Question about Fetco International CBS-2052
Fetco coffee brewer CBS- 2052 error 102 unwanted fill
I just replaced one of the spray heads on our Fetco CBS-2052 coffee brewer and it now has a 102 unwanted fill error and low temp error. I checked the system for leaks but I can't see any. Any help would be appreciated. Thank you.
    New Friend:
    Problem Solver:
  • 10 Answers
Probably the filling valve allows water when is in a close position.
Posted on Oct 31, 2013
4 Suggested Answers
  • 92 Answers
SOURCE: fetco cbs-51h coffee maker not heating hot enough.
It can be the Temperature sensing probe, heating element or a loose/burned wire connection.
Adjusting the brew temperature is not going to help
Posted on Jan 18, 2011
SOURCE: Fetco CBS-31Aap over brewing
It's possible that your airpots are too small. We have the same machine and 3.0 litre airpots and it's perfect. But I can't find the right filters for it! I'm currently using a bunn filter and MOST of the time I end up with a lot of grounds in my coffee.
Posted on Nov 01, 2008
  • 91 Answers
SOURCE: Fetco model # CBS-31Aap the water is spraying
Inlet valve leaking.Either replace or rebuild.
Posted on Feb 09, 2011
How do i find a manual for Fetco CBS-12h coffee maker?
Here is a link for the coffee maker. Just follow to the website and enter your manual, etc. Fetco CBS 12H Manuals
Feb 02, 2015 | Coffee Makers & Espresso Machines
Fetco cbs 51h drips water
Replace the brew solenoid on top of the sprayhead. Either something is keeping the spring and gasket open or the gasket is damaged. Get a rebuild kit from fetco or a new brew solenoid.
Oct 02, 2013 | Fetco International Coffee Makers &...
When I press down on the hot water tap, no water comes out. What should I do?
Inside the faucet is a rubber membrane and this has become detached from the handle. You can order a replacement faucet from the Fetco agent in your area. Swapping it out a simple process requiring only basic hand tools.
Turn the machine off and remove the left side panel. Behind the side panel you should find a clear silicone pipe. Remove the bung in the end and drain water into a bucket or drain. Once level is low enough, you will be able to remove existing faucet and replace with new one. Reassemble, turn on machine and allow to fill and heat.
Sep 21, 2013 | Fetco International CBS-51H-10 Coffee...
Computer read out stuck on full
Assuming this is the readout on the server and not the LCD of teh brewer.
Clean out the servers with detan tablets following manufacturers instructions. Rinse and dry. If display remains unaffected and reads full then the sensor is likely faulty and this means a replacement section.
Jun 04, 2013 | Fetco International LUXUS® 5000 CBS-52H-15...
Water keeps running will not shut off
Where is the water running out of? Does it come from underneath, the top near the spray head, the sprayhead itself or somewhere else?
Sep 10, 2012 | Fetco International CBS-31AAP
Cbs 2031 will randomly push 2 0nces to 30 ouncec of water out overflow next to spray head
The bypass valve is letting by and needs to be replaced. You should be able to get one from your local agent and swapping it out is a simple enough task requirring only basic hand tools and some PTFE tape.
Access to the valve is via the top cover and the valve is located logically close to where the water is leaking, just follow the pipes.
Jun 23, 2012 | Fetco International CBS-2031
We have a the twin 1.5 tanks and can run a full tank of coffee but cannot get the 1/2 or 1/4 pot buttons to work
RTFM...for real. Turn power off, under unit, when machine powers on, press and hold the stop button on the left brewer. When it then reaches prgram cycle, you need the manual to refer to. good luck.
Feb 03, 2010 | Fetco International CBS-2052
When I turned on the brewer the message er 100 lit up. it says its a filling problem of some sort. how do i fix this?
Check the inlet solenoid on the unit the screen may be clogged and not allowing water to flow or the solenoid is damaged and needs to be replaced. Also check the level probe that might be damaged as well.
Oct 07, 2009 | Fetco International LUXUS® 5000 CBS-52H-15...
Jun 18, 2008 | Fetco International CBS-31AAP
Coffee Makers & Espresso Machines Logo
1,463 people viewed this question
Top Fetco International Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Fetco International Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
