Question about Vacuums
Replace motor taken apart putting back together dont know what coulr wire goes to which from the heating ellement
  • 91 Answers
Green is always ground. white or gray is always neutral. and black, red always hot. without know what make,model machine your working on this is best info i can give.
Posted on Jan 14, 2013
SOURCE: HOOVER STEAM CLEANER PROBLEM
The switch in my hover steam cleaner is broken, how do I repair it
Posted on Feb 15, 2008
  • 55 Answers
SOURCE: canister will not release
I've done that.
There is a stem that runs down the center of the cyclone that releases the bottom. You didn't get that stem back in place. The only thing you can do is pry it open, hope is doesn't break, and put that cyclone back together correctly.
I've never broke one, but I had to pull pretty hard. Thought I was going to.
Good Luck
Posted on Nov 26, 2008
galati2k
  • 281 Answers
SOURCE: Eureka boss vacuum, model 4331
if the switch is still connected the take one wire off at a time and put it on the new switch if you do it that way you can't make a mistake.try and get a wirng diagram from eureka or take it in and let a proffesional do it
Posted on Apr 10, 2009
  • 175 Answers
SOURCE: replace wheel axle on my kirby g3 vacuum. have a
The spring goes inside that pedal that you step on to advance the height. Place that spring in that pedal and then place the pedal into its' groove, then put the axile and wheel assembly over the pedal and put your screws back into the mounting sections.
Posted on Jan 01, 2010
heatman101
  • 43501 Answers
SOURCE: i need to know how to put bissell proheat 2x back together
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
ghsgh
Posted on Sep 30, 2010
How to replace an Electrolux Z331 motor?
Did you follow how motor was taken apart? If not, hopefully color goes with color.
May 06, 2014 | Electrolux Vacuums
Putting the head back together
its usually quite simple all you have to do it attach the belt that rotates the motor(sometimes there are two) to either end attach them to the tension prongs clip the brush head in place them screw the retaining plate back hope this helps
Apr 07, 2014 | Eureka 439Az Pet Lover Oh Upright Vacuum
I have taken henrys lid off to look at the motor now he has stopped working
It's possible when you took the lid off one of the wires has come off a switch or the field. It could also mean the motor has gone. Recommend you get it checked out.
Dec 10, 2012 | Numatic Henry Bagged Canister Vacuum
The "hand" run by battery
You have to take it all apart and clean the gears and shaft with keroseen on a rag. Use steel wool to take the rust off the shafts and gears and see if the motor will spin without the gears attached to it. If it does not that has to be taken apart and cleaned. When putting it all together use a light grease or vasoline and put a little on the gears and shafts. Put a little on the motor shaft but make sure you do not get it on the comutator where the brushes ride on the motor.
Mar 11, 2011 | Vacuums
Replace wheel axle on my kirby g3 vacuum. have a
Dec 31, 2009 | Kirby Vacuums
How to replace the elboe on the power nozzle
wouldnt recommenddoing it urself as it may have warranty. But if u have the head off and the elbow apart im not sure what parts u have. If u have both these taken apart. It is pretty much self explanitory. u need to take the prongs out of the one end. At the other end ot the wires there r two attachements. The end that is at an angle attaches to the reset button which is by the L shaped part. The opther wire attaches either directly to the small motor itself, or to another wire which has a plastic cover on it. The wires that you took the prongs off of the rest along side the little knobby piece and then you wrap them around the middle of the knobby piece. Slide the elbow sleeve over the knobby piece and then turn it so u can bring the ends of the wires out of the little hole in the middle of the elbow sleeve. When the is done attach the two little clips back on the the elbow the one on the inside and the one on the outside at the back of the elbow. reattach the prongs to the ends of the wires put them into the notches about the middle of the elbow sleeve. Reattach the little cover and ur done. If u have the whole assembly. Take p/n cover apart and reattach wires where they r already connected inside the head. Put the head back together. Feel free to give me a call 1-866-966-9350.
Jul 13, 2008 | Electrolux Guardian Bagged Canister Vacuum
Repplacing power cord on Hoover Wind tunnel (not self propelled)
I am thinking that the cord goes in on the back, just below the handle. Remove the handle, then from the front, remove the tool holder(#8), then you can get to where the cord comes in and hooks up.
Feb 12, 2008 | Hoover U5753-900 WindTunnel Bagless...
Rainbow Vacuum Cleaner starts slow smells hot
Sounds like the motor is going bad and will eventually not start. I am in the process of changing the motor in mine too and they are not cheap. just search around for a motor
Aug 31, 2007 | Rainbow E series Canister Wet/Dry Vacuum
Vacuums Logo
22 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
