no suds at all. I'll bet you see some suds. Suds now indicates there is soap residue in the machine and / or the fabrics. The soap residue in the fabrics is what is causing most of the odor and the poor cleaning. The problem is too much soap and / or fabric softner. Remember, the old top load washer you had before used about 40 to 45 gallons of water for an extra large load. Your LG uses about 12. First thing to do is clean the washer using a package (three tablets) of "Ah Fresh" washer cleaner, using the tub clean cycle if your model has it, or if it does not have that cycle, use the hottest, longest cycle, + stain setting option. Second, wash all the clothes again without using soap or fabric softener. Third, from now on, use a maximum of a tablespoon of HE (even less if it is 2x concentrated) soap and one teaspoon of fabric softener. Hint: If you rinse well before you towel off your towels are only wetted with clean water. They are not dirty. If you wash them, try washing with no soap.
Sep 04, 2008 | LG WM2688HWM TROMM SteamWasher
Washing machine code OE
It means that the washing machine drain is clogged or has soap in it. Pull out the washer and clean the drains and then it should work properly. Also make sure that you are using HE soap only if the drain has excess amounts of soap (that other non HE soaps have) it will also clog the drains
Apr 18, 2008 | LG Washing Machines
LG WM2277HS - water backing up into soap dispenser
The pipe from the soap dispenser to the tub is quite large, it seems as if the water isn't getting out of the dispenser quick enough. Pull the whole dispenser out of the machine. There is a release clip at the back of the cup with the tray fully open. Clean out all soap residue and scum. Sometimes there is also a spot or setting for liquid or powder detergent. Adjust accordingly. Reassemble and try it again.
Apr 08, 2008 | LG WM-1485FHD Front Load Washer
Washer lg
You are probably using too much soap. You also need to make sure you're using HE detergent. To test this run the washer empty (no soap) and if you see bubbles inside that's left over soap that's still in the unit. If so, keep running it empty until the bubbles are gone then start using only about 1 tablespoon of soap per load. The washer uses about 1/10 of the water so you need to use 1/10 of the soap. Use the same amount of softner.
Jan 13, 2008 | LG WM2277H Front Load Washer
LG front loader problem
If you remove the top cover you will see the soap dispenser unit on the left. It has a large rubber hose connecting it to the drum. If you remove two screws at the front you can free the dispenser for maintenance. You can undo the clips on the various hoses and check that they are clean.
Some people report some dripping from the soap dispenser even when the hose is unblocked. This seems to be a design fault.
Nov 04, 2007 | LG WM2277H Front Load Washer
LG WM-2277HW Front Load Washer Logo
241 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
