Panasonic DMR-ES10 DVD Recorder Logo
john guy Posted on Jul 09, 2007
Panasonic dvd recorder
Dvd consul shows remote dvd2 but cant get into functions on remote control to rectify please help
  • halsey Nov 09, 2007
    I cannot get back to the setup. The channel 2 button on setup holds and the screen shows ch and remote. It seems froze at this time. I cannot get back to setup. My product is panasonic DMR-E75 V Model Number. The serial number is LP4FA00-1280 My address is [email protected] or 1-319-824-3296 in Grundy Center, Iowa 50638. My address is 308 H Avenue. My name is Keith Hall
A
Anonymous
When Panasonic DVD Recorder DMR-ES10 says X HOLD press Enter and Return simultaniously for until the X HOLD disappears this then unlocks the child lock facility and your DVD player is ready to use
A
Anonymous
Push enter and hold 2
2answers
How to change my remote to dvd1 from dvd2
On the remote press 1 and at the same time "OK" for 5 seconds.
2helpful
Panasonic dmrez27 dvd recorder stuck on dvd2 setting
If you point the remote towards sensor, simultaneously hold down the number (1, 2, etc) you want AND the enter button for 5 or more seconds it should switch to the number pressed. Remember if you have a second one, make sure it's off or put towel over its remote sensor. Sue
4helpful
I have two Panasonic DVD recorders under my television. One is a DMR-EZ25EB and the other is a DMR-BS850EB. My problem is that they both operate on the same remote frequency and I want to change one so...
Press functions,go `to others`select set up,go`to others`select remote control and change to dvd2.Then on the r/c press and hold enter and 2 at the same time for 3secs or more.
Problem with my remote
sounds like it needs to be reprogrammed get hold of manufacturer
as its new they owe you one
2answers
Dvd recorder rdr-hxd860
press stop button then the power button together the player will go off. put it on again the remote should work.
Remote control not working
Look into your manual that came with your dvd recorder for DMR-E80H, Page 46, Changing the Remote Control Code. My child played with a remote control as well and reconfigured it as well. In the manual, you have explanation how to configure your remote control again to work.
42helpful
2answers
Panasonic DMR-E55 DVD recorder - 'remote DVD2' command
I had the Exact same problem, after finding nothing on the net I called Panasonic customer-Support and they gave me the information which led to the solution:
If your DVD screen reads 'remote DVD2':
Press and hold simultaneously the "2" & "Enter" buttons (for more than 20 seconds)
If the screen said remote DVD3 then you would hold "3" & "Enter"
What I found happens when this command is accepted, the DVD screen changes to display the channel & counter
e.g. "A2 0:00.26"
If the screen changes back to "Remote DVD2" this means that the signal from the remote control has been interrupted (you stopped pressing, or the batteries have become weak.)
Providing the batteries have power, try again remembering to hold the "Enter" and number displayed after DVD.
The first time I did this it seemed to take forever (more than 30secs.), but other times it's been accepted in 6 secs.
4helpful
7answers
I had the problem where when i would try to use my remote, it would say "check remote2". I've got a DMR-E55. I called panasonic and they told me to hold down the "enter" and "2" button for about 10 seconds. then it worked. hope it works for you too.
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
