Question about jWIN Electronics iLuv iMM155 - clock radio with Apple Dock cradle
I have an ILuv IMM155 & cannot figure out how to change it from 24hr time back to 12hr time
CHANGE FROM MILITARY TIME TO REGULAR
Hold down the MODE button until the time starts flashing. Then use the buttons to cycle through the time, date, and so forth until you see 24hr. On that menu tap the buttons you use to change the setting to cycle it to 12hr.
Feb 01, 2015 | Casio LA670WA-1 Wrist Watch
I just bought an adidas ADH4033. I have read through the manual thousands of times and have figured out how to change the hours on the watch but still cannot change the minutes, date, 12/24 hour, or any...
this might help. press and hold top right button to change to T1 or time 1. press and hold top left button and u will see ' light on/off' on display. press bottom left button to set chime. press again watch will show 24hr/ 12hr and current time set on watch. 12hr/24hr should be blinking. press top right button to change to preferred hour. press bottom left button to navigate to hour, min,sec use right buttons to select numbers.
Aug 27, 2011 | Watches
How do you change time from 24hr. to 12hr.
GO to clock settings.
turn autoupdate off.
exit menu
go back to clock settings.
select time format preference
exit menu
turn autoupdate back on.
May 07, 2011 | Motorola Mobility RAZR V3
After a power outage, my Bose radio went to military time. I've tried to re-start it by unplugging, re-unplugging, etc. Help!
To switch between 12hr and 24hr format:
1) Turn your Wave Radio off
2) Press and hold "Clock Set"
3) Press "On/Off" to switch between 12hr or 24hr format.
Dec 27, 2010 | Bose Wave Radio
24 hour clock
Sometimes if you depress both the Hr/Min buttons this toggles the time 12hr/24hr, Im not positive on this one..You can always check with a dealer or look in the owners manual if you have one. Or just learn military time..lol..
Mar 24, 2010 | 2006 Audi A4
Setting clock in 12 hour format instead of 24hr
You can download the manual here: www.topeak.com/mediafiles/assets/341/file/1
By performing a reset and setup under section A. of the manual you can select 24 or 12hr time.
Jan 06, 2010 | Topeak Panoram V12 Mini 12 Function Cycle...
Casio module 3054, to set military time
You hold down the smallest protruding side-button, until the digits blink.
Use the other high protruding side-button to change to 12HR/24HR.
The 24HR mode is for military time.
Practice with the buttons, repeat as necessary.
Nov 27, 2009 | Cell Phones
I need to reset my tomtom clock from A.M. to P.M. It's a 340-S
i have a tomtom one, not sure if they are all basically the same, but try this. you should be able to via the settings menu. tap screen, tap 'change preferences' and scroll through the screens until you see 'change time' use the little arrows to set the correct time, and then select 24hr mode. if you are not happy with 24hr mode then select 12hr mode. if you know it is pm but sat nav is showing the correct time but in am, then simply increase the hours by 12.
Aug 05, 2009 | GPS
Don't know how to set alarm clock or timer - have set clock OK
To set the Time all you have to do is hold memo/c.adj while on standby, the screen will flash 24hr if you press tune it will flash 12hr pick weather you want 12hr or 24hr and then press memo/c.adj to set the hours press tune then hold memo/c.adj to get to the minutes and then press tune to get the minutes set
May 03, 2009 | Audio Players & Recorders
Set clock time to 12hr display
work the knobs ,hold it down for 10 secs and it should change
Oct 26, 2008 | 2004 Renault 181
jWIN Electronics iLuv iMM155 - clock radio with Apple Dock cradle Logo
74 people viewed this question
Top jWIN Electronics Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a jWIN Electronics Audio Player and Recorder Expert? Answer questions, earn points and help others
