Question about Orion Car Audio & Video
Sx 2150 one day it stop working this amp. is 17 years old help me
I was listening to radio and it just quit working. It's not a short because I also have another orion amp which is taking the place of the orion amp that stop working.
  • 1 more comment
  • castillorobe Jan 23, 2009
    I wish I can but that is what happen. I need you to tell me where to send the amp to get it fixed, in fort worth tx.
    Thank you, for your help. one more question are the orion amp"s of today, like my old 17 yrs. amp in power .
  • Roberta Smith
    Roberta Smith May 11, 2010
    could be a blown component inside the amp
    Brigadier General:
  • 5,158 Answers
Here is the contact details for the company...
For Technical Support: sx 2150 one day it stop working this amp. is 17 ye - dotted_line.gif Phone: (800) 876-0800 x 2032 Fax: (760) 599-1380 E-mail:
Posted on Jan 23, 2009
  • Roberta Smith
    Roberta Smith Jan 23, 2009
    the old ones would put more of a strain on your battery i would think... but would/should be easier to repair.
    Please rate the solution as well please... does sound like a fixya
    take care
Zanussi ZWF 1020W front loading washing machine - filling o.k., draining o.k. but drum will not rotate & machine will not spin - any help gratefully received
Hi from retired Englishman in SW France @ 21:17 Sat evening,
I presume that you could turn the drum by hand? Also how old/used is it, please?
Can you hear a sound as if the motor is turning? If you can it could be that the belt has broken/come off. If you cannot hear it it could be that the motor is not working.
have the back removed so that the belt (and motor) can then be seen easily.
If belt is OK then it is likely to be the motor especially if the machine is quite a few years old and well used. Often the motor brushes wear down to the extent that they do not run on the commutator and the motor stops- or, as in our case just before Xmas, becomes intermittent. Although it is possible to go the least costly way and have the brushes changed, it is false economy in the long run. The new brushes will not bed in correctly and will only last a fairly short time (I've heard of 1 month!). A replacement motor (ours cost £250- and I replaced the belt at the same time- both were 15-20 years old) should last for many years.
I hope this assists,
John C
Jan 29, 2011 | Zanussi FJD1666W Front Load Washer
Hello, my BC246T scanner has no sound, but it stops on different frequencies. I took the back off and try , checking the circuit boads, but did not solve sound problem. Is there anything else I can try. I...
Sorry, but the only mute function is in the external speaker and headphone jacks. Plugging into either one will mute/disconnect the internal speaker. Your scanner is about six years old, so it's possible that the speaker has quit working or that you have a problem with the audio amp. Try connecting either headphones or an external speaker to the appropriate jack. If you get audio through either one then chances are that you internal speaker is shot. No audio at all indicates a circuit problem that needs professional help. You local Radio Shack store can help with either problem. If they don't have the proper speaker in stock they can order one for you, and they can also arrange quality repair of your scanner. CAUTION: If you go the repair route, be sure to get a firm price, not just an estimate before you commit. Repairs can approach or exceed the cost of a comparable new scanner. Good luck and happy scanning.
Bill B
Listening in since the 60's
Oct 05, 2010 | Uniden BC246T Handheld Scanner
My 4 year old YB P 2000 suddenly quit broadcasting AM. I took the radio apart and cleaned everything. Now only some FM stations and no SW reception. Can you help?
Look at the front case and locate reset hole. Insert cocktale stick or similar and listen for slight click. Insert new batteries, ensuring correct polarity and that there has been no leakage from old batteries on terminals. If leakage ie green/ uneven appearance, try to scrape clean with suitable implement when disconnected from mains only.
Feb 10, 2010 | Grundig Yacht Boy P2000 AM/FM/SW Radio
03 325xi radio stopped working
good day, it maybe a bad electrical problem. you may try to check on the fuses and replace it if busted. hope this helps, have a nice day
Feb 10, 2010 | 2003 BMW 325
Wipers and radio quit
The relay is over heating and internally shorting out.
Replace the relay.
Feb 01, 2009 | 1995 Chevrolet S-10 CA Edition
Radio doesn't work!
Assuming that the radio fuse is not blown, you have an internal problem in the radio. Is the car under 36,000 miles? If so, the radio is still under warranty. Your dealer will replace it with a new one free of charge if it is not 3 years old or less than 36 K miles
Sep 18, 2008 | 2006 Scion xB
GE-1000SX stands for Gigabit short haul Multi-Mode fiber That's the SX part. This is a full duplex MMF (multi-Mode Fiber) short haul (SX) connection. It can only connect to another MMF SX enabled device. This is generally used as an uplink between switches or for a high speed connection to a server.
In short if the GE-1000SX duplex pair isn't attached to a similar interface at the other end there will be no connectivity. If you're trying to connect 100FX (100 Mb Fiber) it won't work.
Hope this helps.
Feb 04, 2008 | Enterasys Network adapter
1990 Lexus LS400 Nakamichi Car Stero Amp problems
if the amp is damage it needs to be repaired or replace but the age of any amp doesn't matter, all are compatible to work.
Jun 18, 2007 | Nakamichi PA-2002 Car Audio Amplifier
No bass at higher volume
Your battery should be fine! Although the amp might not be strong enough for the sub. All you can do is check the RCA cables from your radio to your amp as these might vibrate loose when you get to 17 volume and also check the monster cable from your amp to your sub asit might have vibrated loose as well.
Oct 21, 2006 | Pioneer GM-5200T Car Audio Amplifier
Car Audio & Video Logo
139 people viewed this question
Top Orion Car Audio & Video Experts
Tygh Duval
Tygh Duval
Steve Sweetleaf
Steve Sweetleaf
Are you an Orion Car Audio and Video Expert? Answer questions, earn points and help others
