Question about Compaq Presario 1200 Notebook
Trying to remove a memory module from Compaq Presario 1200 Notebk
I have 2 of these notebooks, one is broken. So, I'd like to add memory from the broken one to the working one. Crucial Memory scan tells me I have a 128m module and a 64m module in the working unit. I thought I could replace the 64m module with the 128m module from the broken notebook to get to 256m. The module looks like it is on the bottom of the unit, but not sure how to remove it.
  • 43 Answers
On either side of the unit there may be levers you can pull up, or one center lever, otherwise you can generaly prop it up a little bit and it will slide right out (before putting in new memory make sure the mobo can detect it otherwise its a waste of time) make sure to be careful when handling memory, the oil on your fingers can damage the contact and so forth.
Note : a little force is good, if you feel liek you might break it stop! and do NOT use any tools
Posted on Jan 24, 2009
Compaq Presario CQ50-215NR The computer has a beeping sound like a car alarm. while to Operrating system is running. It wont stop beeping
Hello.
The most common reason for this problem is memory. They could be slightly loose or faulty.
Disconnect all cables. Flip over the laptop and unlock and remove the battery.
Remove the memory cover. Remove and reinsert (on a slant) the memory module(s). Replace cover and battery.
Power on again.
If the problem persists, a memory module could be faulty. Follow the above instructions but test one module at a time.
Hope this helps.
Nov 08, 2011 | Compaq Presario CQ50-215NR Notebook
Hi, my notebk cant start. Can help? tks
Your notebook operating system has been corrupted.It need a new operating system installation.
Apr 18, 2011 | HP Compaq Presario v3000z Notebook
I want to add more memory and I need to know where the two available slots are and how to add more memorey to my presario v2000
the maximum memory you can add for your notebook is upto 1024MB DDR SDRAM (1 x 1024MB). I will provide you the manual where you find the instructions to remove and replace the memory modules.
here is the manual :
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?product=500508&lc=en&cc=us&dlc=en&lang=en&cc=us
Open the above weblink and click on Compaq Presario V2000 Notebook PC , HP Pavilion dv1000 Notebook PC , HP Compaq nx4800 Notebook PC - Maintenance and Service Guide.
Then in the pdf opened refer to page 121 ie chapter 5-12
Jun 14, 2010 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V6101US Notebook PC' push the
There are several reasons why this could be happening. Below are a few diagnostic steps we can start off with to eliminate some possibilities. If there is anything you are not comfortable with doing yourself please consult a local repair technician.
  • Remove the battery from the system and try booting up the computer with only the power cord. The "1" in the diagram below is the battery, "2" is the battery release latch.
  • Try removing one of the memory modules (if there is more than one) from the system by following the below steps.
1. Flip the computer upside down. Remove power cord and battery and ensure the system is completely off.
2.Unscrew the compartment labeled "4" in the diagram below. This is where the battery is held, as well as the WiFi card and motherboard battery. DO NOT do anything to these other components as they are quite fragile.
3. If there is more than one memory module you should remove one. Replace the compartment cover and attempt to boot up with battery and power cord reattached. If nothing has changed try swapping out the memory with the one you just removed.
If still nothing happens, this is not the issue. Comment back and we will move further with your case.
Good Luck,
NOLA Tech
Jan 28, 2010 | Microsoft HP Compaq Presario V6101US...
How do you remove the actuall keyboard on a compaq presario 1200 notebook computer, i have removed all screws and access doors on bottom end, along with the memory etc.
First remove the top plastic strip piece (where the power button is located) and then use a phillips screwdriver and unscrew the screws holding the keyboard in place. Gently pry it out and then remove the ribbon cable that connects the keyboard to the mainboard
http://www.refurbished-laptop-guide.com/how-to-replace-laptop-keyboard.html
Nov 04, 2009 | Compaq Presario 1200 Notebook
Compaq Presario Notebook V3000T I replaced the 2-256mb memory cards with 2-1g memory cards. System boots up but only reads 1024mb?
Thanks to Microsoft Knowledge Base for help with my answer:
First, find out what the maximum amount of memory is. This is generally listed by most of the manufacturers. This will let you know what upgrade potential the system has. Next, determine how the memory configuration is when you buy the system. For example, a laptop that has 2GB of memory can be configured as either a single 2GB module or two 1GB modules. The single memory module allows for better upgrade potential because by adding another module you are gaining more memory without sacrificing any current memory. Upgrading the two module situation with a 2GB upgrade would result in the loss of one 1GB module and a memory total of 3GB.
Jul 07, 2009 | HP Compaq Presario V3000T Notebook
I'm trying to upgrade memory in a compaq presario m2000 laptop. Was told it would be obvious and easy but looks tough to me. Can you help?
1. Save your work and close all open applications.
2. Shut down the notebook.
If you are unsure whether the notebook is off or in
hibernation, turn the notebook on and then shut it down
through the operating system.
3. Disconnect all external devices connected to the notebook.
4. Disconnect the notebook from external power.
5. Remove the battery pack.
6. Turn the notebook upside down.
7. Loosen the 2 memory compartment screws (1), and then lift
up and remove the memory compartment cover (2).
8. Remove a memory module.
To remove a memory module:
a. Pull away the retention clips on each side of the
module 1. (The module tilts upward.)
b. Grasp the edges of the module and gently pull the module
out of the memory slot 2.
c. To protect a memory module after removal, place it in an
electrostatic-safe container.
To insert a memory module:
a. Align the keyed (notched) edge of the module with the
keyed area in the memory slot 1.
If you are inserting a single memory module into a vacant
memory compartment, insert the module into the lower
slot. (The following illustration shows a memory module
being inserted into the second slot of a memory
compartment that already contains a memory module.)
b. With the module at a 45-degree angle from the surface of
the memory compartment, press the module into the
memory slot until it is seated 2.
c. Push the module downward until the retention clips snap
into place 3.
9. To close the memory compartment, align the tabs on the
memory compartment cover with the cover slots on
the notebook, and then slide the cover over the memory
compartment until it is seated 1.
10. Tighten the 2 memory compartment screws 2.
11. Replace the battery pack, reconnect the notebook to external
power, and then restart the notebook.
Hope this helps. If you need anything else, don't hesitate to ask. Also, here is the manual for your machine with more instructions. Pretty handy.
Happy Holidays!
-TJ
Dec 16, 2008 | Compaq Presario Notebook
Memory Upgrade for Compaq Presario 2580US
no 'coz these two memory card differ in size and slot especially when the mainboard doesn't support ddr2
Nov 18, 2008 | Compaq Presario 2580US Notebook
Memory problem
Hi
Compaq Presario 700z notebook PC supports 128MB, 192MB, 256MB, 384MB PC 133 SyncDRAM (SDRAM). The Max Capacity is 384MB.
On this basis, I agree to upgrade the BIOS to support a 133Mhz (PC 133) memory module (DIMM).
At current DIMM capacity and prices, ensure the total memory capacity does no exceed 384MB. On the same note, a 512MB DIMM or two 256MB DIMMs are not supported. The best combination to achieve 384MB will be one 128MB and one 256MB DIMMs.
Compaq Presario 700z notebook PC - Product Specifications - http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00009013&lc=en&cc=us&dlc=en&product=95526&lang=en
Regards
Mike
Mar 27, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq Presario 1200 Notebook Logo
49 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
