My dial goes in and pulls out, but now won't the cycle
A couple days ago, my washer flooded my garage. When I looked in the tub, it was still full of water and water was still coming into it. It did not look like it does when its filling. I could not turn off my water supply, it continued to run. I tried to use the dial to get rid of the water, but my dial wasn't working right either. Help!
  • Washing Mach... Master
  • 17,130 Answers
Possible that the timer program unit has failed and so does not go into the program cycle. Check and see if there is any loose connections, remove the front panel to confirm the connections. If not the estimation for a new timer and the feasibility to replace must be thought of.
Posted on Jan 14, 2013
  • 76 Answers
SOURCE: Maytag washer PAV2300 water over flow
tidalwave If the water continues to flow even when the washer timer and the power to the washer are off then you are right and the water inlet valve has to be replaced. If it does it only when the washer is on then it could be different problems. In that case the first thing you have to check is the water level switch. This is the device which controls the water level. Remove the power first.Open the control panel and you will see the switch on the left side. There is the clear plastic hose connected to the switch. Make sure the hose is not loose. This is one of the most common cause of overflow. If it got loose, drain out all water from the washer before you reconnect the hose. If this is not the issue then you have to check the continuity across the water level switch therminals. When there is no water you should measure the continuity across therminals 11 and 12 (gray and orange wires). Whet the tub has filled up with water you should measure the continuity across therminals 11 and 14 (gray and light blue wires). If the continuity is wrong replace the water level switch. If you are going to do it, make sure there is no water in the tub before you will remove the clear plastic hose from the old switch. Good luck. Gendos. post back...
Posted on Jul 08, 2007
the dr
  • 447 Answers
SOURCE: Kenmore 70 Series Top Loan - Fill Cycle won't stop when full
Does the water stop when you push the timer in or are you having to shut the spigots off?? If it stops when the timer is pushed in then you have a problem with the pressure switch. There are quite a few tricks to axcessing your machine's components but if you are handy ill attemt to help.
Posted on Jan 12, 2008
SOURCE: Whirlpool Model LSV6234AWO
door switch bad?
Posted on Oct 18, 2008
  • 12 Answers
SOURCE: washer fills but won t advance to the next setting for all cycle
Do you hear the ticking of the dial moving? if so it could be that the points aren't getting connection to cycle it threw the various cycles
Posted on Nov 22, 2008
ginko
  • 19396 Answers
SOURCE: washer fills up only half way but water keeps trying to fill tub
That is because the water level switch get stuck when water level reaches that particular point.
The water level switch is activated either by a floater sensor or by a membrane sensor that detects water pressure/volume, depending on the model.
On washing machines it is usually a membrane switch, and that is faulty on your machine.
Posted on Feb 20, 2009
I need a detailed diagram for my Amana Washer model #ALW540RAW
The pressure switch sends the signal that tub is full and agitation should begin. As a rule though pressure switches are long lasting parts. Usually the problem is in the tube that goes from the switch to a bulb or box on the side of the outer drum. The hose can become disconnected, for example if machine was recently moved, or even a severely unbalanced load. Sometimes a tiny piece of lint can obstruct the hose from the bulb end.
http://www.appliancepartspros.com/parts-for-amana-alw540raw-palw540raw.html
Hope this helps.
Jan 21, 2013 | Amana Clothes Washer / Washing Machine...
Water would not shut off and flooded garage? When do you know if your dial to start machine is broke?
Possible that the program timer controller has failed . Also the inlet valve or the seal was faulty to release water to overflow due to faulty action of the timer. Check cost of timer with cost of new machine and decide.
Jan 14, 2013 | Washing Machines
Splendide 2000S Washer/dryer won't wash/dry. Noise then stops, then dial clicks around endlessly.
sounds very much like the bearing has seized on the drum.
can you turn it by hand?
I'm betting it's either stuck or REALLY stiff
Apr 16, 2017 | Splendide 2000S Front Load Washer / Dryer
Why is it that my washer is not completing the spin cycle,it is still very wet when it stop??
Hello there and welcome to fixya
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler
To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
If it's spinning when you lift the lid, the coupler is fine.
If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning
If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve
Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Sep 12, 2011 | GE Washing Machines
Just replace motor coupler a few days ago...now washer filled up, washed & got to rinse cycle then stopped. Turned dial back to wash cycle, won't work. Checked lid switch, not broken. Jumped outer...
since the coupler is new and lid switch was jumped i would be looking at the connections on the motor plug that you disconnected to replace coupler depending on your exact model there is the main plug the 2 wires on the capicator and a smaller plug. BUT FIRST recheck lid switch what must be jumped out is the connection leading up to control panel and NOT the part in the cabinet
to me a appliance tech w/30 years experience it sounds like a bad lid switch!
Aug 10, 2011 | Kenmore Washing Machines
HI: My washer will not drain all the water out at the end of the wash can you help me out
Hello there and thank you for choosing fixya
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Aug 04, 2011 | Frigidaire Washing Machines
Maytag navigator washer not draining all the water out
Here are some things for you to check out
Please read fully this covers a couple of different brands but it is all the same things to check ok?
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jun 23, 2011 | Maytag Washing Machines
Clothes wet after spin
Hi, if clothes are wet after spinning, check.......
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag), a worn clutch (GE/Hotpoint), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Apr 13, 2011 | Whirlpool LSR8433K Top Load Washer
Washing machine
Almost, I hope you put the tube back on. This goes on the pressure switch and the pressure switch determines when the tub is full according to the load size. I don't know what post you read, there's been so many. You have a couple of things to check here. First, make sure the hose going from the pressure switch to the tub is clear. Blow through it. If it's clear it's possible you have a faulty pressure switch. If that tube is not secure on the switch and the tub you will overflow. If the pressure switch is faulty, you can overflow too. Catriver.
Aug 24, 2007 | Kenmore 45081 Front Load Washer / Dryer
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
