Question about InFocus ScreenPlay 4805 Multimedia Projector
SP4805 bulb does not fire up; led stays green; fan turned on
I have SP4805 bulb does not fire up after the beep sound; led always stays green; fan turns on. Replaced with another bulb. Same problem.
  • 93 Answers
There is a problem in the ballast.refre to service personnel
shyam
+919867355202
Posted on Feb 08, 2009
I had the same problem after purchasing a new bulb. My husband pulled it out after it would not fire up and the new bulb plug in conecter (white with 4 holes with two wires) was different. Take your old bulb and compair the two conecters and see if they match, then check if the wires are in the same slots as in first and last. Mine on the new one were in the first and second to last slot. So we took the wire out of the second to last and put it in the last slot and installed it and it fixed the problem. We also had to unplug and replug it in and do a master reset by pressing the Power and Channel buttons and the same time for 15sec. Hope this helps.
Posted on Jan 28, 2009
Projector cp-sx635 lamp indicator glows red (RED). intimate trouble shoot pl
sounds like the bulb will not fire up. most likely cause is the bulb needs replacing
Jan 03, 2013 | Hitachi CPSX635 4000 Lumens LCD Projector...
Projector will only stay on for a couple of minutes then shuts off automatically. the LED turns from green to red
Make sure the venting for the cooling fan is clear and that it is activating. The only time I have seen this in a projector is when it overheats. If it reaches a certain temperature and doesn't sense the cooling fan being on it shuts down to protect the bulb and protect against fire hazard.
Oct 28, 2010 | Toshiba TDP-T90 Multimedia Projector
Panasonic PT-50LC14 HDTV went caput and stopped working
Ur tv LED light indicator "LAMP"flashes?Then the projection bulb life is over must be change.This tv been watching the tv at least 4 or 5 hours a day,the last 3 years?The projection bulb only last about 1500 hours.
May 26, 2010 | Panasonic PT-50LC14 50" Rear Projection...
Unit will not turn on
did you turn it off or unplug it? not to sound too obvious, but make sure it's still plugged in properly and the switch is on. if the led is lit on the top, it's getting power, so it's not the fuse. if not, the fuse is located on the power supply board inside the projector. if the led is lit and the fans don't turn on, it still may be a power supply problem. if the fans go on and not the lamp, could be the lamp, ballast, or main board. if you need to send it in for repair, try av solutions in ny. they're really good. www.avsolutionsny.com
Dec 28, 2009 | InFocus ScreenPlay 4805 Multimedia...
Projector goes POP!
I think it's the bulb, the best would be to take it to the shop where you bought it - or any other good electronic goods shop - so they can test it. If its still under guarantee its better to take it to the dealer. Mine had to have the bulb replaced after only 8 months, but it was still under guarantee.
Jun 11, 2009 | InFocus ScreenPlay 4805 Multimedia...
Changed bulb and still no picture or sound
hello i think when you put a new bulb in you have reset the bulb counter good luck
shaun
May 30, 2009 | Toshiba TheaterWide 52HM84 52" Rear...
I have SP4805 bulb does not fire up "New"
push and hold both volume up and volume down for 10 seconds.
Mar 03, 2009 | InFocus ScreenPlay 4805 Multimedia...
Ya...Ok
Good Day, egear00;
Did you try the DMD board? Other wise I'm still looking for solution.
big IRISH.
Aug 21, 2008 | Hitachi 60V500 60" Rear Projection...
Fan does not operate
Make sure that nothing is obstructing the fan. Try to rotate the fan with your fingers to make sure it is free. If it is, you would be lucky if the fan is at fault because this is rather cheap and easy to find if not it is the main board which is at fault.
Dec 31, 2007 | InFocus ScreenPlay 4805 Multimedia...
Sony HS10 error lights
you could try a new lamp, some lamps fire, but do not stay on
Nov 09, 2007 | Sony VPL HS10 Multimedia Projector
InFocus ScreenPlay 4805 Multimedia Projector Logo
193 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
