Question about Home
I'm looking for a mixing bowl that comes with a cover.
    Problem Solver:
  • 16 Answers
KitchenAid KSM150 bowl won't stay put
I'd be looking at making sure the beater is not banging on the bowl and that the head hinge isn't loose. The bowl is secure on the base with this system that has been in use for decades so you are looking for a fault not a re-design of the system. The friction of the mix in the bowl should logically tend to tighten the bowl, not undo it. I have seen a malformed bowl once where the lugs weren't big enough and I suspect that it's possible for there to have been the odd malformed bottom plate with not big enough lugs.
Jul 08, 2017 | KitchenAid Kitchen Aid KSM150 Artisan 5...
I have an aprilia rx125 2008 & the oil petrol mixing system has been blocked off and now petrol & oil are mixed in the petrol tank, but the bike starts for 3-5seconds then stops & petrol comes out of
Hi Steve, and the usual suspects are:
1. Damaged or restricted fuel tank venting system.
2. Loose float bowl screws.
3. Damaged float bowl o-ring.
4. improper fuel level in the float bowl.
5. Worn or dirty inlet valve or seat.
6. Damaged or leaking float assembly.
7. Particle contamination in inlet fitting cavity.
For more information about your issue please visit the websites below. Good luck and have nice a day.
DOWNLOAD 2008 Aprilia Rx 125
Dec 04, 2011 | 2008 Aprilia RX 125
I need to down load a manual for ge ice cream maker model 106765
  • 1
    Place the mixer bowl in the freezer. The amount of time required depends on the temperature of your freezer, but you should expect to leave it in the freezer for about one day prior to use. To check if the bowl is frozen, shake it gently. If you don't hear any liquid sloshing around inside, it's ready to use.
  • 2
    Place the mixer bowl onto the motor base when you're ready to make ice cream. Insert the mixing paddle into the bowl and place the cover over the bowl.
  • 3
    Turn on the ice cream maker and pour the ice cream mixture into the hole at the center of the appliance until it reaches the fill line. Do not exceed the fill line, as the ice cream will increase in volume as it freezes. Use the low setting if you want a firm ice cream and the High setting if you want a softer consistency. Do not add nuts, candy or chocolate chips at this stage as they can become hung up in the mixing paddle and stop the machine.
  • 4
    Cover the center hole with the cap and allow the ice cream maker to run for 30 to 45 minutes.
  • 5
    Add mix-in ingredients such as nuts and candies two minutes before shutting down the machine.
  • 6
    Turn off and unplug the machine prior to removing the ice cream from the bowl. GE recommends using plastic or rubber utensils to avoid scratching the inside of the mixer bowl.
  • Read more: GE Ice Cream Maker Instructions ' eHow.co.uk http://www.ehow.co.uk/how_7784888_ge-ice-cream-maker-instructions.html#ixzz1ahXwP2GR
    Sep 09, 2011 | Gel Canister 106765 1.5 Quart Ice Cream...
    GWL11 fisher & paykel with error code 56 (lights 3,4,&5) what does this mean?
    This code usually relates to the bowl not disengaging proper to agitate - few things to check - is there enuff water in the machine? - is the clothes packed to one side kinda? - remove the display cover to check if you don't have a kink or the tube for the water level controller hasn't come off - remove the tube & blow into the "bowl end only" attach & try it out - you haven't lost a sock lately or something, it could be stuck between the two bowls? - machine not syphoning? - if none of these work then the RPS is gonna be the most likely problem.
    Aug 22, 2011 | Fisher and Paykel GWL11 Top Load Washer
    After putting flower into mixing bowl large quanity of flower is ejected when mixer is turnon at low speed. Once it starts to mix then it's ok.
    Firstly, I think you mean "flour".
    Put in your ingredients. Cover the mixer, head and bowl, with a dishtowel. Turn on mixer to "stir" (or lowest speed). But! Mix only for 1 or 2 seconds. Repeat this, with bowl covered, until flour is mixed in enough not to fly out.
    Happy baking!
    Dec 11, 2010 | KitchenAid Classic Stand Mixer
    Lumina (Aldi) ice cream maker instructions
    Before using the first time:
    1. Remove all of the packaging.
    2. Wash the parts. (the paddle & the bowl only)
    3. Eight hours in advance, place the inner bowl into a freezer.
    4. Prepare the ice cream or sorbet mix (see recipe ideas)
    Allow the mix to cool in the refrigerator.
    FYI, I freeze the inner bowl overnight instead of the eight hours as stated in the manual.
    Dec 29, 2009 | Ice Cream Makers
    Need directions on how make rice on my oster rice cooker
    There are many types of rice. Follow specific directions for variety used.
    2. Accurately measure rice and water then combine in rice bowl.
    Pour specified amount of water in water reservoir. Cover and steam.
    3. For softer rice, increase by 1 – 2 tablespoons the water mixed with rice
    by the specified amount of water on the chart. For firmer rice decrease
    water mixed with rice by the same amount.
    4. Check doneness and consistency of rice at minimum time specified
    for each type, stirring rice at the same time.
    5. When checking/stirring rice, be careful not to drip the condensate into the
    rice bowl which would reduce the quality and flavor of the steamed rice.
    6. Use only clean water in water reservoir
    7. Rice may be seasoned with salt, pepper or butter after steaming.
    Combined In Rice Bowl Approx. Time
    Type of Rice Rice Amount Water
    (Minutes)
    Brown
    Regular 1/2 cup 1 cup 42 – 45
    Parboiled 1 cup 1-1/2 cups 45 – 50
    Long Grain and Wild Rice Mix
    Regular (6 oz. pkg.) Mix 1-1/2 cups 50 – 55
    Quick Cooking (6-1/2 oz. pkg.) Mix 1-3/4 cups 18 – 20
    Instant 1 cup 1-1/2 cups 15 – 18
    White
    Regular 1 cup 1-1/2 cups 45 – 50
    Long Grain 1 cup 1-2/3 cups 50 – 55
    Oct 25, 2009 | Oster 5712 10-Cup Rice Cooker
    Beater rubbing bottom of bowl
    This sounds like an issue of beater to bowl adjustment, which can come out of alignment naturally over time and with use of the machine.
    If the flat beater is striking the bottom of your bowl, this may cause the locking mechanism to loosen and may cause the mixing head to "bounce" during use.
    Your Use and Care Guide will cover the "beater to bowl adjustment," which you can do at home in a few minutes with a flathead screwdriver.
    Feb 14, 2009 | KitchenAid KITCHEN AID 5 Quart Artisan...
    Kitchenaid Artisan Stand Mixer
    Dec 14, 2008 | Food Mixers
    Mixer head very wobbily.
    Nov 08, 2008 | KitchenAid K45SS Classic Stand Mixer
    Home Logo
    417 people viewed this question
    Top Home Experts
    Donni Steen
    Tom Chichester
    Are you a Home Expert? Answer questions, earn points and help others
