Question about Fishing
What bait should I use to catch small mouth bass?
    Problem Solver:
  • 18 Answers
If your local waters allow it, nothing in my opinion works better than medium to large minnows.
Posted on Feb 05, 2015
    Guru:
  • 269 Answers
Crayfish is probably the most useful bate because small mouth bass love them.
Posted on Jan 14, 2013
  • Mitchell Baughman
    Mitchell Baughman Mar 31, 2014
    My number 1 go to lure for smallies is Chompers double tailed skirted grubs. When a rapala or spinner doesnt work the get em! For dark stained water I use green pumpkin colors. For clear water I use white and hot colors. If it is in a shallow river you are fishing put these chompers on a 1/8 oz jighead and for deeper lakes maybe 1/4 to 3/8 oz jighead.
How do you set to work
Hi, I'm Peter. On this style of live trap the solid lid you see on one end is the door that falls when the trigger is tripped. There is usually a couple of heavy wire rods that is attached to the outer end of the door that is connected at a swivel point and an arm that leads down to the "dog" on the side of the cage about midways. This is just a bent piece of metal that rest on another bent piece of metal that goes through the side of the cage to the bait ( Trip/ Trigger, Pan ) You lift the door up and when you do the arm with the bend down by the side of the cage will be in position. While holding that 1st bent arm move the second bent arm that is attached inside to the bait pan, into position to rest against the 1st arm. It will look like two fingers bent at the last knuckle hooked to each other. I put the bait on the pan inside before I set it. The animal will go in touch the bait pan with it's mouth or paw releasing the two bent arms that are held together by the weight of the trap door. This allows the door to fall trapping the animal in the cage. Most of these traps have a carrying handle on top but you MUST be EXTREMELY careful when carrying these traps because if it gets to close to any part of your body or a finger gets too near for example you will get bit or scratched by a highly irritated confined scared animal. It may take a couple of tries to get use to setting it without the door falling but don't give up you will get the hang of it.
Jun 16, 2014 | Advantek 20041B Catch and Release Live...
How can i keep uncle josh carp bait on my hook better?
get a l ice cube tray then put in bait,put hooh in bait and make sure it covers hook then freeze. i add peanut butter so peanut oil will melt first to have a scent trail.
Sep 22, 2013 | Uncle Josh Carp Bait
RAT OR SOMETHING LARGER IN LOFT. WANT TO CATCH
You can get a cage type trap that you can put some peanut butter for bait on the bait pan. They sell them at tractor supply and other places also. It has a door on either end that will fall when the animal messes with the bait trapping them unhurt in the cage. These cages will have a handle on top so you can carry it without getting your fingers in bite range. The smaller cage will be for squirrels, rats, weasels.
Aug 16, 2013 | Hunting
Big mouth billy bass no audio
it should sound like this and the speaker must be dead or the wires are dead
Feb 13, 2013 | Gemmy BIG MOUTH BILLY BASS THE SINGING...
How can I avoid catching my neighbours cat?
Bait your trap with something sweet. Wheat bread with peanut butter spread on it is always a sure attractant, oil of anise; sweet corn and grape jelly are also suggested for nuisance animals. The majority of domestic animals are not attracted to this type of bait. If you do catch your neighbour's dog or cat you have several options:
Jan 14, 2013 | Hunting
How do set a mouse trap - i torn directions off am scare to experiment
Rule number one, BAIT IT FIRST!
Rule number two, always keep your fingers out of the line of fire.
When you are looking at the trap, it is sprung. That is, the mechanism is tripped, and the spring has flipped the bar to the "catch" position. You'll see the bar and spring. Look, and you will see another, single bar, connected on one end to the trap, with the other end loose. This is the trigger release bar. If you look at the bait tray, you'll see a place where the metal is pushed out on the side. This is the trigger. Here's how it works: You fold the spring bar over the bait pan, and hold it tight against the base, keeping your fingers out of the way (see rules 1& 2 above). While holding the spring bar down, use your other hand to bring the trigger release bar over the spring bar and to the bait tray. The end of the bar rests under the notch on the bait tray. As you are setting the bar, you'll slightly reduce your pressure on the spring bar. This pushes the release bar tighter against the notch. When the bar is in place in the notch, the trap is armed. When the mouse is tugging at the bait, the bait pan will shift and release the trigger release bar. It flips backwards, releasing the spring bar, which then catches the mouse.
Best regards, --W/D--
Jun 02, 2011 | Microwave Ovens
How to fish the fish on fishing hole?
To fish on the Fishing Hole just go into the small building and pay to fish, the guide will explain how to do everything. You can fish without paying, but you won't catch fish near as big or diverse as the ones while on the boat. Just get some bait off the side of the small building (the beehive - knock it down and take the larva) and fish with your own baited fishing rod. When you cast the rod, wait until the hook is tugged down by a fish, then pull it up. Btw, you can obtain a glass bottle this way, there's one in a closed off area of the pond beside the small bridge.
Aug 19, 2010 | Nintendo The Legend of Zelda: The Twilight...
On pft for the ds, how do you actually CATCH the
It took me a while to figure this game out. I didn't even hook a fish for 2 days (about 4 hrs). Simply reeling in the line while glimpses of fish swam by wasn't my idea of a good fishing game. I looked for any reviews that gave me a clue how to play this game. There were NONE. I finally figured out on my own a basic strategy that seems to be working for me. Initially you can only fish in one location, one lake. And the object is to get a total catch of 5 lbs of bass or more. You can see this on the initial screen (it gives you your goal to get to the next level). The key is to watch the "fish mood"... watch for a "Yellow Heart" on the top of the screen as you reel in, this means a fish is lured by your bait... When you see this, stop reeling with the "A" button and begin using the control pad... up or down will just bounce the bait... it's a little counter-intuitive to "real" fishing, but if you stop reeling when you see this "Yellow Heart" and simply wait for the fish to swim around your bait, then bounce the bait with the up or down control buttons, the fish will usually take the bait. Then simply reel them in being careful not to reel too fast... using the "A" button, don't let the meter go to high or too low... simply let off the "A" button if the meter gets to high or low... eventually you'll be able to reel them in by pressing and releasing the "A" button. Likewise with the "yellow heart", also watch for a "red exclamation", this indicates the fish is trying to bite the bait. Use the same method simply waiting for the fish. If you never see either of the two fish moods (yellow heart or red exclamation), then you'll need to either change direction of your throws, or change bait. I've conquered a few levels with this method after many hours of not even a bite. It's a shame this game doesn't give you any of these hints. And even with the catches, the game is still quite lame. Graphics stink, realism is non-existent, and the game is counter-intuitive and though not quite as boring once you start to catch fish, it's still just a bit more exciting than watching paint dry. Hope this helps someone out there that was as lost as I was, and please, do yourself a favor if you haven't bought this game yet... don't.
Jul 29, 2009 | UFO Interactive Professional Fisherman's...
Fishing Logo
973 people viewed this question
Top Fishing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Steve P
Steve P
Are you a Fishing Expert? Answer questions, earn points and help others
