Question about Ricoh Aficio 180 Laser Printer
Please my rico africio 180 is given the above problem. kindly help me in correcting the problem
Replace the transfer roller .
Posted on Mar 03, 2009
  • dittocopiers Mar 03, 2009
    power pack B/C/T defective
    transfer unit set incorrectly
    poor connection with the all in one drum unit
    replace the transfer unit
Fuctional problems sc402. ricoh aficio 150
SC402: Transfer roller leak error 2
A transfer roller current leak signal is detected.
The current feedback signal for the transfer roller is not detected.
- Possible causes -
  • · High voltage supply board defective
  • · Poor connection of the PCU
  • · Transfer/separation unit set incorrectly
  • · Transfer roller damaged
Jan 26, 2011 | Ricoh Aficio 150 Copier
How to elminated sc402
some times transfer unit current didn't receipted charge properly there is two springs charge transfer unit if one of both out of position may causes sc402
on Apr 23, 2011 | Office Equipment & Supplies
Functional problem SC402
sc 402 is the transfer roller error. please clean the transfer roller. transfer roller fits on the side cover. some machines have transfer belt.
Dec 01, 2010 | Ricoh Office Equipment & Supplies
Error Code SC402 in Ricoh Aficio 270
transfer roller negative current error
Jun 25, 2010 | Ricoh Aficio 180 Laser Printer
Zebra TLP 2824 Labels printing upside down.....How do we correct?
Change orientation in the printer driver.
Open printer & Faxes folder, Double click on printer driver icon,
Zdesigner driver, click on properties, click printing preferences, tick the box "rotate 180%" Click apply & ok.
If driver is Zebra TLP2824, same as above, but hit the + on "Paper output" and turn "rorate 180%" on, then click apply.
Nov 16, 2009 | Zebra TLP 2824 Printer
HELP ME PLEASE!!! marc:fix/us/eng/index01.html after GH5 update!!
reffer to your manual every error is listed in that book and can be solved looking at the instructions given in that book, however if you get a ERROR-V3A call Nintendo
Sep 17, 2009 | Nintendo Wii Console
Transfer roller open error.
Transfer connector cable defective
Transfer connector defective
Poor PCU connection.
High voltage supply board defective.
Aug 05, 2009 | Ricoh Aficio 180 Laser Printer
Resetting timing on 1.4l 8v "R" Honda Civic
The white mark is the one indicating TDC. The red one indicates 12 degfrees befor TDC. If you don't have the belt on as yet, then the mark you are looking for will be on the crankshaft sprocket that the timing belt rides on. You line up that mark with the arrow on the block. This arrow is located directly above the crank sprocket.
May 19, 2008 | 1997 Honda Civic
Fault code SC402
A current leak signal for the transfer
roller is detected.
A current feedback signal for the
• High voltage supply board defective
• Poor connection of the PCU
• Transfer/separation unit set
• Transfer roller damaged
The above is what SC402 means the most common thing is that someone tried to change the toner and pull out the drum unit a little way.
OPen right hand door open front door lift green toner handle press green button and pull toner unit out press the green button further and keep pulling and then the toner unit will come out totally.
To the right of that is the drum unit pinch the unlock and pull out then push all the way back in. Reinstall the toner unit close all covers and turn machine on.
Hopefully this will work if not there is going to be a problem with the other possibilities listed above
Thanks J
Nov 19, 2007 | Ricoh Aficio 180 Laser Printer
Ricoh Aficio 180 Laser Printer Logo
391 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
