Question about Sport & Outdoor - Others
How high are hurdles? - Sport & Outdoor - Others
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 63 Answers
Hurdles are about 1.067 meters high
Posted on Jan 14, 2013
How Does i become a english teecher?
To be an English teacher, you just not only to be good but you have to be excellent in English reading, writing, literature and proofreading.
You have to be a graduate/post graduate or PhD holder.
You need to undergo certain Licensure and Certification
Finally, if you successfully cross these hurdles, you will be a certified English teacher who can teach in elementary/middle-level/high schools or colleges. You will also become eligible to be an Online English Tutor and advance your career in the same field.
Jan 04, 2017 | Higher Education (University)
Simpson Maxidry 362. Tips on putting back together....? Roller tensioner spring attached to...?
Here are the steps to get the belt and tension pulley and spring attached properly.
1. Remove the drum from the dryer housing
2. Fit the belt around the drum, secure the belt to the drum (grooved side towards the drum, flat side away from the drum) with small strips of masking tape. Leave a loop of about 10-15 cm's free to fit around the motor. (This was Hurdle #1, it was next to impossible to hold the belt on with one hand and attempt to work out the tension pulley thing at the same time)
3. Place the drum back in to the dryer housing and rotate it so that your belt loop is facing the motor.
4. (Hurdle #2) Attach the tension pulley to the motor assembly bracket. (There should be slots in the bracket for the pulley bracket to insert into. The pulley faces away from the motor, about a 45 degree angle.
5. (Hurdle #3) Feed the belt through (under) the pulley and then over the motor's drive wheel or nub, whatever it's called.
6. (Finaly Hurdle) Attach the spring to the pulley assembly. In the centre of the dryer housing floor, there should be a seam, in the centre of this seam there is a small hole where the other end of the spring attaches too. Stretch and insert the other end of the spring into this hole.
7. Remove the masking tape that's holding the belt down.
8. Re-assemble dryer and your done.
Jun 20, 2008 | Dryers
What is a hurdle?
A hurdle is the name given to a moveable fence or obstacle like the ones used in track and field events such as hurdles.
Jan 17, 2013 | Sport & Outdoor - Others
What is the best technique for hurdles?
I found this site that is a sport coach giving advice on hurdles and the best technique involved. http://www.brianmac.co.uk/hurdles/index.htm
In track and field racing what does the term shutter stepping mean?
Shutter Stepping is related to any event where foot placement needs to be exact: shortened steps leading up to a hurdle or on a runway event where the final step initiates the jump, vault or throw.
How far apart do hurdles need to be in a 110m race?
The first hurdle should be places 15 yard away from the start, the each hurdle should be placed 10 yards apart thereafter. There should be 15 years between the last hurdle and the finish line.
Jan 14, 2013 | Sport & Outdoor - Others
Cant unlock phone
If you need reliable, CHEAPER and high quality unlocking code for your Blackberry Pearl 8100, then try Blackberry unlocking codes with IMEI. They offer excellent customer support service and have a wide range of phones. Once you unlock your phone, you can carry it to several countries without the hurdle of getting it locked again. Take care and good luck :)
Apr 27, 2011 | RIM BlackBerry Pearl 8100
Fallen at the first hurdle! The instructions say it's easy!!
try going to windows media player and going to the sync tab. connect your device, than what ever music is in the liberary of the media player, drag it to the sync list. when you have the songs you want, click start sync. thats what i did with mine.
Mar 15, 2010 | SanDisk Sansa Clip MP3 Player
I have an LT170 proj. i bought on line but it has no lamp .
You are looking at two hurdles here: 1) The lumen output of an LED light is nowhere even close to the output of a high voltage lamp in a LCD projector. 2) The color temperature of the LEDs, even if they were bright enough, will likely not match that of the lamp. This means the colors will not display correctly.
While it is a very ambitious project, I think you may be better off replacing the lamp with the proper model.
Dec 24, 2008 | NEC LT70LP Projector Lamp for LT17
Cobra 132 recieves good poor send
Poor send? Is your modulation ok?
The biggest hurdle for good coms is the antenna, placement and proper tuning will make or break your CB.
Check your SWR, if you can't check it then another way to get an idea is to use your power meter.
It will show more power when the SWR is high, check you high and low channels for increased deflection. High on channel 40 and low on channel one would mean antenna needs to be shorter and the opposite for channel one. A balanced reading or slightly lower reading in the midband channels would indicate antenna working near optimum.
Dec 06, 2008 | Cobra 29 LTD CB Radio
Sport & Outdoor - Others Logo
593 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
