Door seals i need seals for these machines as the quality i get now is really inferior.i have a sample or can send photos
  • Washing Mach... Master
  • 17,130 Answers
Please check on these link for spares updates
Click on : washing machine spares
Posted on Jan 14, 2013
2 Suggested Answers
  • 1527 Answers
SOURCE: changing door seal on hotpoint ultima washing machine
hello if you take the top off the washer and look down inside you should see a metal ring with long screw and nut unscrew this so it's loose you should be able to pull the seal off .then on the front of the washer where the next part of the seal is theres another rmetal thin bit of wire . unscrew the platic clip and the wire should come off. then just pull the seal out of the washer and when you put the new seal on fit it the same way you took it off good luck ps get back to me if you get stuck
shaun
Posted on Sep 06, 2009
I need to seal my attic door completely but not my using locks or bolts.I need something strong to seal it.Any idea?
I don't know why you want to seal your attic but some companies provides wide range of industrial seal so you might want to go through it to find which suits best for you since you don't want any bolts or locks. People usually use good quality and high strength locks or bolts to seal the attic. But it is your choice whatever you want to use.
You could try this link to get some good seal for your door.
Security Seals High Quality Tamper Evident Seals Bolt Seals Cable Seals... Security Seals High Quality Tamper Evident Seals Bolt Seals Cable Seals...
Feb 08, 2014 | Sentry Safe Products Sentry Safe H4100...
How could I find best qualities of seal to lock my attic doors?
I don't know why you want to seal your attic doors.Some of companies provides wide range of industrial seal so you might want to go through it to find which suits best for you since you don't want any bolts or locks.People usually use good quality and high strength locks or bolts to seal the attic.But it is your choice whatever you want to use. Security Seals High Quality Tamper Evident Seals Bolt Seals Cable Seals...
Feb 03, 2014 | KitchenAid Architect Series KEMC308KSS...
Whirlpool Clamp came loose on front door seal
Check for replacing door seal: Use the right type and quality.
Click on Door seal
Jan 22, 2013 | Whirlpool W10217563 Washer CLAMP, BELLOW...
Maytag washing machine leaking water
Hey, Maytags never need servicing!, or so the advertising used to say. However, a leak is really not a "machine" problem, it is a plumbing problem: If it is leaking from a door seal (all the way around the door including the bottom edge), replace or reglue the door seal. If it is filling up too high inside, it may cause excessive pressure on that seal. If, however, the leak is between the machine drain and the floor pipe, you will need to pull out the machine and inspect the seals...change as necessary...have fun!
Dec 27, 2012 | Magic Chef 24 in. DU6550 Built-in...
Need seal for center door for comercial 3 door Delfield.
A good parts store will carry ready made gaskets, just bring a sample to match.
Apr 28, 2010 | Freezers
My machine wont start ,unless i really have to slam the door real
Either the switch striker/actuator on the door is worn or the door lock/switch assembly on the right side of the door opening is faulty. It is recommended to replace both parts when one is faulty or worn. The door lock/switch assembly is part number 1094190 and costs about $55. The switch striker/actuator is part number 906446 and costs about $5.
Door Lock/Switch Replacement Procedure
  • Unplug the machine.
  • Open the machine's door.
  • Locate the retainer spring of the seal boot retaining hoop at the bottom of the door opening.
  • Stretch the retainer spring apart then remove the retaining hoop.
  • Ease the edge of the seal boot off the lip of the door opening near the door lock/switch assembly. Remove enough of the seal boot to gain access to the door lock/switch assembly behind the front panel of the washer. Be careful not to tear the seal boot. It will cause water to leak out of the machine.
  • Remove the three screws securing the door lock/switch assembly to the front panel.
  • Slightly lift the door lock/switch assembly, pull it away from the front panel then pull it out of the machine.
  • Disconnect the wiring harness and connect the new door lock/switch assembly.
  • Reinstall the new door lock/switch assembly and the seal boot in reverse order of the procedure above.
Jan 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Fridge not working - electricity is fine, no dust
There so many reasons for the answer to the solution that I want to ask you a few things about your refrigerator.
1. Sears uses model numbers that protect their brand names and models to keep them Kenmore. For example Kenmore may be made by a very well known Brand name with a different model number. The truth for a sample Kenmore Brand Name would look like this 214.2654789 for example only.
2. Location of most Sears Brand Names are located near the bottom of the fresh food section door and just near the door seal. I will send photo locations soon because my computer that I use to upload photos and description's in doing a long virus scan.
Now can you tell me the model number, are the lights on, are fan's running or is it just like it's unplugged?
Answer those or most of those question and I will help you get your Kenmore running again. Thanks, Sea Breeze
appliancepartsse@yahoo.com
Aug 03, 2009 | Kenmore Refrigerators
How can we tell if our fax machine is working
basically if the fax is well kept, its dialing properties will remain ok. what you need to check is the quality of print out. to test the quality of print out just try to copy a sample document. if your fax is a thermal type, change the paper first before proceeding with copying. if your fax has a menu and help button try pressing the menu first before help for the fax to print a helplist.
Mar 28, 2009 | Office Equipment & Supplies
Replacement door seal/gasket
This video will show you how to replace the Bosch washing machine door seal with step by step guide on the process
Apr 08, 2007 | Bosch Classixx WVF 2402 Front Load...
Sony M1 photo quality issue
I love my M-1...My Pics are all sharp.I love the video as well.Very nice to send 20 sec MPEG4 on AOl...may not be DVD quality but not herky jerky either.I also love the design.
Sep 15, 2005 | Sony Cyber-Shot DSC-M1 Digital Camera
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
