Question about Haier HRF10WNB Top Freezer Refrigerator
Haier hrf488/fr defrost mechanism faulty - Haier HRF10WNB Top Freezer Refrigerator
Our Haier HF-100/A fridge is 3 years old since purchase (Co-Op), and appears to have developed a faulty refrigerant circulation circuit. The top two shelves of the compartment are no longer freezing down....
DC (Adaptive Defrost Control) is **generally** the issue on these....you can force a defrost by jumping L1 and Test on the board.
Some general info on how an automatic defrost works at:
http://www.applianceaid.com/defrost_cycle.html
Also, a little info on adaptive defrost controls at:
http://www.applianceaid.com/adaptive_defrost.html
Jul 01, 2008 | Haier Refrigerators
Why does my refrigerator turns off restart a couple days later ?
Could be the back of the freezer is not defrosting and is packed up with ice. The cold air then can't circulate to the fridge part as the fan is frozen solid in ice. Had this happen due to a faulty transducer that tells the defrost system the freezer is iced up and to go into defrost mode. Also it could be the fan that blows cold air down into the fridge from the freezer compartment.
Aug 24, 2014 | Haier HNDE03VS (32 cu ft) Compact...
Defrost timer location
Check this out for manual: www.manualowl.com/p/Haier/HRF-588FR/Manual/99803
Feb 28, 2014 | Haier Refrigerators
My Haier wine cooler (Model BC112G) has stopped working. Prior to it stopping, the pipes in the lower back became caked with ice. Any ideas what might have broken...and how/if it can be fixed?
let the thing totally defrost (24hrs)with the door open then switch it back on as a first step,the ice on the pipes stops the gas from turning from a liquid to a gas...thats how it cools..
Jun 03, 2010 | Haier BC112G Wine Cooler
Frezzer working,freshfood side not,ok I stopped motor several times and it work four days and agin the problem. Is there a sensor in the freshfood side? or a little fan inside?Pls Help me
Hi, you got a defrost problem, when to much ice build up after few days,cooling decreases. it could either be your defrost heaters are burnt out, faulty defrost timer, or faulty defrost thermodisc, which are usually at back of freezer, you will have to remove back panel of freezer, and cary out continuity test, to see which ones are defected. the defrost timer sometimes could be found inside of refrigerator compartment or at back of ref. different models, different location, you didn't say what made ref. you got, surely you got a defrost problem, you will need a mechanic to get it check, if your days are hot, or if you got door gasket problem, or someone forgot door half open for few hrs, or excessive hot air getting into ref, could cause that too. before calling mechanic, you will need to empty ref. and unplug for few hrs, clean out all ice, surely it will work, but if problem continues, call mechanic.
Aug 07, 2009 | Refrigerators
My Haier Mini Fridge comes on but keeps nothing cold. I defrosted in August and it worked for awhile and now it defrosted on its own and no longer gets cold.
This could be a bad defrost timer. See if the compressor is working. If it isn`t or only works sometimes. The defrost timer could be bad. When the frig goes into the defrost cycle, turns off the compressor. It may failing to turn the compressor back on after the defrost cycle. Since it stopped defrosting at one point and started again, the defrost timer may be bad. Let me know if this was any help or if I can help any farther.
Nov 12, 2008 | Haier Refrigerators
Haier HRF-488FR/***
hi there, i noticed your post was in 08 did you find a seal to fit your fridge i have a hrf 488 fr/a and fisher and pykel are looking after them now... they advised be that this model is obsolete now and no longer have parts available.
May 19, 2008 | Haier Refrigerators
Haier HRF10WNB Top Freezer Refrigerator Logo
23 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
