MY HP2480 PRINTER DOES NOT RECOGNIZE BRAND NEW COLORED CARTRIDGE
My hp deskjet 2480 printer does not recognize brand new colored cartridges i thought its a fake cartridge on the first time but i tried 3 other brand new genuine cartridges but still the problem persist. the printer is working properly before but its not working propoerly now.
  • 59 Answers
SOURCE: Color Cartridge Failure
You know, I'm not going to read the other solution. I know 100% FOR SURE, when a cartridge fails, it is dead and there is nothing you can do about it, but there is a good side. HP ink cartridges have a year warranty. Call them and tell them it failed, they'll send you a new one!
Posted on Oct 02, 2007
  • 4 Answers
SOURCE: Remove and check color cartridge
try this. worked for me. when installing the cartridge, put one finger under the cartridge and hold upward pressure as you closed the green plastic cover. problem is the pins on the cartridge and the pins on the printer are not aligning properly by relying on the spring to do it. this will help to align the pins and should make it work.
Posted on Nov 19, 2008
jmassengill
  • 345 Answers
SOURCE: The printer doesn't recognize the new original HP color cartridge
There is a small spring that holds the ink cartridge in the ink holder. You will see it stick out from the right hand side of the ink holder where the ink cartridge slides in. If that spring isn't being held to the ink holder by two plastic tabs, (I.E. the plastic tabs are broken) the printer will never recognize the cartridge. If the printer is still under warranty I would contact HP or an authorized repair center for HP. Both the black and color ink holder has this spring. I know of no way to repair this kind of breakage.
Posted on Jan 08, 2009
  • 4 Answers
SOURCE: hp 2610xi not recognizing HP 97 color cartridge
If you look in the 96 (Black) cartridge loading area you might see that the retention spring has poked a hole in the circut board. I am now either trying to replace the ink cartridge holder or purchace a new printer. I have about $70.00 in new ink that I can't use now. The 2610xi worked great until the spring popped out of its holder.
Posted on Mar 22, 2009
  • 15 Answers
SOURCE: Printer will not recognize refilled black HP cartridge (#74)
Try to get your printer to recognize the new cartridge; go to start - printer and faxes -right click on printer - preferences (printing preferences) -settings -load factory settings. Print test page Ctrl+P
Please post if that worked.
Posted on Jul 13, 2009
HP Deskjet 1010 will not recognize ink cartridges from another manufacturer. How to override this & get on with printing?
Use the cartridges for the same brand and same part number as of your printer, other brands will not work for your printer
May 21, 2014 | HP Deskjet 3845 InkJet Printer
I am replacing the #97 color ink cartridge and my printer left ink icon blinks and doesn't appear to recognize the new cartridge
Is the cartridge "new" or "refilled" ?
Remove the ink-cartridge.
Turn the printer off.
Disconnect the AC power cord.
Reconnect the AC power cord.
Turn the printer on.
Re-insert the ink-cartridge, and be sure that it is "seated" fully and correctly.
Dec 15, 2010 | HP Deskjet 6940 InkJet Printer
HP Deskjet 5550 quit printing red color. Installed new color cartridge HP57. Quit printing red again after 5 pages. Is it a printer problem or cartridge problem?
Have you check your color cartridge if they are properly installed.
Make sure your are not using a refill cartridge.
Replace your tri-color cartridge with original an HP tri-color cartridge.
Aug 26, 2010 | HP DeskJet 5550 InkJet Printer
Rhinotek color cartridge not recognized in my HP printer. what can I do?
Non-HP cartridges often give troubles in HP printers. Probably the best thing you could do is just use HP cartridges.
May 05, 2009 | HP DeskJet 960c InkJet Printer
Printer does not recognize color cartridge for my HP OfficeJet 7410
its a broken spring clip on the side of the ink cartridge.
fixes are here;
http://www.fixyourownprinter.com/forums/inkjet/46650#83
and here;
http://www.fixyourownprinter.com/forums/inkjet/50913#243
hp is supposed to give you a brand new printer for free.
Apr 13, 2009 | HP LaserJet 8150 Printer
New tri color ink cartridge will not print red
Probably bad, there's actually no way to check ink levels.
Jan 22, 2009 | HP DeskJet 960c InkJet Printer
Dec 03, 2008 | HP DeskJet 5150 InkJet Printer
Are you sure it's a genuine HP cartridge? Sometimes remanufactured cartridges aren't recognized by the printers. HP and others make them so that they have a chip inside that ensures only new genuine cartridges can be used. Try a new HP and see if that solves the problem. If you've already tried that one, then make sure the contacts in the printer are clean. If you still have a problem, then I'd say try a new printer!
Oct 19, 2008 | HP OfficeJet 7410 All-In-One InkJet...
The color ink in my hp deskjet 920c won't work
try cleaning the contacts (bronze like) with dry cloth both the cartridge and the cartridge holder most of the times there exist some liquid forms on both areas. since you frequently remove the cartridges; their might be a broken part on the cartridge holder. the broken part, use, is to make sure the cartridge is in absolute contact with the cartridge holder's. the size the said broken part is 2 mm in all sides. so small that it has a big function.you dnt even recognize.
Nov 07, 2006 | HP DeskJet 920c InkJet Printer
26 people viewed this question
k24674
