Question about Dell OPTIPLEX GX110/200 PIII-866MHz 256MB 20GB (PCPIII866DELL) PC Desktop
I can't connect to internet, Im using globe tattoo broadband.
I have a load in my tattoo but I still can't connect with the internet. What will I do to solve my problem? Please help me.
  • Dell Master
  • 27,725 Answers
You will have to open up your network connections Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled. Make sure your antivirus program is not blocking the internet connection. If you are trying to connect through a modem/router you it should have come with a disk then you might have to connect the usb lead to your modem to get a connection then Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers. The driver might be on the disc supplied by your ISP internet service provider or the motherboard disc Click start type cmd press enter you will be in DOS mode type in ipconfig press enter you will see all o fyour internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138 Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its "Enabled"imake sure its enabledPci device arrows key scroll to nstalled. Hope this helps.
Posted on Jan 14, 2013
2 Suggested Answers
kevin000
  • 1847 Answers
SOURCE: NETWORK ADAPTER
Reinstall the network adapter from the dell driver cd and reboot the system with the nic pluged in.
Posted on Jul 21, 2008
Does anyone like full arm tribal tattoos or this one I have added in this question?
Well...I 'm a girl and i think tribal tattoos are really hot! i would love for my guy to get tribal tattoo designs for men, so I could trace the designs that are across his shoulders, neck, stomach or arm's... with my finger tips i don't really like tattoos but tribal tattoos have something over me. so yes i like full arm tribal tattoos as long as ya don't go over bored ;) I plan on getting a tribal tattoo on my lower back sometime this year.
Sep 07, 2012 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Tip
Tattoos - Do They Hurt?
Tattoos can be a wonderful way of expressing art on the body, but you should always make sure you use a reputable tattoist and follow some basic health and safety guidelines if you want it to be a positive experience.
  • Just like with any cosmetic surgery, you should make sure that you choose your tattoo studio carefuly. Once you have a tattoo done on your body, it's not something that can be easily removed so make your choices wisely.
  • Yes, tattoos can be very painful but it's not a pain that is unbearable and everyone reacts differently. Your attitude to pain and how relaxed you are feeling will greatly affect the outcome.
  • The skill of the artist definitely has some bearing on the amount of pain you'll feel. An experienced tattoo artist will know how far they need to be pushing the needle to get the effect that they want.
  • You may be offered a numbing cream but these don't work beyond the top level of skin and as tattoos are done on the second layer of skin, these creams really don't do much to help.
In summary - yes tattoos do hurt but so does waxing and having your eyebrows plucked. Just make sure that you trust your tattoo artist and that you are relaxed.
on Oct 07, 2013 | Medical
How to ajust the points on a tattoo gun
be more specific, you mean contact points? that's all about armature height, spring tension, spring load, spring angle, spring slope... you want your armature bar about half a centimeter higher than the vice hole on your iron, you want your spring bent to around 20 degrees to 30 degrees depending on if your'e shading or lining. alignment springs (the one that is on the bottom of the armature bar) should usually be a 16 unless your'e using monster coils which good ol fashioned 10 wraps can do lining or shading if youre any good at tuning. dial back your contact screw so that it is not touching the contact spring when it's idle. Use 5-8v of power and press the pedal and dial it in until it touches. The machine will run, keep playing with the contact screw (screwing it inward) until the armature bar has a visible wobble optical illusion attributed to it. LIGHTLY allow the pole on the armature bar to hit your finger and if the machine speeds up instead of slowing down, you've hit the sweet spot. - Professional tattoo artist - Brian @ Foxy Tattoos, Raleigh, NC
Mar 21, 2012 | ART Cast Iron Coil Tattoo Machine Liner &...
MY TATTOO MACHINE IS GETTING HOT
too much voltage, too much amperage, your springs may be too heavy, and the return on your armarture/contact spring should be bent just a little to help it assist forward motion in the direction of the coils. play around with the armarture height and bend your springs while trial and erroring (*******, i know it's not a word) at low voltage like 5.5-7.5 volts. if it hits hard, sounds consistent and doesn't kick back or stick you won't overheat. A better power supply may just be the ticket though. spend at least $80 bucks on one. anything cheaper will feed too much power, inconsistent power or will not feature short circuit protection so the moment a coil stick happens your PS blows. stay away from digital power supplies (the little dinky box ones that look like late 90's GPS beacons) and only run your machines momentarily while tuning, when it's tuned you should know it immediately within the first few strokes based on the sound. You should already know all of this if you are tattooing, but I wont give you heat because I know some scratchers that do better work than Kat Von D and Tomas Tomas, just saying. If you are scratching please for the love of sweet baaaaby Jesus, ONLY USE DISPOSABLES and NEVER go without BARRIER PROTECTION aka, wrap it up. - Professional tattoo artist; Brian @ Foxy Tattoos, Raleigh, NC
Mar 12, 2012 | ART Cast Iron Coil Tattoo Machine Liner &...
Where do i attach the clip cord to the tattoo gun model d99
if you don't know, you shouldn't be tattooing... or it takes an RCA cord in which case your'e just a big dummy
Sep 30, 2011 | ART Cast Iron Coil Tattoo Machine Liner &...
Changed connection and modem to 100 Mbps. No wireless connection from router. Tried wired connection. No go. Router does connect..all lights green. Laptop sees the connection but no internet access.
Improve the Fixya.com experience for everyone by voting!
Subject: No wireless connection from router cannot connect to the Internet.
Solutions: Straight Connection, Windows Connecter and Microsoft Fixit
Discussion: I'm going to provide you with three solutions and between them you should get online. However, you should be advised that in order to fully analyze and correct any difficulties you're having, we should be chatting or on a telephone connection. All I really know at this point is that you can't connect to the Internet through your router.
