Question about Rock & Ice Climbing
What size line is the Spider Jack 2.1 used on?
    Guru:
  • 269 Answers
It can be used with ropes between 11 mm and 13 mms.
Posted on Jan 14, 2013
My spider III amp has no sound.. lights on but no sound
No, probably NOT a fuse issue here (still lights up, etc.). Are you using the foot-pedal accessory? If so, then unplug it and go direct into amp. Try some headphone via the output jack (sound?) Yes -> GOOD. NO? -> Not so good. May require servicing. Also, check the guitar cord you're using. While unlikely, somehow it might have gotten damaged. Good luck!
Jan 10, 2013 | Line 6 Spider Iii 30
Line 6 Spider IV 30 I have the above amp and there seems to be a short when the guitar input jack makes contact with the chassis. There's a copper contact pad on the sub board that the jack is mounted...
Typical guitar input on a schematic for line 6 shows an inductor between the input jack sleeve connection and the "earth" or safety ground.
I do NOT understand how you could fry one of the voltage regulators via the guitar cable unless you have more than a guitar (other devices) connected to the jack.
ALWAYS power any interconnected audio equipment from the same receptacle or power source to avoid ground bounce/fault damage to equipment.
Jan 08, 2011 | Line 6 Line6 Spider IV 30
The hexagon nut came loose for the Guitar -CD/MP3 input from my son's Spider 3 (75) amplifyer. Where can I find a hexagon nut?
Those can be a pain to find. Some are Metric which worsens the problem. There are several types as well. I would first try Radio Shack where they have the drawers of jacks, etc. Those ore probably English thread...
The BEST source would be to search the DIGIKEY.com website for a jack that has the identical nut... the jacks are NOT expensive... under $2. Finding just the nut alone unless a repair shop for amps happens to have one laying around will be near impossible. It is worth trying that source however because USUALLY the jack inside is broken.
Dec 06, 2010 | Line 6 Spider Iii 75 Guitar Combo...
What causes your line 6 spider amp to turn on and off while using
This MAY be due to overdriving the amp. The single chip amplifiers used in these have thermal protection usually and will cycle on and off if you drive it too hard. This is a tiny amp and is for use as practice and is NOT suitable for heavy use. Most of these use chips like the TDA 2050 and MANY of them have VERY substandard heatsinks and often don't even use thermal conductive grease under the chip.
If you want loud, then you need to step up the size of amp you are using to say a 100 Watt one that is designed to take the power.
May 19, 2010 | Line 6 Spider Iii 15 Modeling Guitar...
My line 6 spider iii30 30 watt amp works with
There is likely a switch contact on the headphone jack that routes the amp output to the speaker. These jacks on most music stuff are JUNK and the contact may not be closing.
If the spring contact is bent so it won't close you can bend it to contact BUT the springyness usually is gone and the contact will be marginal.
May 10, 2010 | Line 6 Spider Iii 30
What is 2 sided stereo jack?
A 2 sided jack is a connector with different sized pins on both ends to connect two different sized socket ended cables. Like if you want to connect a 2.5 mm socket to a 3.5 mm socket then you use a 2 sided jack that would have a 2.5 mm pin on one side and a 3.5 mm pin on the other side. A stereo jack means that all the three connections from one side run parallel to the other side, as a stereo would have three lines running.
Nov 21, 2009 | ASUS K8V-MX Motherboard
Line 6 spider III 15 watt sound problems
Hi there. Sounds like the power amp IC is shorted. Must replace.
Paul
Jul 04, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
Line 6 Spider 2x12 100w combo - Input jack issue
Its a 1/4" mono Panel-Mount Audio Jack
and can be bought at
Radio Shack, Best Buy, Any Music Store
Click Here
Average price about $3.00
Mar 10, 2009 | Music
Rock & Ice Climbing Logo
895 people viewed this question
Top Rock & Ice Climbing Experts
Makenzie Floyd
Level 1 Expert
RatanbssBD
Level 1 Expert
Are you a Rock and Ice Climbing Expert? Answer questions, earn points and help others
