Question about Running
What can I do with my old running shoes? - Running
    Problem Solver:
  • 10 Answers
Give it to the needy one. If you don't use your old stuff then you can donate it. And after that, you can buy new shoes for yourself. If you want an option then I would suggest you visit Best Weightlifting Shoes to purchase best lifting shoes at a very decent price. Here, you get full details about various running and lifting shoes with their pros and cons, it really helps you to grab the best one under your budget and requirements.
Posted on Jan 22, 2018
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 63 Answers
You can donate them; Nike Reuse-A-Shoe program (www.nikereuseashoe.com) accepts donations of all athletic shoes that don't contain metal. The shoes are converted into athletic surfaces (running tracks, soccer fields, basketball courts) that are sent to underserved communities around the world. And One World Running (oneworld)
running.com; previously Shoes for Africa) will send your new or gently used shoes to athletes and children in Africa, Mexico, and South and Central America.
Posted on Jan 14, 2013
Adidas SpringBlade running shoe tread splitting
there is not much hope for a solution to this problem as it is common to all shoes sold
Why adidas will not help is that they and all shoe manufacturers are aware that all shoes have a shelf life and if the shoe is not used in a short period of time after manufacturer the material used starts to break down and become unstable
it is the movement of the sole that sets the material and produces a long wear period but shoes ( and boots ) bought and stored will fail quickly with sole problems ( cracking, falling off , bits falling out etc )
Best advice is wear all your shoes on a regular basis for the first few months before leaving them in the cupboard and to get a retailer that will offer a replacement pair if the soles fail in a short period of time as a good will gesture for the customer
of course you can always resort to legal action as there is an expectation by the purchaser that the goods will last for a reasonable period of time regardless of expressed warranty period or not
Jul 31, 2016 | Adidas Mens Springblade Running Shoe
I am running an 100 metres in 2 weeks time...how do i train????
https://m.youtube.com/watch?v=0N3JQs0hpm8&autoplay=1 I hope this helps. I am not a doctor. YouTube will help.
Jun 30, 2016 | Running
What do you think about the roadmap strategy regarding Run 3 game?
The roadmaps gradually be a little more difficult. Within infinite mode the actual alien runs forever until an inability. In every session you generate points which later on could be exchanged for some other tools. There are several pyramids hovering within the space generally in run 3 full game. All those pyramids your own points, which means you should attempt to obtain them no matter what is the cost.
Nov 06, 2014 | Quiksilver Mens Pre-Game Running Full Zip
How do i change the water pump on a cadillac deville
  1. Remove the coolant overflow bottle.
  2. Remove the battery.
  3. Loosen the pulley bolts.
  4. Loosen or remove the drive belt.
  5. Remove pulley bolts
  6. Remove all studs and bolts from old water pump.
  7. Pull old pump off. Use a screwdriver to start it but be careful not to bend the old pump. Also, tapping the center of the pulley lightly with a hammer may help loosen it. If it is hard to get out, check and make sure all bolts are removed. When you remove the pump, there will not be enough room to remove the pulley drum from the pump. This is important to remember when installing the new water pump.
  8. Scrape area off with a gasket scraper and razor blade to remove old gasket. Make sure its clean! Spray it with brake cleaner and wipe clean afterward.
  9. Spray both sides of the new gasket with high tack. High tack works much better than the goop because it is clean, even, and seals well.
  10. Slip gasket in carefully and be sure it fits properly over bolts and is in correct placement against block. Press down to ensure seal.
  11. Spray the inside of the water pump with high tack evenly.
  12. Install water pump into correct place against block making sure that pulley drum is already hanging from new pump or you will not get it on afterward!
  13. Install bolts and studs and tighten down.
  14. Install pulley screws and tighten as best you can.
  15. Reinstall and tighten drive belt.
  16. Finish tightening pulley bolts.
  17. Reinstall battery and coolant overflow bottle being sure that bottle is empty.
  18. Let sealant dry overnight.
^if you follow the book and have little experience that is the best way
I have 11 years experience working on cars and 4 years were at a cadillac dealer
This will give you more hand room I Take the 2 nuts off the bottom of the front motor mount and back motor mount, on the passenger side then I jack up the motor on the passenger side end of the oil pan with a board between the jack and the oil pan. You can jack it up a couple of inches, it gives you plenty of room. I leave it jacked up until I'm done, even putting the belt on is alot easier. Then lower the motor, and put the nuts back on the mounts
Sep 29, 2014 | Gates 1993 - 1993 Cadillac 60 Special...
Can i put my jordan sc 2 in the washer
Yes, of course you can wash your jordan Sc 2 without any problem. Nowadays branded shoes are coming with water proof models,so no need to worry about that.
Apr 15, 2013 | Nike Jordan SC-2 Basketball Shoe Mens...
How long do running shoes last?
Running shoes last roughly between 300-500 miles or between 4-6 months. These are rough estimates as there are several factors that contribute to the breakdown of your shoe, like how often you are running, what surface you are running on, and other factors like heat and weight.
Jan 14, 2013 | Running
How does the iPod Nike running monitor work?
The Nike GPS monitor fits into your sneaker and you can track your progress on your iPhone or iPod with a special app. You can download the app from the iTunes app store.
http://nikerunning.nike.com/nikeplus/v1/pdf/English.pdf
Can you put running shoes in the washing machine if they are air?
I have always washed my sneakers in the washing machine, if they have air bubbles make sure that you wash them on a cold wash and not too hot as this can cause the bubble to expand and rupture.
Jan 13, 2013 | Running
My Nike air max bubble has burst can this be repaired?
It is unlikely that the bubble can be repaired but Nike does have a 2 year warranty depending on the wear and tear of the shoe, you could take them to the store you got them and see what they say.
Running Logo
315 people viewed this question
Top Running Experts
JoseEllis
JoseEllis
Level 1 Expert
Are you a Running Expert? Answer questions, earn points and help others
