Question about Sport & Outdoor - Others
How far from the ladder are you supposed to stand?
    Guru:
  • 269 Answers
The "toss line" is five paces away from the ladder.
Posted on Jan 14, 2013
Can not order parts
Have you tried eBay? Or Google this toy and try to find the manufacturer. If still in business, you could contact them. If not, you may have to follow the breadcrumb trail of who purchased it, when, and where it stands in today's business world. I would say the ladders and bell are the easiest replace. Any woodworker worth his salt could recreate these ladders. And the bell looks as though most any vintage style bell will work. It's the dome head nut that has me stumped.
Mar 19, 2014 | Kids Deluxe Fire Truck Pedal Car Red
What is a telescoping ladder?
Cynthia. The ladders Justin are referring to are not Telescoping Ladders. A telescopic ladder is one that collapses into itself like a telescope or a collapsible tumbler or "cup". Generally stands about 2-3' tall when completely collapsed and you can feed out as much of it as you need provided what you need in height isn't more than the ladders total length.
These ladders are GREAT and are typically used for inspections and cable installers. Some are rated for a fair amount of weight but I wouldn't trust it. We love using them and have been a great tool to have in the arsenal.
I have attached a photograph of one of our telescopic ladders.
Jan 23, 2013 | Tools & Hardware - Others
G5rv lite installation instructions
A G5RV antenna is a popular ham antenna due to its cost, weight and ease of installation. The G5RV is a really a dipole type, that looks like a "T" with the top of the T as the main radiator consisting of a single conductor main radiator and the bottom of the "T" (also radiating on certain bands) consisting of a 2 conductor 450 - 600 ohm "ladder line" that terminates in a fitting that converts ladder line to a coaxial connector.
One of the most popular configurations is the inverted "V". Depending on the version of the antenna, the main radiator will be either 102, 92 or 51 feet long. The ladder line will be 32, 42 or 16 feet (respectively) in length and will require a coax feed length of 70, 70 or 40 feet minimum (again, respectively) to present the proper range of impedences to your manual or auto tuner (the G5RV REQUIRES an external tuner to present an acceptable SWR or impedence match to your transmitter on all bands).
The inverted V requires a mast as high as you can erect, located as close as centered between support sources (trees, buildings, etc.). Ideally, there should be enough room between the mast and the main radiator supports to allow the main radiators to be fully extended. Also, the ladder line should be able to hang straight down without being coiled on the ground at the base. This means you'd need a 32 ~ 42 foot mast at minimum.
The top of the mast will be needed to be fitted with an anchor or hook that will support the center insulator that provides strain relief, splits the ladder line and allows connection of the ladder line conductors to the single conductor main radiators.
Unroll the antenna on the ground. Connect the center insulator to the top section of the mast by the hook. Install "antenna lead stand offs" every 3, 4 or 5 feet. Secure the ladder line to the stand off to keep it from touching / wrapping around the mast.
Use UV resistance parachute cord to connect to and support the main radiator insulator, and pull the slack from the line, from a point as high off the ground as possible. Do the same to the other radiator, trying to match the height above the ground as the first radiator. Go back and forth between the two radiators (or have a helper - so each can be pulled slowly, and evenly together. Inspect the mast to be sure it is still straight. Loosen or tighten the radiator support lines as needed to allow the mast to stand straight.
Secure all lines, connect and run coax to the connector at end / bottom of the ladder line. and connect the opposite end to your antenna tuner connector labeled "ANT". Connect a short coax cable between the transmitter's "ANT" connector and the tuner's "XMIT" connector.
Set xmit power to 5 - 10 watts, transmit and operate the tuner - or set up your radio to use an external auto tuner. Tune for lowest SWR or reflected power. The internal auto tuner on many radios is only good for correcting up to a 3.0:1 mismatch or SWR. The G5RV will present mismatches far in excess of 3.0:1 on certain frequencies and bands.
Jan 12, 2013 | Radio Communications
How many ladders should I put in the cage?
It depends on the bird type and size. If it is a big parrot like African greys or macaws I would put 2-3 ladders. I also recommend having ladders and perches in the birds stand so the bird will be able to stretch their wings and do some exercise.
May 14, 2012 | Birds
Ice maker not making ice
1)First check you have a water line that is getting water to the ice maker.
2)Ice makers have a valve at the bottom that open and close when told by the ice maker replace that cheap fix.
3)The ice maker needs to be repaced.
(how far into the line will the water freezehow far into the line will the water freeze)
.The valve at the back opens and closes will not leave water in the line to freeze.
Dec 21, 2008 | KitchenAid Superba Architect KSCS25INSS...
No Problem
This is "middle of the line" Kitchenaid as far as bowl size and motor strength goes. However, it is a great mixer that will probably fit your needs.
Nov 28, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
Sport & Outdoor - Others Logo
905 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
