Question about Sport & Outdoor - Others
How far apart should the pedals be in a starter block to maximize their effectiveness?
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 63 Answers
So that the starter blocks are effective and to ensure that you have them in the correct position you should please the two pedals about your shin length apart.
Posted on Jan 14, 2013
Can you show me where the starter is on a 1985 xj700 yamaha maxim?
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
1985 Yamaha XJ 700 Maxim starter location Google Search
http://www.beginnerbikers.org/showthread.php?32987-Remove-Starter
Yamaha XJ700N Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-xj-owners-manuals
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jun 12, 2014 | 1985 Yamaha XJ 700 X Maxim
Starter noise or starting noise
Most probably just a bad meshing of the starter and the gearbox drive. If the starter doesn't throw the gear out far enough you will get a grinding sound. This will mean it has to work harder to turn the engine over , so causing the battery to drain more and the engine to take longer to start.
Apr 21, 2013 | 1985 Yamaha XJ 700 X Maxim
Do i have too split my case on my 85 xj 700 maxim too replace starter clutch ?
Hi, Dave absolutely not for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
82 650 Maxim starter clutch
Starter Clutch Removal avi
May 18, 2012 | ATVs
My 2003 acura rsx only start when i push it,whats the problem
It sounds like the Neutral safety switch on the clutch pedal or a starter problem. Try pushing the clutch pedal REAL FAR DOWN while starting. If it works have the switch adjusted.
If that isn't the problem try a jump start. If that doesn't work, a starter may be be needed. Try tapping on the starter with a wrench then start.
Sep 19, 2010 | 2002 Acura RSX
Have a 95 chev s10 with 2.2 and standard trans. intermiten won't start when it dosen't start I can hear the starter spining but it dosent engage with the motor,already replaced starter and selenoid and...
Was the starter shimmied to match up with the fly wheel properly so the starter gear fly wheel ring gear don't bind or out to far apart that they don't reach each other. The other problem is that if the starter gear was to far apart, it may have shaved the teeth on the starter gear causing your engine not to turn.
Feb 25, 2010 | 1995 Chevrolet S-10 CA Edition
1985 Yamaha Maxim. starter is going out. How do
First you want to disconnect the positive cable to the starter, than unscrew the 2 bolts holding the starter to the motor, pull them up as far as you can and you will be able to pull the starter out.
Aug 11, 2009 | 1985 Yamaha XJ 700 X Maxim
I don't understand my wiring diagram.How does the positive and negative cables hook up to the starter relay and to the battery.I have one small red wire coming from my wiring harness does this wire connect...
Hi and welcome to FixYa,
If the starter relay in your version uses blue / white and red / white wires, then to my understanding, connection would be:
  • blue / white - goes to the start switch and is supplied with +12 on starting;
  • red / white - goes to the starter circuit cut-out relay. This cut-out relay controls whether the starting relay gets a ground based on neutral/gear and clutch lever conditions.
Good luck and thank you for asking FixYa.
Jul 08, 2009 | 1985 Yamaha XJ 700 X Maxim
Sonic maximizer
To use the maximizer as a send effect, connect the effect send (1 or 2) to the input on your maximizer, then connect the output from your maximizer back into any input A thru G on your 2488. You then assign the track you want to maximize to the correct send (1 or 2) using the send key and then assign the input to a track to record to.
To use a maximizer as an input effect (assuming guitar) simply plug yoiur guitar into the maximizer and then patch the maximizer to input H (Hi Z input of the front panel of the 2488). Assign input H to a track to record and this will record the maximized input signal.
Jan 03, 2008 | Tascam 2488 Portastudio Multitrack...
Sport & Outdoor - Others Logo
760 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
