I had the same issue twice (2 diffrent devices) on LG Blue-ray HX-906 - stuck on "please wait" after switching it on. It turned out to be defective mainboard - main BGA chip (the one with black radiator) has some problem with connection to mainboard. Here is how to repair it:
- dismount the mainboard
- take off the radiator from the main chip
- put alluminium foil around the chip to avoid unnecessary heating up of other parts of PCB
- heat up the chip using air hotgun to about 200 celsius for about 5 minutes.
Mother board faulty. some times a software update resolves such problems. But for the you have to consult the authorize service center.
If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
1) power on the player with no disk in the drive 2) pres pause on the remote 3) enter "314159" on the remote 4) enter "0" on the remote (0 = all regions, 1 = region 1 etc) 5) press pause on the remote 6) power the player off and then back. Hopefully this helps someone else! (Info from http://forums.dvd-swaps.co.uk/archive/index.php?t-2327.html)
Check working condition hardware. May be malfunction Main Boar or AMP. Unplug cable (wires) attached from Power PCB Board and main board to AMP PCB Board. Turn ON, if again comes message " Please wait" and unit sot down itself- Malfunction main board. If unit booted UP -OK -replace AMP board. Partsare availableon our web
1. Remove disc from tray. 2. Switch off player and unplug power cord. 3. Wait 30 seconds, then reconnect power cord. 4. Turn on player with remote. Wait for player to finish loading and display 'no disc'. 5. Press enter on remote. (There will be no on-screen response.) 6. Press 8, 4, 2, 6, 9 on the remote. (There will be no on-screen response.) 7. Press enter on the remote. Player will automatically shut off. 8. Turn player on. 9. Turn off. 10. Turn player on then off again. 11. Player is now region-free.
did you follow the steps carefully. the number "9" on this hack is region free. you could go back and try the hack again,following the steps,to see if it works.
