Question about Home
What is a mortar? - Home
    Problem Solver:
  • 8 Answers
A mortar is a wooden/ceramic/stone bowl used with a pestle to grind.
Posted on Jan 14, 2013
The mixture of sand and cement for laying bricks
mortar proportions are always expressed as a proportion of cement to lime to sand and always in that order
common mortar made from portland cement has one part cement to one part lime and 6 parts sand ===1:1:6
Cement bags have the mix written on the side for mortar mix or concrete mix or you can get mortar mix cement which already has the lime added
Oct 22, 2016 | Washing Machines
Tip
Mortar and Pestle to make Pesto
Many have chosen to be lazy and try to make pesto with a food processor. However it is widely known that the best way to make pesto is by using a mortar and pestle.
Here is an Italian recipe for the traditional Pesto Genovese:
Ingredients:
2 cloves of garlic
a pinch of kosher salt
100 ml of extravergin olive oil
50 gr of basil leaves
30 gr of grated pecorino cheese
1 tbs of pine nuts
70 gr of grated parmesan
Instructions:
First of all basil leaves should not be washed, rather cleaned with a soft cloth.
Take the peeled garlic cloves and put them in the mortar with a bit of kosher salt. Start grinding.
When the garlic will look creamy add the basil leaves with a pinch of kosher salt and grind.
The grinding should be done towards the walls of the mortar, turning the pestle right and left and the mortar the opposite way.
Continue until the leaves will release a bright liquid, then add the pine nuts and keep grinding.
Add the cheeses a bit at a time, mixing all the time.
Last add the oil, slowly, in a thin line, while mixing.
Mix well until all is one cream.
All the grinding and mixing should be done exclusively in a marble mortar and using a wooden pestle. No metal should be involved.
on Oct 13, 2013 | Home
Can I put bbs into the mortars of a black ops airsoft mortar launcher?
These mortars are made to be used with water and CO2 I can't see how you would be able to put bbs in it and it would work, not to mention that would be very dangerous.
Feb 16, 2014 | Toys
I would loike to remove my bottom nailinf fin on my pella replacment window
should not be a huge issue to trim off the bottom nailer... trim off with a razor knife being careful not to penetrate the frame. the primary concern is providing support to the frame. Using mortar and wood shims, layer mortar where the window will sit and level it using the wood shims, leaving space to remove the shims after the mortar sets... I'd recommend using screws to afix the remaining fins to the studs to lessen the loss of mortar from shifting the window during install
~~~~] shim [~~~~mortar~~~~] shim [~~~
Nov 18, 2013 | Heating & Cooling
Are mortar and pestle better than electric grinders?
It depends on what you need to grind. Some electric coffee grinders are very good for certain seeds for example, while substances like basil come out better tasting and with a nicer color when crushed with a mortar and pastle.
Also, if you need to produce big quantities of ground substances it would probably take you a long time to do it with mortar and pestle, and using an electric grinder would help you speed up the process.
Sep 12, 2013 | Home
Which is the best material for a mortar and pestle?
Mortar and pestle must be made of a hard enough material so that seeds and plants can be crushed without wearing away the tool, and so that the pounding and grinding won't break it.
The material should also be smooth and non-porous so that it won't absorb or trap the substances that are being ground.
There are a few materials that all more or less fit these requirements: ceramic, porcelain, glass, marble, stone, wood, bamboo, iron, steel, brass and basalt.
The choice among these is based on what use you need the mortar and pestle for.
For example rough ceramic is more fragile than stone but makes a finer powder. While glass, also fragile, is stain-resistant. Wood absorbs more easily but is very good for the grinding of salt and pepper at the dinner table. While metal mortars need to be kept lightly oiled.
I personally would suggest a heavy, thick, smooth marble mortar and pestle, as it is both very resistant to pounding, and grinds pretty finely. Marble is good with both liquids and dry seeds and plants, and it doesn't absorb odors and tastes as much as other materials, even tho it does get a bit stained and sometimes previous substances can still be smelled on it for a while.
Sep 12, 2013 | Home
When were mortar and pestle invented?
Mortar and pestle seem to have been used since anchient times to grind seeds and plants. There are sources of its use both in the Egyptian Ebers Papyrus (1550 BCE) and the Bible.
Different variations of mortar and pestle can be found in almost every culture, all over the world.
Sep 12, 2013 | Home
Tuckpointing brick, mortar won't stay in. have a beveled 2 ended tool from lowes does not work
is the recess deep enough on the bed and perp joints if so is the mortar the right consistency.
a little tip is to wet the joints with water before jointing. it stop the mortar drying out to quick
Aug 11, 2013 | Masonry Tools
Adhesive for granite tiles on kitchen counter?
Mortar, go to a tile supply store and ask for the best tile mortar for granite.
Glue is fast and easy but pails in performance to that of mortar.
Jan 03, 2010 | RTO 5/16" X 4" Long Groo V Tip Granite,...
Frost damage to cement mortar
Your fears are well-founded. Here in NW, MO the sand and mortar are heated prior to using in freezing weather.
Dec 20, 2009 | Saws
Home Logo
589 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
