Question about Scuba Diving & Snorkeling
What is a dry suit and how is it different to a wet suit.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 63 Answers
A dry suit is loose fitting apart from a sealed neck, wrists and ankles to stop the water getting in. Dry suits do not provide insulation and the clothes worn under the dry suit keep the people warm they are used more for deep sea diving. Wet suits no not keep a person dry but they are insulated to keep the person warm during water sports or scuba diving.
Posted on Jan 14, 2013
What is the difference between wet clutches and dry
Wet clutches ride in oil ... dry do not.
Jun 17, 2013 | Motorcycles
It's my fox ( name brand) sweater . the fabric is acrylic . All I did was machine wash it then when I took it out I saw that it looked and felt different. So I wet it in cold wash try to get as much w
I have an acrylic blanket that feels different when wet, sort of tight. But when it dries out, it is soft and sort of spongy like before. Hopefully this will be the case for your sweater.
Feb 16, 2013 | Clothing
What should I wear under my dry suit?
Dry suits are not meant to keep a diver warm; they are designed to keep the clothing from getting wet. It may be even possible that a diver may get wet from perspiration or a leak in the suit. The types of materials to wear under the dry suit include pile fleece, polypropylene or wool as these types of materials will keep you insulated even when wet - avoid wearing cotton.
Jan 17, 2013 | Scuba Diving & Snorkeling
What are the different types of dog food?
Different types of dog foods are:
1. Wet foods that have high content of moisture in it.
2. Dry foods that contains low amount of moisture.
3. Semi-moist foods which have soft pellets with a chewy texture.
4. Frozen foods that are available frozen or freeze-dried formats.
Jul 18, 2012 | Dogs
Older model shop.vac parts/owners manuel
Hi, I know on my Craftsman shop vac 2 different sizes of vacs that I use, I try and stick to the craftsman filters, but you can use other brands if they are not available or you want to save some ( $ ) ? As far as a manual for this vac, more then likely you will have to go to the maker and distributor as Sears, O.C.Hardware also sell there products. You may have to go with a manual that is the same peak H.P.and gallons that covers all different makes and models. Filter wise, make sure you have the right ones on or off when using the wet or dry pick-up settings.
Sincerely,
Shastalaker7
Jan 23, 2010 | Craftsman 17765 Canister Wet/Dry Vacuum
How does may tag intelli dry work? what is the difference between less and more heat setting
there is a sensor inside the door to the right it actually "feels" the dampness of the clothes across the two strips on the sensor, if you close a wet washcloth in the door so that it hits the sensor you will see that it will show as wet and it will run longer.
if nothing in the load hits the sensor the sensor will call it dry and the load will finish, larger loads work better with sensor dry small loads not so much. if there is alot of trouble try using the timed dry cycle.
Sep 03, 2009 | Maytag PYE2300AY Electric Dryer
How could I purchase Hoover H3060 and does it suit
hello. i can help you. contact hoover directly at
http://www.hoover.com/CustomerService.aspx
they will answer all of your questions and assure that you get the right hoover with the right power pack.
Jun 25, 2009 | Hoover H3060 FloorMate SpinScrub 800...
Scuba suit need?
"Wet suits and dry suits are very important when it comes to scuba diving. Your normal body temperature hovers around 98.6F (37C). If you are scuba diving in water that is cooler than your body temperature your temperature will drop. In all water, even the warmest, tropical waters, you will need thermal protection, like a wet suit, dry suit or dive skin, to keep warm and to keep safe while scuba diving. The cold affects our ability to think and our physical response time slows, which can lead to an accident. Warm tropical water will begin to feel cold after prolonged scuba diving, so it is always a good idea to wear light insulation at a minimum. When choosing thermal protection, like a wet suit or dry suit, you need to consider the following factors: Water temperature Your activity level during a dive Your body size You should always wear more insulation in colder water and lighter insulation in warmer water. Your level of activity can be a good indicator of how much insulation you should wear during a scuba dive. The more active you are during a dive the more heat your body generates and the warmer you remain throughout your dive. Larger scuba divers may need less insulation than smaller scuba divers and small, muscular scuba divers may need less insulation than larger scuba divers. It is important for you to try different amounts of insulation in differing water temperatures to determine what you need. Some scuba divers need more insulation than others, regardless of activity or size. Some scuba divers can dive in tropical water wearing only a lycra body suit, commonly known as a dive skin, while others need a 2mm wet suit. Some scuba divers can dive in cold water wearing only a 6mm wet suit, while others need the protection of a dry suit. If you are scuba diving in water below 55F (12.7C), a dry suit is the warmest type of thermal insulation available. Dive skins, wet suits and dry suits also protect your skin from cuts, scrapes, abrasions and stings which can occur while you are scuba diving. A simple brush against specific forms of coral and fish can cause painful irritations and burns on bare skin, but may not be noticeable or even occur, if your skin is protected."
Dec 01, 2008 | ACCO Brands Apollo Bio-Filter Moisture...
Bread hook use
Use it to the side. This will pull the dry ingredients off the bowl. If the dough is coming out lumpy, make sure you follow the recipe exactly. Putting dry into wet will give different results than putting wet into dry. If this doesn't end the lumps, try a different type of flour.
Oct 15, 2008 | Sunbeam Heritage 2346 Stand Mixer
Scuba Diving & Snorkeling Logo
725 people viewed this question
Top Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Are you a Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
