Question about Home
My Eljier toilet doesnt allow enough water to flush properly causing backups
  • 979 Answers
Adjust your flapper. This is keeping enough water from going into the bowl thus allowing it to properly remove the waste.
Posted on Feb 04, 2013
brighthm
  • 36 Answers
SOURCE: not enough water in the toilet bowl
Adjust the floating stopper in the tank to allow more water to fill the tank
Posted on Oct 29, 2008
  • 6 Answers
SOURCE: Toilet will not fill up
Some Toto fill valves have a plastic debris screen located at the inlet connection. Turn off the supply valve and remove the supply connection at the bottom of the tank. Use a mirror to inspect the screen for debris.
I agree w/ Smithbrother, the Fluidmaster fill valves are cheap and work well. The only thing they ever need is an occasional seal for $1.50 and 5 minutes to replace.
Posted on Mar 14, 2009
SOURCE: cadet 3 round bowl toilet not flushing all from bowl
You are probably correct, the water level needs to be raised. There are many different toilet tank systems, but all have some way to control the water level in the tank. Let me know if you need help figuring it out...
P.S. You'll have to take the lid off the tank, first...pardon me if that is too obvious
Posted on May 08, 2009
parrotheadpc
  • 2600 Answers
SOURCE: toilet keeps filling tank every 10 minutes
If there is no water on the floor then the water is leaking down the main tank drain. Take off the tank lid, turn off the water supply to the toilet. Fllush as much water out as you can. Look at the main drain, sometimes if the flapper valve is connected with a chain, the chain can get caught between the flapper valve and the drain hole, the flapper valve is pliable so it tries to seal around the obstruction but can't always do it. Make sure there is obstruction, that the flapper valve is not out of shape or old and non-pliable and that it lines up with the drain hole and doesn't get "hung up" on anything.
Posted on Sep 11, 2009
  • 129 Answers
SOURCE: My toilet does not flush properly. It seems to
You might check under the rim of the toilet, there are about 12 little holes that when you flush water comes out to start the most important part of the flush. The swrill, with out it hard to flush. Talk a piece of wire hanger ( I know "NO WIRE HANGERS") and use it to push up into the holes. Hard water deposits sometimes build up there.
Posted on Sep 28, 2009
Roca dual push button Toilet will only flush when holding the push button continuously down until the cistern is empty. It won't completely flush like it should when pressing the button once.
allow tank to fill a little more by adjusting fill valve. When there's not enough water flowing from tank the stopper can over-power the water flow and cause the flush to stop by re-sealing.
Feb 28, 2015 | Home
Wont complete flush
Could be low water level in the reservoir, otherwise the flapper may be shutting to quickly to allow enough water to properly flush. You could try holding the flapper open or watch it's operation as you flush the toilet to see if it's allowing enough water to drain into the toilet. It's pretty easy to replace the flapper on most toilets and cheap as well.
Jul 25, 2014 | Home
Water ridge toilet manual
Thus if the tank is continuing to drain down through the bowl into the sewer line, the rubber flapper is not seating properly with the flush. These become worn and torn and are easily replaced. Or, even with a new one installed, sometimes they are not adjusted properly to create the appropriate balance between play and pull. Play being the upward connection to the flush handle and pull being the downward draw with the gravity flow of the water. Too much play it won't actually flush or lift properly. Too much pull it does not seat tightly or won't lift up long enough to allow enough water to flow through to flush the toilet...as engineered by the geniuses who designed the toilet. A simple adjustment of the chain links attaching the flapper to the flush handle and perhaps a side to side turn of the cuff so the flapper is aligned to seat properly as it drops should be sufficient. And test, test, test, test, and test again until you're absolutely sure you've got it adjusted correctly. One or two flushes is not sufficient!
Dec 08, 2013 | Plumbing
Flapper closes before toilet has completely flushed,
sometimes those flappers get leaks in them and water seeps into the inside and doesnt allow the flapper to stay afloat long enough for the water to empty. Just replace the flapper with a universal replacement flapper. Very easy and cheap fix.
Mar 31, 2011 | Toto Home
Toilet flushes by its self
Water pressure makes the unit kick on and off by itself. If the pump is turning on by itself that means that somehow water is draining into the pump creating enough water pressure that it will make it kick on and off. Inspect the flapper on the check valve inside the discharge elbow, also check the flapper on the flush valve inside the toilet tank, the flapper may not be closing properly and is allowing water to enter the pump.
Oct 11, 2010 | American Standard Colony 2388.012.222...
Dear sir/madam. when flushing toilet it takes a
Some water saver toilets are very problematic about not having enough water to thoroughly flush. Here are 2 things to look for:
First, after toilet stops running completely, check the water level. Most tanks will have a "full" line marked inside. If the water level is low, your fill valve will need to be adjusted.
Second, if the water level is fine, your "flapper" valve (very bottom of tank) may not be opening all the way. Watch valve as you flush the toilet. It should come up far enough to allow total unobstructive flow of water. If it isn't, adjust chain length until it does. Make sure there is a little slack left.
If neither of these solves your problem, you may have a partial clog that will need to be gotten out with a drain snake that can be purchased at any hardeware store.
Jun 08, 2010 | Home
Basement toilet drains slow sometimes ,other times doesnt want to go down all the way. seems as if there is no pressure to remove waste
if the toilet is old or not cleaned proper, the water jets that shoot the water into the bowl might be clogged. If the jets are clogged with moldor hard water build up the toilet will not flush proper. If you can take a 3 gallon bucket of water and pour straight into the bowl and it flushes fine you have a water pressure problem as described above. the problem also might be that your water inlet system is not letting in enough water to fill the tank. If this is the problem you need to replace the water inlet mechanisim, such as a fluid master. If you use a blue water device that hangs on the side of the tank in the back of the toilet you might have a peice of it under the flapper that takes the water to the bowl when being flushed. Check under the flapper if you put cleaners in the tank.
Mar 23, 2010 | Crane Plumbing Toilet To Go Tall...
Toilet doesn't flush hard enough and some "particles" remain and need to be flushed a second time.
check water level in tank if low adjust float to proper level inside tank will see a level line also check flap as to opening all the way may have to adjust chain if problem continues hard water can cause build up in water holes and narrow tank to bowl tube
Oct 07, 2009 | Kohler 3386-6 Rialto Skylight Round Front...
Flush valve drops before bowl completes flush
is the flapper weighted? if it is it will cause it to shut prematurely. one thing you can do is increase the water in the tank. you might have to buy a pvc cuppler to put on the over flow to allow it to fill up more. korky makes a nice flapper thats not weighted
Aug 01, 2009 | American Standard Traditional Champion4...
I BELIEVE IAM HAVING SOME TYPE OF VACUME ISSUE WITH TOILET
The water in the tank is not filling to the water line, thereby not providing enough water to flush properly. Adjust the float so that the tank fills to the water line
Apr 27, 2009 | American Standard Colony 2388.012.222...
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
