Question about Sport & Outdoor - Others
Are track spikes the same as cleats? - Sport & Outdoor - Others
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 63 Answers
Track spike are similar to cleats and serve a similar purpose however spikes tent to be smaller and have a pointy edge.
Posted on Jan 14, 2013
What is the difference between rugby boots and soccer cleats?
My rugby boots are heavier and sturdier than my soccer cleats. Depending on the position you play, some of the boots go higher up the ankle instead of soccer cleats that cut off just below it. Also, rugby boots have around 10 studs whereas soccer cleats have about 16, give or take.
Feb 06, 2013 | Rugby
What is the benefit of metal cleats as opposed to plastic ones?
Plastic cleats have the spikes permanently molded into
them. The spikes on metal cleats can be
screwed in or out. Therefore, if you have the option of changing the size or removing them when they get worn in.
Feb 06, 2013 | Baseball & Softball
Can changing from running shoes to running shoes with track spikes damage my legs or feet?
Changing from running in regular workout shoes to track spikes can cause Achilles tendon problems. Your Achilles tendon, sometimes called the calcaneal tendon, connects your calf muscles to your heel bone. A slow onset of pain that increases with exertion is likely to be tendonitis, whereas a sudden pain may be a partial or complete Achilles' tendon rupture. Achilles' tendons injuries are slow to heel and, in the case of ruptures, can even require surgery.
Source: http://www.livestrong.com/article/356226-track-spikes-sports-injuries/
Jan 17, 2013 | Sport & Outdoor - Others
How to remove the track spikes on my running shoes?
Place the spike key over the top of the spike, ensuring that you secure it around the base. Hold the shoe firmly and slowly turn the key to the left to loosen and remove the spike. One you get the spike turning, it should come out easily.
Can I use my track spikes to train on hard surfaces such as cement?
It is not advised to use your track spikes on hard surfaces for a number of reasons, firstly it will ruin them, a hard surface will wear down the spikes, secondly the spikes do not support the foot so it could cause problems with the foot area also the spikes would not penetrate the surface which could make it very slippery - do not use your track spikes on a hard surface.
What are track spikes made from?
Track spikes can be made from ceramic, metal and plastic and they are screwed into the bottom of the training shoes.
Jan 14, 2013 | Sport & Outdoor - Others
Need to find replacement for broken belt/track.
Belts for cleated tracks are no longer available from arctic cat. You will have to find a used belt on EBAY, at a salvage yard, or upgrade to a rubber track. An Arctic dealer can look up pieces needed to upgrade to rubber track from the old accessory parts listing to do the upgrade. You will need to replace your drive sprockets and possibly the drive axle to run a rubber track with out cleats.
Oct 24, 2010 | Interactive Toy Concepts Crossfire Arctic...
What is the correct way to place the nails into the gun? This gun uses both cleats and staples. I am using cleats but it does not seem to be working. I may be putting the cleats in wrong.
If you have a Bostitch MIII FN it is only for cleats. Bostitch doesn't make a universal nailer that takes staples and cleats. The MIIIFN is the "floor nailer" and the Model MIIIFS is the "floor stapler"
Maybe check exactly what model you have and ensure you are not trying to put cleats into a stapler.
Oct 17, 2010 | Stanley Bostitch MIIIFN Flooring Nailers
I have a central pheumatic stapler model 99640. When I used it, it shot out 2 'L' shape cleat (16G, 2") at the same time instead of 1 cleat. I tried to minimize the gap for the mouth, it end up jamed....
I have noticed that some nailers with this problem have a driver blade that is slightly wider than the width of the cleat thus allowing the driver to actually hit part of the second cleat in the strip. To fix problem the driver blade should be slightly trimmed or tapered. File/grind the driver only on the side facing the cleats. Remove only enough metal to allow driver to hit only one cleat. Taper the grind up about 1/2 inch. This tapering is used on many different drivers including fraiming nailers to prevent the driver from hitting second nail on strip (mainly clip head nails). Only other remedy is to find thicker guage cleats that will still fit thru nose. Good luck with your repair
Oct 08, 2010 | Craftsman Air Tools & Compressors
Can't fit the cleats to MO76 shoes. Instruction
assuming your using Shimano pedal cleats?
You should have on the bottom of the shoe 4 threaded holes showing.
(if not then you will need to check the shoe box as sometimes they need to be fitted)
The cleat should be placed directly on top of this... with the point facing towards the front of the shoe.
You then need to place the OO plate on top of the cleat and place the crews in making sure the cleat is positioned straight.
Once tightened then place the cleat on the pedal and make sure its position is correct and your shoe is sitting straight then re-tighten.
hope this helps.
p.s. try here http://drivemybike.wordpress.com/2009/05/23/understanding-clipless-pedals-installing-cleats-on-shoes/
Feb 26, 2010 | Shimano Cycling
Sport & Outdoor - Others Logo
366 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
