Question about Fisher and Paykel GWL11 Top Load Washer
My fuse from the controller keep getting blown out.
Hi, I have F/P GWL11 top load model. Yesterday I was unable to turn the unit on after the first successful load.
I found out from this website that the 3AMP build in fuse from the controller is blown out. I used the meter to test it and it was blown out. So, I purchased a fuse housing and 3AMP 250v fuses. I also removed the original fuse and replace it with fuse housing to hold new 3AMP 250v fuse.
I got the power after I put all back together with new fuse but once I start to use the machine the fuse get blown out at spin cycle and sometimes it complete the wash successfully and last trigger to turn the system off will blown the fuse out.
I also check the pump from the bottom of the washer and seems ok and it is not grounded either. I did also take out the flywheel and check the coil and seems to be ok. I didn't see anything wrong with it or smell anything.
My question is following:
1. Is the controller blowing the fuse out? Do I need a new controller?
2. Do you think the keypad is causing the fuse to blown out?
  • 1 more comment
  • jitan2004 Jan 23, 2009
    I do not see any water on the ground nor any where on the pump and equipments under the washer. I only see three parts.
    1. Water pump. Seems good not hot and I also took it out and tested it with the meter and there is no ground. So, i think the pump motor is good.
    2. I also see Y shipe pipe connection with relay (I think) seems to be ok and not wet.
    3. I also see the big round flywheel directly under the bowl to hold the cloths. I took out the flywheel and check if there is any water, damaged and burn coil but seem ok.
    4. I do not see any water within controller compartment. It is dry.
    Should I check anythng else. I can buy more fuses and try to narrow doen when exactly the fuse gets blown.
    I think I solved the problem. The original fuse is a time delay fuse TR5 type with following writing on it. T 6,3A250V.
    I made a mistake and translate into 3Amp 250V. After looking into TR5 fuses, I found that it is 6.3AMP 250V.
    Now I am using fuse with rating 6.3AMP 250V and seems to work correctly.
    I believe there is a reason for having time delay fuse in the circuit instead of normal fuse. So, I will change back to time delay fuse in near future but for now I need to do my currently laundry so I will stick to normal fuse :-).
    Thanks for all your support.
  • Jidza
    Jidza May 11, 2010
    Is there any water leaking? A partially clogged drain in the outer tub can cause water to spill over the top and maybe cause a short. Or there could be water leaking underneath during the extract. A tiny spray into the motor would blow the fuse
    Does the unit labor? If there are bad motor bushings or a bad tranny the motor could be overheating under the strain of spinning. The motor would already be hot from the agitation cycle.
    Keep in mind that the motor spins backwards during the extract cycle , using different circuitry in the motor.
  • 145 Answers
With all due respect, there is some rather incorrect information in your response Jidza.
These washers are direct-drive and do not have any transmission, nor does the motor "spin backwards during extract". I think you are confusing a Fisher Paykel machine with conventional motor-driven washers. The "motor" is not a self-contained unit, it is really a "drive unit" consisting of a stationary stator/RPS sensor and rotor that either spins in a circular motion to drive the basket for the extract cycle, or it will "pulsate" to mimick the action of a transmission for the agitate cycle. There is no belt or gears or any of that. It's a brilliant design that eliminates many of the moving parts on the typical American washing machine.
With that said, in regards to the original post, the diverter valve, water pump and water inlet valves all are possibilities for a popped fuse in the controller, as well as a fault in the circuitry in the controller itself. Visual inspection of the pump or a simple continuity test is not enough. You need to check the specific resistance of the coil for the water pump, as it can be out of spec and cause the control to fail.
Some of the other experts do not approve when some of us suggest that obtaining a service manual would be the best cause of action but in this case it is warranted. These machines are not like "conventional" washers, they are, for the most part, electronic in nature and proper understanding of the circuits involved in the various cycles and functions makes servicing them much easier and your chances of sucess in repairing them much greater. You can obtain a detailed service manual for the GWL11 here:
My answer is not intended to insult anyone, I'm trying to help the original poster.
Posted on Jan 30, 2009
Power panel won't light up. Checked electricity to washer. It's ok.
motor control fuse has blown. this has happened because there is a short in one of the other components.
Oct 09, 2013 | Fisher and Paykel GWL11 Top Load Washer
Gwl10u2 fisher paykel washer iwl15 can't get it to turn on? Checked the outlet,it's ok. Tried another outlet, still nothing! Help!!!
the fuse on the motor controller has blown. you can replace this fuse, but you will most likely have a short circuit / fault in the pump or motor. check for signs of wear on these, and check for earth faults before re powering machine with new fuse / motor controller.
Sep 17, 2013 | Fisher and Paykel GWL11 Top Load Washer
That model would need more than just a fuse,
A lot of other parts in the board are blown as well,
Have a technician look at the board,
Before you buy a new/recondition board.
May 20, 2013 | Fisher and Paykel GWL11 Top Load Washer
Gwl11 will not power on
It could be the 4Amp fuse in the motor controller board that needs replacing.
Dec 29, 2012 | Fisher and Paykel GWL11 Top Load Washer
I have a Fisher & Paykel GWL11 and it has completely stopped working no lights will turn on. I have checked my fuse box and i don't have any blown fuses. please help
Hi there you need to replace the motor controller under the touch panel, remove the 2 screws on back of touch panel and pull touch panel forward, the motor controller is the big one on the bottom, remove it and replace, you cant get the wiring wrong they are made only to go into 1 hole,
Dec 04, 2010 | Fisher and Paykel GWL11 Top Load Washer
Drain pump and motor control board was replaced. Entered the load size and when to start the machine and the display lights went out. Unable to do anything with the display panel now. I have power at...
Hi just read your posting.Sorry to ask these questions but why did you replace the control module and pump?When you turn the power off then on at the wall does your machine light up the display and give a beep as well? Did you hear a popping sound when you tried to use the machine?Did you smell anything burning?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Sep 20, 2010 | Fisher and Paykel GWL11 Top Load Washer
Hi fuse has blown on wash machine but plug looks completly sealed.can you help please
Hi just read your posting.Are you talking about the fuse in the motor controller?Is your model the US model and has a fuse in the plug?If it is the fused plug type did you test for power at the control module and found the fuse on the plug was blown.Please reply with additional information and I can help you rectify this fault.Looking forward to your reply.
Sep 06, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
769 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
