Question about GE DBSR453EBWW Electric Dryer
Dryer stops when I release the start rotary switch knob.
To continue drying cycle I have to hold or tape the dryer start knob to the right.
  • 979 Answers
This sounds all right on the short term. But eventually it will go out. to replace the part is not that expensive or hard to replace.
Posted on Jan 25, 2009
How do you dry clothes in this machine please
A fairly common problem! The official instructions are
Before using your dryer, wipe the dryer drum with a damp cloth to
remove dust from storing and shipping.
1. Load clothes loosely into the dryer and close the door. Do not
pack the dryer. Allow space for clothes to tumble freely.
2. Turn the Cycle Control knob to the recommended cycle for the type of load being dried. Use the Energy Preferred Automatic Setting (,) to dry most heavyweight and medium weight loads. See "Drying, Cycle, and Temperature Tips."
3. Select a temperature setting on models with a Temp/Fabric selector. The cycle descriptions include temperature setting suggestions.
4. Push the START button.
Stopping and Restarting
You can stop your dryer any time during a cycle.
To stop your dryer
Open the dryer door or turn the Cycle Control knob to OFE
NOTE: The Cycle Control knob should point to an Off area when
the dryer is not in use.
To restart your dryer
1. Close the door.
2. Select a new cycle and temperature (if desired).
3. Press START
Extracted from
http://www.manualslib.com/manual/511763/Whirlpool-Lte5243dq.html?page=10#manual
Nov 14, 2015 | Whirlpool AWZ410 Front Load Washer/Dryer
GE dryer starts but..... stops
What you describe is either a failed evenheat board or a failed motor relay.
Please post the complete model number from the machine and I can help you narrow it down. There should be a wiring diagram inside the console with voltage checks also.
Thanks/Mike
Nov 25, 2007 | Kenmore 63932 Electric Dryer
I have a Candy GOU218 when I push the start button it does start the dryer but as soon as I release my finger from the button it stops, It started doing it around a week ago so I had to push and hold
There are push to start circuits used for motors and then there are holding circuits that keep the unit running. This way the dryer stops if the circuit is open due to high temperature or end of the cycle. It seems as if the holding circuit (could be a rotary switch that stays closed while the dryer is running) or a holding circuit relay (stays closed until circuit is broken by the control) has failed.
Jan 09, 2014 | Candy Dryers
I have a ge dryer. Turn dryer on would not stay on when I released knob. Replaced the rotary start switch. Still does not work
Could be a bad motor or door switch. If it runs for awhile then shuts off it is a motor.
Sep 25, 2013 | Dryers
Dryer stops but the timer continues on
Fixed! The "push to start" button was stuck. Must have been some dust. I pushed the knob a few times and that's all it took. Works fine now.
Dec 12, 2009 | Kenmore Dryers
Gas dryer not maintaining heat. 70 Series Kenmore/Whirlpool 76722
Fuse is ok . Problem is the soils on the burner valve . If the dryer heats when started , the electricity goes thru the coils to open the valve . Once the coils get warm , 1 will open (short) until it cools back down . The coils can be replaced just by removing the front panel . Only 2 screws hold the coils in place . No turning off gas , dissasembling dryer .
Jul 14, 2009 | Whirlpool Dryers
My dryer makes a buzzing noise when I push the start button
My Hotpoint dryer is seven years old and did the exact same thing. When I got over the anger and the thought of spending 4 or 5 hundred dollars to replace it I started messing with it. I finally decided that since it buzzed when I tried to start it there was current there. The only other thing it could be was the drying cycle knob.
I held the start knob and let it buzz while I slowly turned the dryer cycle knob to the right. As I turned through each cycle it would hit "off" and the buzzing would stop and then resume as I moved past the "off " setting. On the third trip around the dryer "started" and has been working since. Maybe something got out of kilter. Apparently the problem was in the knob that controls the drying cycles.
Mar 24, 2009 | Hotpoint NVL333EY Electric Dryer
I would like to shut off buzzer in dryer please do not answer if there is a charge
If you are trying to shut off the buzzer because it sounds constantly, there is a problem with the dryer timer motor, and that is an entirely different problem.
However, if you are like me and find it really annoying and loud - and are trying to disable/remove it this is how to do so:
Tools: #2 Phillips head, 8-10" long
#2 Phillips head, 3" long
Optional but recommended: Vacuum cleaner with flex hose. (Unless your dryer is new or you maintain regularly, it is full of lint that is a potential fire hazard - this is a great opportunity to clean it out)
Optional but recommended: Duct tape, the metallic sealing kind, not the elastic adhesive tape
Steps:
1. REMOVE THE POWER PLUG FROM THE WALL. TURN THE DRYER CONTROL TO TIMED DRY AND TURN THE START KNOB TO ENSURE THE POWER IS OFF (IF THE DRYER STARTS, YOU PULLED THE WRONG PLUG - TRY AGAIN)
Note 1: As you start removing panels, it would be a good idea to clean as you go, otherwise you will have a big dusty mess...
