Question about Coffee Makers & Espresso Machines
Hi! my Delonghi ESAM 4000/4200 model Infuser got stuck at down position while the Power was still ON. I couldnt remove the infuser even with power OFF. The Drip tray with Cup tray couldnt be inserted back because the infuser is blocking its slot. Did power reset but to no avail. Already cleaned coffee granules in infuser path. Anything I can do more to reset the machine back to normal position? I still couldnt find any service center here in Manila... :( thanks
2 Suggested Answers
  • 1833 Answers
SOURCE: The infuser is low and
According to your problem, first turn the appliance off by pressing the button but do not unplug and wait for the display to go off; open the service door. Remove the grounds container. Press the two red release buttons on the infuser sideways and towards the centre and pull the infuser out, but remember the infuser can only be removed when the appliances is off. Then insert the drip tray first. After place the drip tray replace the infuser by sliding it onto the supports and pin at the bottom, then push the PUSH symbol fully in until it clicks into place.
Posted on Jun 24, 2011
Delonghi magnifica has exclamation
Switch the machine off, AND pull the plug, wait 5 minutes (to be sure) and turn it on. Then turn it off again, now the infuser should return to it's normal position where you can take it out.
If the descale button is still flashing, try descaling again. Was the procedure interupted before? That would be a reason the light keeps flashing.
Bert
Nov 19, 2015 | DeLonghi Coffee Makers & Espresso Machines
Infuser jammed in ESAM 5600 cannot get it out
Obvious question really, but is the power turned off? You cannot get the infuser out if the power is on. Or has it been reinserted recently, and incorrectly? The only time I have known of issues getting them out is if the power is on, or if the power went out when it was not parked, in which case turn the power back on it, let it go through the warm up cycle, then turn it off again, let it shut down, then remove the infuser
Jun 15, 2014 | DeLonghi Intensa ECAM 23.210 W 2-Cup...
How do you remove a stuck diffuser on ESAM4200. Have tried switiching it on and off but its still stuck
Hi Sue Are you sure that it is not the infuser that is stuck. Theere are a number of things you can do to try to loosen it. Has it clicked? I put the link to the manual here, you should be able to find help there, I have when I could not get my ifuser to click iuser.http://www.delonghi.com/corporate_en/products/esam-4200s-ex1/ Kolbrun
Sep 10, 2013 | DeLonghi Coffee Makers & Espresso Machines
Hello i have an Delonghi esam 4200 and the infuser got stuck can you please recommend how can i solve it
I had this problem until I realised that you need to switch the machine off by pressing the on/off button on the front of the machine first *before* switching it off at the back and unplugging it. This moves the infuser unit further to the bottom and then allows you to take it out.
Aug 27, 2010 | DeLonghi Coffee Makers & Espresso Machines
Infuser stuck up my delongi magnifica
I have a problem. I removed the infuser and the internal bracket is now in a "down" position and I cannot get the infuser back in. I need to know how to raise the internal bracket to its proper place. Any ideas?
Apr 06, 2010 | DeLonghi Coffee Makers & Espresso Machines
Delonghi magnifica coffee machine...infuser jammed in machine. Needs to come out for cleaning. Can depress red buttons but it wont come out..looks a but squint
Remove base plate and turn pulley clockwise (probably for several minutes) until infuser arm returns to vertical position and the infuser itself drops to the low position. You should here a click when it reaches this point. The infuser can then be removed as normal.
Nov 02, 2009 | DeLonghi DCM485 Coffee Maker
DeLonghi Magnifica always asks "Insert Infuser Assembly"
on my machine, the two screws that attach the infuser receptacle to the insides of the machine came loose. You can see those two stainless hex socket screws when you remove the infuser by grabbing its two red tabs and pulling it out. Just use a hex shaft
screwdriver (size 3mm or thereabout) to tighten them.
Apr 01, 2009 | DeLonghi EAM3500 Espresso Machine/Coffee...
Magnifica gives Generic Alarm Message - Infuser stuck
My infuser was stuck in the down position, When I called customer support the told me some easy steps to fix this problem..try calling them
Nov 28, 2008 | DeLonghi Esclusivo Magnifica ESAM3300...
Coffee Makers & Espresso Machines Logo
230 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
