Question about GE Spacemaker JVM1640SJ Microwave Oven
Crackling/sizzling sound My GE spacemaker makes a crakling/sizzling sound as it cooks...otherwise it works fine. Is it safe? I have young children and am concerned. A year or 2 ago our tile installer accidently turned it on with nothing in it and one of the plastic peices melted, causing metal to be exposed...then it stopped heating entirely, we got both issues fixed (seperately) and we had a year of nothing... Is this "something"?? It appears that there may be some black ash on the inside door frame (as you look at it from the outside) but it doesn't make sense, it is minimal and it is never warm. Please someone help me...Should I just buy a new machine?
  • 5,911 Answers
If you're hearing a crackling noise and don't see any sparks, you may have a magnetron that is arcing inside the waveguide. Once this arcing occurs, in some cases, replacing the magnetron may not be enough to fix the problem. There was also a noted problem with some models where the stirrer motor shaft inside the waveguide would arc when the magnetron was energized. This too, caused damage inside the waveguide. If the internal walls of the waveguide become damaged it cannot be repaired and the unit must be scrapped. The waveguide has a special coating to help propagate waves of RF energy. If the walls are damaged due to arcing this special coating gets burned off and will continue to arc even if a new magnetron is installed. This will eventually lead to magnetron failure and potentially cause a fire inside the oven. I would think seriously about looking into another unit if any of this may be occurring in your oven. Better to play it safe, especially with small children. I hope you find this advice helpful. PS A new magnetron can run as high as $250.
Posted on Jul 09, 2007
SOURCE:
Ge microwave je2160sf03
From the description one of the door switches is defective, or a more serious problem has developed.
Jun 02, 2012 | GE Spacemaker Over-the-Range Microwave
After a few seconds my microwave makes a crackling
check for scraps of foil, wire ties any type of metal or tin,or aluminumif not any of that, ur looking at a componet problem
May 23, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker microwave oven - Sensor error
Hello :
Many models of the GE microwave have sensors that can detect humidity from the foods you are cooking. This allows the microwave to make adjustments to the power levels used to cook your food. If "Sensor Error" appears, you should either press "Clear" to cancel the mode or leave the food in the appliance longer to give the microwave more time to detect the food.
Press "Time Cook" to manually enter the time if you receive an error message when trying to use the "Sensor Reheat" mode of your GE microwave. The error message may be caused by the food item being too large or too small to detect
good luck .
please rate !
Mar 29, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
We have a GE Profile Spacemaker XL 1800. It began making a laboring noise and stopped cooking at the same time.
Sounds like the Magnatron or the HV Cap or diode is failed. Process of will show you which one. Very dangerous area to work in, not for the untrained. Eric
Aug 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Crackling sound in microwave vent when power is off
By "powered off" can I assume you mean that it is plugged in and at idle, not cooking, just showing the clock?
If so, I'd say your control board is failing.
If my assumption is wrong, please write back with more details.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller
[email protected]
http://www.microwavedisplay.com
Nov 02, 2008 | GE JEM25 Microwave Oven
BREAKING MICROWAVE SAFE DISHES
I would recommend having it looked at. Sounds like the magnetron or the maser is malfunctioning and not operating within it limits which could be potentially dangerous.
Feb 04, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave doesnt work
good day, try to check your cooking settings. tnx
Jan 20, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
838 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
Jimmy
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
