I have a Hotpoint WML540 Aquarius which has stopped mid cycle, all the lights are flashing and it is stuck on 'pump out' can anyone please advise how to fix this?
  • Washing Mach... Master
  • 17,130 Answers
Switch off the machine for sometime and then power it while holding the play/pause button. If the machine does not reset but continues to flash it is possible that there are errors within or is a failure of the panel. Check the door switch, check the connectors and finally check for moisture in panel- If so use a hair dryer to mop up the moisture by heating the panel slowly,
Posted on Jan 14, 2013
    Sergeant:
  • 282 Answers
Knock off the electric and unplug the machine . Remove the Rear cover. On the lower right hand side is a pump and rubber filter unit. This gets clogged up with whatever falls out of pockets such as Coins , buttons ,Hairclips and underwires . You will need a small screw driver to open the clamp up by prizing the teeth apart . Make sure you have something on the floor like rags or towels to soak up the excess water still in the pipes . You may be able to get a small tray underneath if the washing machine is tilted forward to gain access..
When the filter part is off , Remove the white insert and take out the Ball and whatever is the blockage, Refit the filter unit making sure the white plastic part shown joins into the slots of the one still on the machine. Once all the clips are secured and all is complete.
Leave the back off for now and replug the machine in and try a short rinse programme to see if if leeks when pumping out.
If it is dry underneath the machine replace the rear cover and push the machine back into its usual place.
.. I have a Hotpoint WML540 Aquarius which has stoppe - hotpoint-wml540-aquarius-stopped-mid-hido5oczi4wv25hkp4nrzdid-1-0.jpg
Posted on Dec 23, 2014
  • 1462 Answers
SOURCE: Machine stuck mid cycle
filter blocked or brawire or similiar in drain pump take off cover at bottom rear. take of hose going to bottom of tub. filter is in that hose you will have water everywhere. one way round that is to lay machine on side - left side down viewed from rear
Posted on Mar 20, 2007
SOURCE: Hotpoint Aquarius WD440 Error
Remove the white plastic cover on the back near the bottom. To the right as you look at it their will be a black concertina pipe with a hose clip on its top edge. Undo this and pull the pipe downwards to reveal the filter. There will be a plastic ball inside (which is supposed to be there) remove this and clear out the cr*p.
Re-assemble as removal.
That should fix it
Posted on Apr 27, 2009
SOURCE: my hotpoint aquarius wd440 has flashing lights
First of all try cleaning the filter inside the back as described by others if this does not work there is a filter in the top. how you clean this is quite easy. all you do is remove the top of the machine by undoing the 2 screws at the back then pull top top backwards when you have removed the top you well see a large metal casing on the left if you are looking from the the back of the machine the filter is in there to remove the casing you pull the small pipe off then undo 5 star headed screws then gently pull the casing off noteing that there is a large pipe at the front when you have remover the casing you will see the filter (the small pipe you removed at the start fits on this filter) clean the filter then put it all back together.
Posted on May 17, 2009
SOURCE: I have a hotpoint aquarius WF250 1500 spin. The
I've just had this exact same problem. Can you tell me if you have had any success with fixing it please?
Thanks!
Dan
Posted on Oct 14, 2009
  • 51 Answers
SOURCE: WMA 54 Hotpoint Aquarius washing machine lights flashing
the problem here is the machine is not emptying when its supposed to, you will find it is stopping at the rinse cycles. there is a sump underneath the machine that needs to be emptied. From my experiences, 9 out of 10 hotpoints that i would of repaired with the same problem as you are having is usualy caused by using the color catcher sheets, they are a disaster.
appliancesdav@hotmail.com
pallesappliancerepairs.com
Posted on Feb 03, 2010
Hotpoint WML540 stops mid cycle, end of rinse going onto spin. Key lock light flashes, it also makes a banging sound as though washing trainers and then there are some clicking sounds before it stops. If...
maybe the concrete balancing weight has come loose and the fact that most of the water has been drained off when you turn it off for 10 seconds it does not have the one-sided affect anymore also check the damping springs as one may have come off in the violent spin eric
Dec 19, 2017 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarius WML540, HAS JUST STOPED WORKING ITS ONLY OVER 1 YEAR OLD,WILL START ANY WASH BUT JUST STOPS WHEN IT REACHES THE SPIN AND DRAIN AND ALL LIGHTS START TO FLASH VERY FAST CAN YOU HELP.
Could be the pump blocked or not working, check the pump for blockages or wiring faults. For Hotpoint, Creda and Indesit error codes that include flashing lights visit selfix-uk
Mar 20, 2010 | Washing Machines
Hotpoint Aquarious WF210. Machine stops mid cycle...Reduce Creases and Time Saver lights flashing. On-off flashing quickly. Any suggestions ?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} For Hotpoint, Creda and Indesit error code definitions use this link. This will give you some idea as to where the fault may be.
Mar 06, 2010 | Hotpoint Aquarius WF210 Front Load Washer
I have a Hotpoint Aquarius WML540 washing machine and after the wash and the rinses, all the lights start flashing and the programme will not go any further. I would like to know what is causing this and...
I would like to know what is causing this and how to solve it.
Sep 22, 2009 | Washing Machines
Thanks!
Dan
Sep 17, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint washer/dryer aqaurius stopd mid cycle with message F-01
f01 is a motor short circuit. you will probably need a new one and maybe the circuit board that powers it if all the lights went out unless the fuse is gone.
Jan 28, 2009 | Hotpoint Aquarius WD63 Front Load...
Washing machine stops mid cycle and lights start flashing
Drain the water by lowering the hose into a bucket or something and then try it on spin, if it spins o/k then you probably have blocked pump or filter.
The filter is located in the large black hose that is fastened to the bottom of the drum, remove and clean.
Hopefully this will solve the problem.
Plz rate this solution.
Thanks.
Dec 17, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Washing Machines Logo
817 people viewed this question
Top Washing Machines Experts
