Question about HP Casio FX-9860GII Graphing Calculator- FX-9860GII- Pack of 2
Range error press exit - HP Casio FX-9860GII Graphing Calculator- FX-9860GII- Pack of 2
Error code sc545
The Error Code SC542 or Sc546 could be a caused by a few reasons. There is a temperature problem with the fuser unit, the roller thermistor is bad, or the BCU Board is bad.
1 metode to reset Ricoh Error code sc542:
To clear the code:
Hit the yellow "Clear Modes" key
Press 107 on the number pad
Press and hold the "Clear Stop" for 10 seconds until you get a new screen ...
Press the "Copy SP" Button on the display
Open the front door
Turn front left power switch off and on
Shut the door
The error code is now cleared.
To Enter and Exit the SP Mode
1. Press yellow "Clear Modes" key .
2. On the operation panel keypad, press 107 number
3. Hold down red "Clear" key more than 10 seconds.
The Copy SP is displayed.
4. Press "Copy SP" and go to the code SP5810, press "Execute"
5. To exit the SP mode, just press Exit in the upper right corner of the SP mode
screen. Power switch off and on and the error code is now cleared.
Hope this his helps, thanks for using fixya.
Aug 28, 2014 | Office Equipment & Supplies
Kitchenaid kgrc608
Try this,
FAULT ERROR: F1 E3NOTE:Make sure harness to P1 connector is correctly installed
per wiring diagram before performing the following steps:
STEP 1 Power off and wait 5 seconds.
STEP 2 Power on and wait 5 seconds.
STEP 3 Press the following keys:
CONVECTION - CONV. BROIL CLEAN BAKED GOODS 190 TIMER SET
NON-CONVECTION - CLEAN STOP TIME 0 OVEN LIGHT 1
STEP 4 Press START.
STEP 5 Make sure Timer ID is the same as the oven.
STEP 6 Press CANCEL to exit.
Nov 27, 2012 | KitchenAid KGRC608LSS Gas Kitchen Range
Error code f1 e3
Try this out,
STEP 4 Press START.
Nov 27, 2012 | Kitchen Ranges
Range error on casio graphing calculator
Open the window configuration ans set Ymin to -10. You can also access the ZOOM function and select Zoom Standard.
May 07, 2012 | Casio FX-9860G Graphic Calculator
Hi i have a vision fitness 9450 hrt and i'm getting an error message: E6
Typically an E6 error message indicates that the machine needs to be recalibrated because the elevation motor is out of range or that you have a loose cable connection. Below are the auto calibration instructions. Please make sure that no one is on the machine because it will speed up quickly.
STEP 1 ENTER ENGINEERING MODE
With the safety key in place, hold "ELEVATION UP" and "SPEED
DOWN" buttons for 5 seconds. Software version will appear in display
window for a few seconds before model displays.
Press "STOP" , "ENG1" will appear in display window.
STEP 2 AUTO-CALIBRATE
Press "ELEVATION UP" until "ENG4" is displayed.
Press "SELECT" , display will read "AUTO".
Press "START". Unit will calibrate, when finished "END" appears in
display window, then "ENG1".
STEP 3 EXIT ENGINEERING
Press and hold "STOP" to exit engineering mode
I would also suggest that, with the power to the machine off, you check all of the wire connections underneath the motor cover, the assembly connection that sits where the mast meets the console and underneath the faceplate. Check to be sure that all of the connections are secure and that the pins within the cables are seated properly.
If you are still having any problems you can reach a knowledgeable Vision Fitness Representative toll free at 800-335-4348.
Mar 29, 2011 | Dmm Vision Fitness T9500 Treadmill
The stove is stuck on celsius. I pressed and held the CANCEL AND BAKE buttons for 3 seconds and nothing happens. I don't know how it got on celsius. How do I get it back on Fahrenheit?
You can get Whirlpool manuals from http://www.whirlpool.com/custserv/index.jsp
Just got it from there:
The temperature is preset at Fahrenheit, but can be changed to
Celsius.
Style 1 - Electronic Oven Control
To change: Press and hold PRECISE CLEAN for 5 seconds, and
"TEMPERATURE UNIT CELSIUS" will appear in the display.
Repeat to change back to Fahrenheit.
To exit mode, press OFF/CANCEL.
Styles 2, 3 & 4 - Electronic Oven Controls
To change: Press and hold BROIL for 5 seconds. A tone will
sound and "°C" or "°F" will appear on the display. Repeat to
Mar 18, 2011 | Whirlpool GR563LXS Kitchen Range
My Kenmore oven won't work there is a PF 5AB error
The PF on your control indicates a power failure and should be removed by pressing the cancel button. The 5ab code indicates the range is in the SABBATH mode.
If a power failure occurs when the SABBATH mode is set, the oven will return to the OFF mode and will turn the power OFF to the oven.
To ENABLE SABBATH mode:
* Open the oven door
* Press STOP/CLEAR
* Press both the HOUR "UP" and "DOWN" arrow pad at the same time - and hold for 5 seconds.
SAB ON will disappear from the display.
To disable SABBATH mode: Repeat the steps above and SAB OFF will appear.
To set the SABBATH mode for use during the SABBATH/Holidays:
* Press BAKE
* Pres TEMP "UP" and "DOWN" Arrow pad to enter a different temperature other than 350 degrees. (Between 170F and 500F)
* Press COOK TIME
* Press HOUR/MIN "up" or "down" arrow to set cook time
* Press DELAY START to set a delayed cook time (optional)
* Press and hold TIMER OFF for 5 seconds
SAB will appear on the display indicating it is ready.
* Press START
* To STOP cooking - press STOP/CLEAR
* To exit the SABBATH mode and return to normal operation - press and hold TIMER OFF for 5 seconds.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 05, 2010 | Kenmore 71414 / 71419 / 71410 / 71412 Gas...
The oven setting was accidently changed to celcius. How do you get it set back to fahrenheit
Press and hold Custom Broil till it beeps then press off/cancel to exit.
Eric
Jul 03, 2009 | Whirlpool GS460 Gas Kitchen Range
Machine Error 8460N Laser Printer
To get the machine error code
Get into maint mode
Within 2 seconds hit:
menu,*,2,8,6,4
This will put you in maint mode.
Press 82
This will give you the machine error code.
Press stop/exit
press 99 to exit maint mode.
Let us know what the machine error is.
Jan 16, 2009 | Brother MFC-8460N Laser Printer
HP Casio FX-9860GII Graphing Calculator- FX-9860GII- Pack of 2 Logo
41 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
