Question about Epic A30T Treadmill
My treadmill will not connect to wifi.
I've disconnected a few devices and reconnected them while next to the machine to make sure I was putting in the correct password and yes it was correct.
    Top Expert:
  • Epic Master
  • 12,223 Answers
Go to https://www.ifit.com/install
install that update and try again, this will be fix it.you will need adobe go
http://get.adobe.com/air
God bless you
Posted on Jan 14, 2013
My wifi keeps disconnecting and have to restart phone to reconnect, but only lasts for maybe an hour
Samsung Galaxy S 4G Smartphone: WiFi disconnects (have to restart phone to reconnect, does not scan for WiFi connections):
Hello. It could be that your "Auto Network Switch" setting is on..
What Auto Network Switch does: when the WiFi gets too low the phone automatically switches to cellular, and when cellular connection gets too low, the phone will switch to WiFi
All Samsung Galaxy's are not alike for it's menu settings.. but you can try:
for S4 and up:
Settings>hold down on WiFi settings for a second then let go > un-check box at top for "Smart Network Switch"
for other Samsung Smartphones see the attached video below:
If your device is having issues trying to scan for your router.. try turning off your router for 2 minutes, then turn it back on.. make sure you wait a few minutes for your router to properly boot back up before you try scanning for your WiFi network again
Jan 31, 2016 | Samsung Galaxy S 4G Cell Phone
Proform xp 70 stationary bike console is not getting power
IF BATTERIES ARE NEW THEN CHECK THE CABLE AND CONNECTION FROM BATTERIES TO THE CONSOLE.MAKE SURE ALL CONNECTION ARE TIGHT AND CABLES ARE NOT BROKEN,FRAYED,CRACKED,OR CORRODED LOOKING.ALSO MAKE SURE SAFETY DEVICES(KEYS,PINS,CLIPS) ARE IN PLACE .
Oct 13, 2012 | ProForm 70 Perspective Treadmill
Where is the filter in washing machine
Start by turning off the hot and cold water faucets that are connected to your washing machine. This will stop water from running into your washer so you can disconnect your water inlets without flooding the house! To relieve any built-up water pressure, pull the knob out on your washer that starts the washing cycle for just a few seconds. Now it's time to unplug and disconnect your washing machine. First, unplug your washer from the electrical outlet. Next, use a pair of pliers to unscrew the hose fittings on the back of the washing machine. There will likely be some water left in the hoses, so you will want to have a hose or a bucket handy in order to catch and clean up any spillage. Now it's time to break out the water-resistant vacuum. Place the vacuum over each water inlet. As you turn on the vacuum, tap on the inlet a little with a plier in order to free any debris or sediment that may have lodged in it. Continue vacuuming until the inlet is clear, then repeat on the second water inlet. Now that you're done clearing out the filters, it's time to reconnect your washer. Using your pliers, reconnect the correct hose to its inlet and make sure to tighten them properly. Don't forget to double-check to see if there are any leaks. If you find any, re-tighten accordingly. After that, all you have to do is plug your washer back into the outlet and you're ready to go. You've successful cleaned out your washing machine filter!
Aug 05, 2012 | Hotpoint Aquarius WF000 Front Load Washer
My smooth 5.25 will run about 10 minutes and then stop. If left alone, it repeatedly tries to restart with a clunking sound.
Double check that all connections are secure, especially the console cable. Unplug and reconnect the console cable to verify.
Make sure the console cable is not pinched or damaged in any way.
Turn the power off, unplug the power cable and wait 60 seconds. Remove the motor cover. Wait until all red LED lights have gone off on the motor control board before proceeding. Next, verify that none of the wires connected to the lower board are loose or disconnected.
Refer to your treadmill owner's manual for information on common questions regarding sounds.
SINCERELY
Dec 09, 2011 | Exercise & Fitness
Motor is not responsive and it read LOW SPEED message and time L51
Oct 20, 2011 | RTO Sole F80 Treadmill
I have the Archos 101 internet tablet but have been having trouble connecting to the wifi recently, I try to connect to a secure connection (I have the password and it is correct as I did connect a few...
Hi there. I noticed that sometimes Android devices seem to have trouble connecting to certain access points or.they seem to stop connecting alltoghether to certain routers. Sometimes this method can help: Select the network you are trying to connect to and select "forget this network". Reboot the tablet and try to reconnect again. Sometimes this doesn't work on the first try. If that doesn't work I have heard of other fixes but they require "rooting" the tablet which could be potentiall dangerous. Another thing you can try if that doesn't work is change the security to a different encryption type. Your password will either be WEP or WPA. Whatever it is try to change it to the other. I cannot give you detailed instructions on this because I don't know your router model or its current settings. Hopefully this helps and leave a comment if you have further questions. Good luck!
Sep 09, 2011 | Archos 101 Tablet PC
No wireless con on my a60
Make sure wireless is on.
Make sure the network is visable or you have the hidden SSID.
Make a connection to the network using the correct encryption method (WPA, WEP, etc.) and correct password.
Make sure wireless access point is connected to the Internet or you will be limited to only accessing systems on the local network.
Jul 27, 2011 | Computers & Internet
Logitech Z5500 5.1 speaker system Hi, Any suggestions on how to troubleshoot this problem? there is no sound coming from the subwoofer or the speakers, but when I connect my mp3 player to the pod...
Try pulling the power from the unit for a few minutes, the reconnect. Make sure you've got the surround settings correct. If that doesn't do it, you've likely popped the amp or the amp's power supply in the sub box.
Jun 16, 2011 | Logitech Z-5500 Computer Speakers
Epic A30T Treadmill Logo
201 people viewed this question
Top Epic Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
L Pfaff
L Pfaff
Are you an Epic Exercise and Fitnes Expert? Answer questions, earn points and help others