Note 2: As you remove the panels either screw the screws back in to where to took them out of, or screw them into the holes of the panels you are removing, they can get mixed up or forgotten easily...
2. Remove the 2 screws that hold the cover from the underside of the dryer tumbler (above the lid for the washing machine)
3. Remove the 7 screws for the tin sheet that covers the blower/tumbler motor
4. Remove the 2 screws for the front control panel with all the knobs for the washer/dryer
5. The panel can be lowered out slots on each end by applying some pressure inwards, then down. Mine was a little more difficult to remove because of all the lint/**** built up so I used a screw driver for a little prying action. If you try this, pry on a side the that is not exposed in case you cause any dents, scratches, etc... for aesthetic reasons.
6. Once you have the panel down, vacuum this area very well, there are exposed contacts and terminals here that will be a source of ignition if a contactor goes bad and there is a lot of lint build up.
7. On the left side where the dryer controls are, there is is a little black rentangular box with two wires going into it - mine was between the dryer cycle knob and the start knob. It is the only component on the backside of the panel that will not have a corresponding knob on the front of the panel. Remove the screw that is holding it in place, and pull it up at an angle to clear a metal clip that holds it in on the side opposite the screw.
8. Once you have the buzzer free, follow each wire from the buzzer to its termination point on the dryer cycle controller. The buzzer should have black a wire going to the "common terminals" labeled either B or C, the other black wire is for the switch terminal of the dryer cycle controller. There should be "female" connectors on the wires from the buzzer, connected to the "male" terminals of the dryer cycle controller.
9. Remove these female connectors, which will disconnect the buzzer from the dryer. Be sure that you do not accidentally pull off an incorrect wire - and if you do, make sure to reconnect it before removing any other wires to avoid confusion as to what goes where.
At this point, get a flash light and take a look around the inner dryer housing. With your vacuum - if you have a brush attachment, use it - clean out all the built up lint from everything you can reach, especially around electrical connections, wires, the dryer motor windings, etc... Take your time, do it right - you spent the time taking the thing apart, it will not kill you (and actually may save your life) to spend 15 minutes cleaning the inside of your dryer.
If you have some duct tape, tape the blower exhaust connections from the plastic blower housing to the metallic duct and the flexible duct. I also taped the plastic piece that the lint screen inside the dryer door sits in because the foam rubber stripping had come apart. There areas are the main places that lint escapes into the inner parts of your dryer.
10. When you are done cleaning, reassemble the dryer in the reverse order you took it apart in.
11. Once reassembled, plug the unit back into the wall.
12. Turn the dryer control knob to as close to the end of a cycle as you can, turn the start knob to start the dryer. If the dryer starts, then stops at the end of the cycle without a buzzer - you were successful.
Dec 22, 2008 | Frigidaire FEX831CS Top Load Stacked...
Whirl pool dryer LEC9000PW0 will not turn on
Has a household fuse blown or has a circuit breaker tripped?
There may be 2 household fuses or circuit breakers for the dryer. Make sure both fuses are intact and tight, or that both circuit breakers have not tripped. Replace the fuse(s) or reset the circuit breaker(s). If the problem continues, call an electrician.
Is the correct power supply available? (Electric dryers only)
Electric dryers require 240-volt power supply. Check with a qualified electrician.
Is the dryer door firmly closed?
Your dryer door may not be fully closed. It may look shut, but may not be latched. Push on the door to engage the latch or latches. Some models have an upper and lower latch. Both latches must be secure for the dryer to run.
Was the Start, Push to Start or Hold to Start button firmly pressed?
Large loads may require the Start, Push to Start, or Hold to Start button to be pressed and held for two to five seconds.
Is the Cycle Control knob set on a Sensor Dry or Timed Dry cycle? (on some models)
The Cycle Control knob must be set in a Automatic Dry or AccudryTM or Timed Dry cycle. The dryer will not start if set on the Wrinkle ShieldTM option.
Is Controls Locked status light on? (on some models)
Press and hold the Cycle Signal button for three seconds. This will turn off the Controls Locked feature.
Did you recently install a power supply cord on the dryer? (Electric dryers only)
The power supply cord may be incorrectly installed. If the power cord is incorrectly installed, the dryer may not start or heat. Review the Installation Instructions to check that the power supply cord is properly installed.
Dec 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dryer only starts sporadically
your headed in the right direction. there are contacts inside the timer that have gone bad. the timer is in the console ofcourse. its not hard to replace and replacing it will solve your problem
Nov 25, 2007 | Whirlpool LEB6300 Electric Dryer
GE DBSR453EBWW Electric Dryer Logo
108 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
