Question about Home
What is a pestle? - Home
    Problem Solver:
  • 8 Answers
A pestle is a heavy tool that resembles a club that is used for grinding.
Posted on Jan 14, 2013
What is the main causes of over heating an damaging of pestle even, brocking of corn root?
not enough oil ? not stiring corn to keep it moving? thermostat on kettle stuck on ?
Dec 31, 2014 | Kitchen Appliances - Others
Tip
Mortar and Pestle to make Pesto
Many have chosen to be lazy and try to make pesto with a food processor. However it is widely known that the best way to make pesto is by using a mortar and pestle.
Here is an Italian recipe for the traditional Pesto Genovese:
Ingredients:
2 cloves of garlic
a pinch of kosher salt
100 ml of extravergin olive oil
50 gr of basil leaves
30 gr of grated pecorino cheese
1 tbs of pine nuts
70 gr of grated parmesan
Instructions:
First of all basil leaves should not be washed, rather cleaned with a soft cloth.
Take the peeled garlic cloves and put them in the mortar with a bit of kosher salt. Start grinding.
When the garlic will look creamy add the basil leaves with a pinch of kosher salt and grind.
The grinding should be done towards the walls of the mortar, turning the pestle right and left and the mortar the opposite way.
Continue until the leaves will release a bright liquid, then add the pine nuts and keep grinding.
Add the cheeses a bit at a time, mixing all the time.
Last add the oil, slowly, in a thin line, while mixing.
Mix well until all is one cream.
All the grinding and mixing should be done exclusively in a marble mortar and using a wooden pestle. No metal should be involved.
on Oct 13, 2013 | Home
A seven letter word from these letters ypteltdnopxs
deepdye
deepens
deepest
deepset
deleted
deletes
denoted
denotes
densely
densest
depends
deplete
deploys
deposed
deposes
despond
despots
detente
doodles
doyenne
endless
entente
expends
expense
explode
exposed
exposes
extends
extenso
extents
eyeless
eyelets
eyespot
lessees
lessens
lessons
looplet
loosely
loosens
loosest
needled
needles
nestled
nestles
nettled
nettles
nonstop
noodles
notedly
oddness
odyssey
oldness
oneness
opposed
opposes
oxytone
peddled
peddles
pellets
pendent
pentose
peopled
peoples
pepless
peptone
pestled
plopped
plotted
pollens
pondlet
pontoon
poodles
popeyed
popeyes
possess
seedpod
settled
settles
sexless
sledded
slopped
slotted
slyness
snooped
sonnets
soonest
speeded
spelled
spleeny
spondee
spooled
spooned
spotted
steeled
steeped
steeple
steeply
stepped
steppes
stepson
stetson
stooped
stopped
stopple
syntone
syntony
systole
tendent
tendons
tensely
tensest
tenspot
toeless
tollens
topless
toppled
topples
tosspot
tylenol
typeset
Apr 29, 2014 | Toys
1994nissan 4x4truck...when I turn it on it stalls...when it on and you push the gas pestle it dies off...need help...is it the throttle body or the timming ?.?
cud be many things with age of car--idle air motor probly worn or dirty--also tps device or trottlebody issues--gas pump may be failn--ignition components may be old like distributer cap and coil--get a haynes manual for service procedures---perform a scan at a partsplace
Sep 22, 2013 | 1985 Nissan Pickup
Are mortar and pestle better than electric grinders?
It depends on what you need to grind. Some electric coffee grinders are very good for certain seeds for example, while substances like basil come out better tasting and with a nicer color when crushed with a mortar and pastle.
Also, if you need to produce big quantities of ground substances it would probably take you a long time to do it with mortar and pestle, and using an electric grinder would help you speed up the process.
Sep 12, 2013 | Home
Which is the best material for a mortar and pestle?
Mortar and pestle must be made of a hard enough material so that seeds and plants can be crushed without wearing away the tool, and so that the pounding and grinding won't break it.
The material should also be smooth and non-porous so that it won't absorb or trap the substances that are being ground.
There are a few materials that all more or less fit these requirements: ceramic, porcelain, glass, marble, stone, wood, bamboo, iron, steel, brass and basalt.
The choice among these is based on what use you need the mortar and pestle for.
For example rough ceramic is more fragile than stone but makes a finer powder. While glass, also fragile, is stain-resistant. Wood absorbs more easily but is very good for the grinding of salt and pepper at the dinner table. While metal mortars need to be kept lightly oiled.
I personally would suggest a heavy, thick, smooth marble mortar and pestle, as it is both very resistant to pounding, and grinds pretty finely. Marble is good with both liquids and dry seeds and plants, and it doesn't absorb odors and tastes as much as other materials, even tho it does get a bit stained and sometimes previous substances can still be smelled on it for a while.
Sep 12, 2013 | Home
When were mortar and pestle invented?
Mortar and pestle seem to have been used since anchient times to grind seeds and plants. There are sources of its use both in the Egyptian Ebers Papyrus (1550 BCE) and the Bible.
Different variations of mortar and pestle can be found in almost every culture, all over the world.
Sep 12, 2013 | Home
I dont have a garlic press, what should I do?
I used to use a soup can to crush it, but then I bought a mortar and pestle. You can also chop it up with a knife, use a meat pounder, or use a food processor for large amounts.
Feb 04, 2013 | Home
What is a mortar?
A mortar is a wooden/ceramic/stone bowl used with a pestle to grind.
Jan 14, 2013 | Home
How do you grind ice for a mojito?
The best way to grind ice for a mojito is with a classic ice grinder. If you don't have one, a mortar and pestle or a few pulses in a blender will do the trick.
Jan 10, 2013 | Home
Home Logo
586 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
