Question about Cycling
How many bicycle gears types are there? - Cycling
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 63 Answers
Bicycles usually have 1, 3, 18, 21, 24 or 27 gears. There used to be bikes with 10 and 15 gears but this are old and bike manufacturers do not manufacture them anymore.
Posted on Jan 14, 2013
I have a classic ss men's Schwann that I would like to convert to a geared bike. How do I go about getting parts to do this. Can it be done?
I am not familiar with the type of bicycle but I assume the bike is currently a fixed wheel type - the type sometimes described as an ash track racer?
The problem when converting will be keeping the frame geometry correct while bending the rear forks to accommodate the wider axle of the wheel with a deraillier gear. It is necessary for the chain wheel to align exactly with the middle sprocket of the cluster.
The best option would probably be to fit a two, three or four speed hub.
Apr 22, 2017 | Cycling
How do the gears work
Have a read and watch some videos.
  • How do Bike Gears Work? ' Design Squad - YouTube www.youtube.com/watch?v=oauDyIu_swM
    • BY DESIGN SQUAD GLOBAL
    • 3 MIN
    • 107K VIEWS
    2012-10-12 · How do Bike Gears Work? ' Design Squad ... What Is Inside A Bike Freewheel/How Does It Work? - Duration: 3:56. RJ The Bike Guy ...
  • Bicycle Gears - How Bicycles Work ' HowStuffWorks adventure.howstuffworks.com/outdoor-activities/biking/bicycle3.htm Bicycle Gears - Bicycles aren't just for kids. ... How Bicycles Work. by Marshall Brain Adventure ' Biking. Bicycle Gears. Prev Next . You have ...
  • Bike Gears: How Do They Work - Sportive Cyclist sportivecyclist.com/bike-gears-how-do-they-work Now, if you'd like to learn more about bike gears, and chainsets in particular ... Bike Gears: How Do They Work (learn what terms like '53/19? mean) ...
  • Bicycle gearing - Wikipedia, the free encyclopedia https://en.wikipedia.org/wiki/Bicycle_gearing Bicycle gearing is the aspect of a bicycle drivetrain that determines the relation between the cadence, ... Hub gears work using internal planetary, ...
  • How to use Bicycle Gears ' Gears on a Bike bicycleuniverse.info/eqp/gears.html How to use Bicycle Gears. ... This works because the higher gears move you farther for each spin of the pedals, making you do more "work" ...
  • Hub gear - Wikipedia, the free encyclopedia https://en.wikipedia.org/wiki/Hub_gear A hub gear, internal-gear hub, or just gear hub is a ... 1959 Elizabethan Apr. 35/1 My lightweight bike with 4-speed hub gear ...
  • Technique: How to use your gears efficiently ' Total Women ... totalwomenscycling.com/...how-to-use-your-gears-efficiently-9497 Total Women's Cycling . ... Find out how to change gears on a bike and learn to use your gears efficiently, ... Liked this guide on how to use your gears efficiently?
  • How do bicycle gears work? - Ask.com www.ask.com > ... > Biking & Cycling > Bicycles Bicycle gears work by moving the bike's chain on varying chainring and cog combinations to match the desired drive wheel speed, cadence and pedaling speed of ...
  • Apr 21, 2016 | Cycling
    The more gears the better the bicycles?
    Not Necessarily... If you are not a professional athlete then the number of gears you have does not really matter. What matters is the range of the gears. You need low enough gears for going up hills and high enough gears for inclines.
    Jan 17, 2013 | Cycling
    My shimano ultegra left shifter is super stiff/hard to push in; what is going on?
    Try flushing out the shifter(s) with WD-40, use plenty. The next step will be replacing the shift cables and cable housings.
    • Take the bicycle in an area free of cars and obstacles, such as an open parking lot. Concentration is required when learning to use Ultegra shifters or any other type of bicycle shifter.
    • 2 Mount the bicycle and rest both hands on the proper Ultegra hand control. The left-hand control operates the front derailleur. The right-hand control operates the rear derailleur.
    • 3 Start pedaling, smoothly and evenly. While pedaling is crucial to propelling the bicycle forward, it is also necessary when shifting the derailleur. Pedaling forces the chain to rotate. The chain must rotate before it can transfer to another gear.
    • 4 Push the outside right Shimano Ultegra lever in toward the bicycle. The rear derailleur will shift the chain to a smaller rear gear.
    • 5 Push the inside right Shimano Ultegra lever in toward the bicycle. The rear derailleur will shift the chain to a larger rear gear.
    Rear Ultegra Derailleur Control
    • 1 Push the outside left Shimano Ultegra lever in toward the bicycle. The front derailleur will shift the chain to larger front gear.
    • 2 Push the inside left Shimano Ultegra lever in toward the bicycle. The front derailleur will shift the chain to a smaller front gear.
    • 3 Use the front and rear Ultregra hand controls interchangeably. For small changes in gearing, using the rear control. For larger changes, choose the front control. A smaller gear causes the bicycle to travel a shorter distance per pedal stroke but also requires less energy to use. A larger gear requires greater effort but in turn causes the bicycle to travel farther per pedal stroke.
    Oct 25, 2011 | Cycling
    What does each gear mean, ie.: is gear 1 for hills, etc. what do I do if chain comes off? If I need a part, where do I go to get it?
    1. The ratio of the driving gear to the driven gear is the gear ratio. Lower ratios give higher torque; higher ratios give higher speed. You can't have both.
    Search engine "how do gears work on a bicycle"; "what do I do if chain comes off"; "how to shift a bicycle". Many videos and resources.
    2. Bicycle shops, eBay, online Search Engines
    http://www.parktool.com/blog/repair-help
    Jul 11, 2011 | Cycling
    How do I operate the 8 gears on my bicycle as I have no instruction manual ? Please advise. My bicycle is a "Carolina Free Spirit". Thanks
    Google bicycle shifting technique, for example:
    http://coachlevi.com/cycling/complete-beginner-guide-to-bicycle-gears-shifting/
    The basics of shifting are these:
    1) The big ring and right side of the cassette in back are for speed.
    2) The small ring and the left side of the cassette are for high torque, lower speed
    3) The middle ring works with all rear cogs.
    Avoid crossing left front to right rear and vice-cersa. It cause excess side loads on the chain.
    Mar 07, 2011 | Cycling
    What chain set type do I need for my Marin Hybrid Bicycle?
    SRAM and Shimano both make good quality chains. Try to use the same chain type as what was on your bike originally.Here are two good sites with helpful articles:http://www.parktool.com/repair/byregion.asp?catid=5 and http://sheldonbrown.com/chains.html
    Oct 23, 2009 | Cycling
    Shift Bicycle Gears
    To shift gear properly, while riding the bike you be sure you are turning the paddles, and shift the gear.
    Try to avoid shifting gears while riding standing up, this stress the gear system.
    Oct 29, 2008 | GMC Denali 700C Road Bike
    Cycling Logo
    336 people viewed this question
    Top Cycling Experts
    John Egan
    John Egan
    Are you a Cycling Expert? Answer questions, earn points and help others