I'm going to give you three FREE general fixes and let's hope that one of them will work for you. If not, then we have to chat.
Now, let's see if I can help you.
The first solution I'm suggesting works in my business (LAN installations) about 95% of the time. I trust that it will work for you.
Begin by turning on your computer and your router
? Make sure your service provider has activated your account and services on the subscribed line. Please check with your service provider to confirm this.
? Make sure that you are using the latest drivers. You can download the latest driver from Driver Downloads Database.
? Make sure that you have entered the right username and password (case-sensitive) as given by your service provider. For example, in Australia: user@bigpond; in NZ: user.name.xadsl@xtra.co.nz.
? Open Internet Explorer;
? Click on 'Tools';
? Click on 'Internet Options';
? Click on 'Connections';
? Click on 'Setup'
? Click on 'I want to set up my Internet connections manually . . .';
? Click on 'Next';
? Click on 'I connect through a local area network (LAN);
? Clock on 'Next'
? Click on 'Next' [This is not an error];
? Click on 'No';
? Click on 'Next';
? Click on 'To connect to the Internet immediately . . .; and,
? Click on 'Finish'.
That should have you online.
However, if the first solution doesn't get you connected, do the following:
• Click on tools again.
• Click on 'Diagnose Connection Problems'
• and follow the instructions.
The second suggested solution is to use the Setup Wizard. It seldom works for me but you might have more luck than poor me. Here are the instructions:
The Connect to the Internet wizard will guide you through the steps of setting up an Internet connection.
Open the Connect to the Internet wizard by:
• Clicking the Start button Picture of the Start button
• Click on Control Panel.
• In the search box, type network,
• Click "Network and Sharing Center"
• Click Set up a new connection or network
• Then double-click "Connect to the Internet".
The third solution requires an Internet connection. I'm going to pass on to you a FREE and hard to believe program from Microsoft called Microsoft Fixit! I have no idea why this little program hasn't been advertised but then I don't own their stock.
Just click on the following link and your problem should be solved: Download Microsoft's Fixit
You'll see the following areas in which Microsoft Fixit can solve software , hardware and just about every other problem you may incur. They are:
Top Solutions Windows Internet Explorer Windows Media Player
Entertainment Office Other
I suggest that you try top solutions and 'automatic' before exploring the other titles.
Be a hero and fix your friends' computers; just don't tell them how you did it! That will be our little secret.
All the best
Ben
Jul 23, 2011 | D-Link DIR-615 Wireless Router
I have a netgear wnce2001 universal internet adapter. It was previously configured to the wireless internet in home to work with Xbox. Just yesterday the WLAN line went out. Hooked ethernet and USB cable...
The solution I'm suggesting works in my business (LAN installations) about 95% of the time. I trust that it will work for you.
Let's see if I can help you.
? Click on 'Tools';
? Click on 'Setup'
? Click on 'Next';
? Clock on 'Next'
? Click on 'No';
? Click on 'Next';
That should have you online. However, if it doesn't get you on line, do the following: Click on tools again. Click on 'Diagnose Connection Problems' and follow the instructions.
The last choice is to use the Setup Wizard. It seldom works for me but you might more luck than poor me. Here are the instructions:
All the best
Ben
Jun 18, 2011 | Computers & Internet
Paano ako magkaroon ng connection sa internet?please ituru ninyo sa akin kasi first time ko...
kelangan mo magsubscribe sa isang ISP provider tulad ng pldt, bayantel, digitel, smart, globe, or kahit sky cable..or kung gusto mo ng instant internet, bili ka ng globe tattoo or smart broadband kit..
May 17, 2011 | Microsoft Computers & Internet
Couldnt play games on facebook now it says no server
This occurs as a result of slow internet connection, or unresponsive server host. You should get a better modem, if possible a broadband, in order for your system to load sufficient kilobytes per time, for you to play games on facebook. However, if you feel your connection is fast, you can download and install mozilla firefox from 'www.brothersoft.com'. After downloading it, you go to tools/options link, then click 'advanced'. Furthermore, you click the settings button, in this menu set to use 'system network'. Apply the settings, then restart firefox. Make sure your internet connection is already running before you reopen firefox. If you are able to get these steps correctly, I guess your problem is solved
Apr 21, 2011 | Facebook Social Network
Hi, im using a brand new acer asprire x1800 desktop..and i can HARDLY connect to the internet using SUN BROADBAND (lan connection already disabled). i have been using the broadband for a few months now....
There could be several possibilities for your internet connection to slow, or stop functioning. Here is a small list of things to check:
1) Run Spybot Search & destroy:
This is a program that will help you find, and eliminate malware, it's free from Here. It also helps speed your PC up by removing unwanted malware that can drain your system's resources.
2) Check your scheduled tasks to determine nothing is set to run during these " down " times.
3) Check to make sure any wireless connections are secured using WEP or other such wifi security. It's a little known fact that people will " pigy-back " on someone's wifi connection to use the internet and download. this can cause internet instability.
4) Call your Internet Service Provider. Your ISP can usually help you determine if the problem is with your computer or their connection.
5) Check your network settings. Your ISP can help you determine the best settings for your connection, as well you may check to see if the network device has an updated driver from the manufacturer.
6) If all else fails, you may wish to take your PC to a licensed technician, or replace the network device if you feel it is faulty.
In my experience most internet instability that happens on a regular basis during a set amount of time is due to malware, or scheduled downloads.
Nov 03, 2009 | Acer Aspire™ T180 PC Desktop
Dell OPTIPLEX GX110/200 PIII-866MHz 256MB 20GB (PCPIII866DELL) PC Desktop Logo
136 people viewed this question
Alun Cox
