Raise the vehicle. Refer to Lifting and Jacking the Vehicle.
Remove the tire and wheel assembly. Refer to Tire and Wheel Removal and Installation.
Remove the brake caliper. Refer to Rear Brake Caliper Replacement.
Remove the rear wheel speed sensor. Refer to Rear Wheel Speed Sensor Replacement.
Remove the rear axle housing cover and the gasket. Refer to Rear Axle Housing Cover and Gasket Replacement.
Remove the pinion shaft locking bolt.
On axles without a locking differential, remove the pinion shaft.
On axles with a locking differential, remove the shaft part way. Rotate the case until the pinion shaft touches the housing.
On axles with a locking differential, use a screwdriver, or a similar tool, in order to enter the differential case and rotate the C-lock?(1) until the C-lock aligns with the thrust block?(2).
Push the flange of the axle shaft?(1) toward the differential.
Remove the C-lock from the button end of the axle shaft.
Note: When removing the axle shaft, do not rotate the shaft. Rotating the shaft will misalign the gears. Misaligning the gears will make the installing of the axle shaft difficult.
to remove front axle.to loosen front axle nut leave vechicle weight on wheel then just loosen front axle nut because axle nut torque at 217 ft lbs torquehard to loose axle nut with vechicle weight off wheel.okay. you need a 1/2 breaker bar and axle socket to loosen axle nut dont use 12 points sockets need go auto parts store buy right socket for axle nut.okay when you loosen front axle nut you need safely raise support vechicle. need to remove wheels remove fender apron seal remove transaxle fluid remove transfercase oil if you have 4WD.remove hub nut remove stabilizer bar link remove speed sensor remove tie rod end remove lower arm from the ball joint then slide the halfshaft from the hub then carefully pry the shaft from the transaxle.then install new front axle push in make sure front axle snap ring on front axle snap in place inside transmission just pull a little on front axle make its in place. when all done tighten front axle much as you can then when done putting every thing back in place.lower vechicle need torque front axle nut to 217 ft lbs.
conventional axle or limited slip? Get axle code off door sticker.
SECTION 205-02: Rear Drive Axle/Differential - Ford 8.8-Inch Ring Gear
1998 Explorer/Mountaineer Workshop Manual
IN-VEHICLE REPAIR
Rear Wheel Bearing and Axle Shaft Oil Seal -4.0L SOHC and 4.0L EI, Conventional
Special Tool(s)
Axle Seal Replacer T83T-1175-A
Axle Wheel Bearing Puller T83T-1225-A
Axle Wheel Bearing Replacer T83T-1225-B
Driver Handle T80T-4000-W
Impact Slide Hammer T50T-100-A Removal
Remove the axle shaft; refer to Axle Shaft in this section.
Axle Shaft
Removal
CAUTION: Do not use heat to loosen a seized lug nut. Heat can damage the wheel (1007) and the rear wheel bearings (1225). Loosen the lug nuts (1012).
Remove the center cap.
With the weight of the vehicle on the wheels, loosen the lug nuts.
Raise and support the vehicle.
Remove the wheel and tire assembly.
Remove the lug nuts.
Remove the axle housing cover (4033).
Loosen the axle housing cover bolts (4346) and drain the rear axle (4001).
Remove the axle housing cover bolts.
Remove the axle housing cover.
Remove the rear disc brake rotors (2C026); refer to Section 206-04 .
CAUTION: Once the differential pinion shaft (4211) has been removed, turning the differential case (4204) or an axle shaft (4234) will cause the differential pinion gears (4215) to fall out of the assembly. This could result in chipped or damaged components. Remove the differential pinion shaft.
Remove the differential pinion shaft lock bolt.
CAUTION: Do not damage the rubber O-rings in the U-washer grooves. Remove the U-washers (4N237).
Push the axle shafts inboard.
Remove the U-washers.
Reinstall the differential pinion shaft.
Install the differential pinion shaft.
Install the differential pinion shaft lock bolt finger-tight.
CAUTION: Do not damage the inner wheel bearing oil seal (1177). Remove the two axle shafts.
Installation
Lubricate the lip of the inner wheel bearing oil seal.
Use Premium Long-Life Grease XG-1-C or equivalent meeting Ford specification ESA-M1C75-B.
