Question about Microwave Ovens
WHAT IS THE BEST MICOWAVE??????? - Microwave Ovens
  • Microwave Ovens Master
  • 9,098 Answers
I'm not sure I can say which is best, but on one hand I would recommend the one with the longest warranty.
If you get an over the range type, I would recommend buying an extended warranty / service contract.
The Electrolux / Frigidaire / Whirlpool / Maytag family of microwaves as well as most Kenmores these days are made by LG.
GE microwaves are made by Samsung.
Replacement part prices will be much cheaper if you go straight to the "source" and get an LG or Samsung.
Hope that helps.
Posted on Jan 23, 2009
Is the micowave dangerous and can we fix it.
You did not provide the make or model of your Microwave, but to give you a generic answer, it sounds like there may be an issue with the control board or the door interlock switch.
If you are not familiar with repairing electrical appliances, it is best to call a qualified service company or bring it to a repair center. If you have the owner's manual or user guide, there should be some information about where and how to have the oven serviced.
Jul 21, 2015 | Microwave Ovens
I have a GE JVM2070SH001 micowave . I do not have power to the under unit lights (work,nitelight) but everything else works fine. What is the likely problem?
Either the control board or the switch itself. I can't remember if that on is part of the main keypad or not. Does the unit beep when you press the light button? If it does then you need to follow the wiring to a point where you have power. Best guess...control board
Dec 05, 2012 | GE Profile Spacemaker Over-the-Range...
Everthing works will not heat
Micowave is not working or emitting a wave form. Needs to be replaced. There isn't a way to replace this in a cost effective way. Replacing the microwave is the best, and most cost effective solution to this problem.
Nov 16, 2010 | Microwave Ovens
Micowave is not heating up, and is making a
It may be a shorted diode in the HV power supply for the magnetron. Open the case to get to the part. Unplug the machine before opening anything. This is normally a high voltage area when running.
Jul 17, 2009 | Microwave Ovens
Kenmore micowave oven interior light
THe microwave has to be removed from the wall and then the outer cabinet has to be removed to get to the bulb. Do not do this with the unit plugged in and do not do this if u don't know how to work on a microwave as there is a shock hazard.
Jan 26, 2009 | Kenmore Microwave Ovens
Panasonic Inverter Micowave only runs for four seconds
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Dec 24, 2008 | Microwave Ovens
Kenmore micowave
IF IT IS THE KEYPAD THAT IS LOCKED, ONE OF THE TOUCH PADS SHOULD BE HELD FOR 5 SECONDS TO UNLOCK THE
TOUCH CONTROL.YOUR INSRTUCTION MANUAL WILL TELL
YOU WHICH PAD TO HOLD. IF NOT AVAILABLE, TRY EACH PAD, ONE AT A TIME. HOLD EACH PAD FOR 5 SECONDS.
IF NO RESPONSE, TRY THE NEXT ONE. WHEN YOU FIND THE ONE THAT UNLOCKS THE CONTROL, WRITE IT DOWN
FOR FUTURE REFERENCE. THAT PAD WILL ALSO LOCK THE CONTROL WHEN HELD FOR 5 SECONDS.
Mar 28, 2008 | Microwave Ovens
Sharp Carousel Micowave
One or more door switches is bad, or the switch mount is loose or broken. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Jun 23, 2007 | Sharp R-320H Microwave Oven
Microwave Ovens Logo
57 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
