Question about Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator
The motor is making a sound - Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator
I have Hayward (A O Smith) 1.5 hp pool pump c48l2n134b3, was makeing loud noise, but today stopped working and is making sound like zzzzzzzzzzzzzzzz sound, but not pumping or working. Do i need a new...
sounds like a seized bearing. they can be replaced at your local motor shop or pool store. now that its buzzing, i would also suggest getting the start capacitor replaced at the same time.
Oct 05, 2013 | Hayward 1.5hp Pool Pump Motor Motor A O...
Pool motor makes a buzzing sound but doesn't work
sounds like it has a bad capictor .. look fr a otor shop in your area that tsts them , should be free test
May 30, 2010 | AO Smith Pool Pump Motor Hayward Swimming...
Doesn't agitate or spin but makes loud motor sound
check your motor coupling, it is between the motor and tranny
Feb 17, 2010 | Washing Machines
Wont turn on, makes click sound when you push the start button. The click sound is near the motor.
The clicking sound your hearing is in the gas valve and or ignitor that are located near your dryers motor. It sounds as if you have a problem with the motor or motor switch itself. This can be repaired but the repair most often requires the replacement of the motor itself.
Jan 09, 2010 | Kenmore 73952 Gas Dryer
The motor makes a weird sound and starts to heat and smell like something is burning
If the motor sounds scratchy and is making a burning smell, or sparking you will need to replace the motor or the entire vac. Carbon brushes will rarely fix this as it is a high RPM motor
Sep 04, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Lasko 5365 heater making growling sound.
sounds to me like you have a fan blade hitting something inside the unit, or the motor is going bad, thats the only moving parts to the unit unless it has a sweeping mode, moves from side to side, if it doesnt have that, then its your fan motor or blade, you probably need to replace the motor or the whole unit, as they are fairly inexspecive, but its your call, look inside the unit to see if anything is in there that might be making the noise as well, best of luck, hope that helped
Jan 19, 2009 | Lasko 5365 Ceramic Compact Heater
Brand new pump that i bought it from store and i installed myself but it makes a distinctiv noise. emerson 230 v 1 hp.
is it the water going through the wet end or is the motor making the funny sound?
If the motor is sounding funny then you may have a bad motor. if the wet end is sounding really noisy then the motor may not be matching the size of the wet end as far as the HP. make sense? if your motor is bigger than the rating on the wet end it is pushing way too much water it is will be very noisy.
Jan 02, 2009 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator Logo
13 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