CAUTION: Once the differential pinion shaft has been removed, turning the differential case or an axle shaft will cause the differential pinion gears to fall out of the assembly. This could result in chipped or damaged components. Remove the differential pinion shaft.
CAUTION: Do not damage the inner wheel bearing oil seal. Install the two axle shafts.
CAUTION: Do not damage the rubber O-rings in the U-washer grooves. Install the U-washers.
Position the two U-washers on the button end of the axle shafts.
Pull the axle shafts outward.
Align the hole in the differential pinion shaft with the differential pinion shaft lock bolt hole.
Install the differential pinion shaft lock bolt.
Install the rear disc brake rotors; refer to Section 206-04 .
Install the axle housing cover and fill the rear axle housing (4010) with 2.4 liters (5.5 pints) of specified lubricant; refer to Axle Housing Cover in this section.
WARNING: Always remove any corrosion, dirt or foreign material that may be present on the mounting surfaces of the wheel or the surface of the wheel hub or rear disc brake rotor that contacts the wheel. Installing wheels without proper metal-to-metal contact at the wheel mounting surfaces can cause the lug nut to loosen and the wheel to come off while the vehicle is in motion, causing loss of control. Clean the wheel hub and mounting surfaces.
Install the tire and wheel assembly.
Position the tire and wheel assembly.
Install the lug nuts and lower the vehicle.
Tighten the lug nuts.
Install the center cap.
CAUTION: Never remove the axle shaft oil seal by itself. Always remove the rear wheel bearing and the axle shaft oil seal at the same time. NOTE: If the axle shaft oil seal is leaking, the axle housing vent may be plugged with debris. Use Impact Slide Hammer and Axle Wheel Bearing Puller to remove the rear wheel bearing and the axle shaft oil seal.
Installation
Lubricate the new rear wheel bearing.
Use Thermally Stable Rear Axle Lubricant XY-80W90-QL or equivalent meeting Ford specification WSP-M2C197-A.
Use Axle Wheel Bearing Replacer with Driver Handle to install the rear wheel bearing.
Lubricate the lip of the new axle shaft oil seal.
Use Axle Seal Replacer with Driver Handle to install the axle shaft oil seal.
Install the axle shaft; refer to Axle Shaft in this section.
Working through cover opening, remove differential pinion shaft lock pin and remove differential pinion shaft and differential pinion gears (4215).
NOTE: THIS IS FREE INFORMATION!!!!
Remove rear brake anti-lock sensor . Push axle shaft inward until u-washers at button end of the axle shaft are clear of side gear recess.
CAUTION: Do not damage inner wheel bearing oil seals when removing axle shafts from rear axle housing. In addition, axle shafts should be completely removed from rear axle housing.
Remove u-washers and pull axle shafts out of the rear axle housing.
-Remove tire and brake drum
-put drain pan under axle housing
-remove rear axle housing cover (10 or 12 bolts)
-turn gear untiil the bolt for cross shaft shows and remov e the bolt
-remove the cross shaft.
-push axle in until you can remove "U" clip from axle and axle will pull out,
Remove seal, you need a pulller to remove axle brg.
remove differential cover,turn axle until chunk turns around to access the small 5/16pin bolt remove pin bolt ,slide spider gear axle rod out ,go to axle ur working on and push axle inward ,ther is a c shaped key on end of axle where u took spider axle rod out remove this key easly by hand and pull axle out,,,note do not turn chunk after removing spider axle rod or ur spiders will fall out
No "axle pins". Axles are held in with "c" clips. Remove wheels. Remove drums (or rotors). Remove differential cover. Rotate axles or driveshaft until a small bolt running horizontally can be seen. It has an 8 millimeter head. Remove this bolt. It holds in a shaft that is about 1 inch in diameter an 3 inches long. Remove that shaft. Shove axle towards center of vehicle one at a time. C clip can now be removed from internal end of axle and axle can be slid out of axle housing. When axles are removed DO NOT ROTATE DRIVESHAFT OR CARRIER.
it wont ever work.this is a nortel proprietary telephone and will only work on the nortel products. there is also issues with voltages etc.you are lucky if you have not damaged the ptt end of your home line remove it as quickly as you can...hope this helps
