Question about Baseball & Softball
Why did the guy at the store tell me not to use my new bat at the batting cages?
    Guru:
  • 269 Answers
It's not a good idea to use a new, quality baseball bat at a batting cage because the balls that come out of the machine are much denser than regular baseballs. This could end up doing irreversible damage to your baseball bat.
Posted on Jan 14, 2013
New battery not charging after changing the alternator
First make sure both battery cables are free of corrosion and ground is secured to chassis and engine then check to see if theres an alt. fuse or bat. fuse blown. Another way to test charging sys w\out an meter is to remove the ground terminal from the bat. with the car running, if the alt. is good car stays running, if all else fails take the alt and bat to a parts store that will test them for free
Dec 14, 2013 | Chevrolet Venture Cars & Trucks
The computer clock and date always show the wrong time when I first turn on the PC. I correct it but next time I turn on it is wrong again. I am told that I need a new CMOS battery for my Packard Bell BL...
The MCOS bat is inside the tower.Just screw off the side plate and look for a watch like bat and take it with you to any watch or bat store.Go to http://www.google.com.pr/search?q=cmos+battery&hl=en&client=firefox-a&hs=sC6&rls=org.mozilla:en-US:official&prmd=imvnsr&tbm=isch&tbo=u&source=univ&sa=X&ei=7bZ9TomvGNCSgQfz54lM&ved=0CEMQsAQ&biw=1440&bih=750 to see some samples.
Sep 24, 2011 | Computers & Internet
Alert! system battery voltage is low
Hello there and welcome to fixya
This is a very common issue with these desktop units the cmos battery will only last from 2 t0 5 years depending on how it is used.
This battery sits on the motherboard so you will want to first unplug the computer then remove the outer cover to expose the internal parts then look for a coin sized silver battery that looks like a watch battery then replace the battery with a new one
radio shack has these then power up the computer and you will have to reset the time and date ok you will get a error about this. here is what the battery looks like
Aug 16, 2011 | Dell Dimension C521 PC Desktop
Problem is not charging
First you guys need to know that the HTC does not charge if the ROM is inconplete/damaged .
And.....
If your battery is really dead there is no initial power on the internal battery to manage the chargement.
So ... resolution.
Fist way .
If you know any one that may have an other HTC Diamond you need to swamp batteries so the good Diamond that has the internal bat ok and charge it there.
Second way . this one i did it my self .
Go to a Local ChinaMan store and buy a multimeter and a regular Universal Adapter.
Heres how it hoes ...
Use the Multimeter do figure out the polarity pin's on the battery ex: + and - .
remove / cut one of the plug's from the Universal transformer and also tag the polarity.
set the voltage to be close to 5 V - 1 Amp .
Conect the cuted wire from the Univ. Adapter to the Diamond Battery respecting the polarity.
Leave it for a wile..... ( Probably up to 1 hour but chec from time to time tme battery temperature and if possible a reading on the bat voltage levels.)
Done!
Put the battery bat and boot your diamond or turn on to boot loader.
**** Attention if you don't have more than 50% of the bat charge compleated you wont be able to flash your phone****
Jan 14, 2011 | HTC Touch Cell Phone (Unlocked) - Soft...
I have a protax dv6 camcorder, it takes a li-ion qlr0509 bat. i need a bat and charger?. Can you help. Thank you
I ordered a new battery from Deals Only Web Store. I believe they also carry chargers for 12.00
Jun 09, 2010 | Konaki DV6 PLUS Digital Camera
Kodak m863 camera not charging
try buying a new baterie
mine did same and it was the baterie
just take it to the local cam store and have them try a bat in the cam and try and charge it while there if it works buy the bat if not start looking at the charger
Aug 03, 2009 | Kodak EasyShare M863 Digital Camera
Easton synergy softball bat
clean the end of bat get some j b weld at a hardware store mix it up ,put on cap evenly put cap back on bat let it sit for 24 hrs.
Jul 28, 2009 | Easton Synergy Cnt Softball Bat
1988 olds regancy new bat keep charging. won't hold charge. think somthing draining bat.could it be a short?
sounds more like the alternator isn't working. there should be a local auto parts store that will check the charging system or if you had the battery installed they should be able to check it. good luck!
Feb 24, 2009 | 1992 Buick Park Avenue
Baseball & Softball Logo
669 people viewed this question
Top Baseball & Softball Experts
Ned Halaweh
Ned Halaweh
Are you a Baseball and Softball Expert? Answer questions, earn points and help others
