Machine says clean pump can i do this myself - Washing Machines
  • harvy Jan 14, 2013
    THANKS VERY MUCH just needed a good clean in the pump and pipework was blocked
  • Washing Mach... Master
  • 17,130 Answers
Please check on this link:
cleaning pump
Posted on Jan 14, 2013
Can I remove the pump filter on the WMD960
What was the washer doing that made you attempt this repair? I would say you will need to replace the pump assembly now.
Oct 13, 2016 | Hotpoint Washing Machines
Whirlpool washing machine "clean pump" error light.
take top off machine. look down right side and you will see a disc about 50 mm in diameter, attached to this is a small flexible rubber pipe, take this off at the disc and blow through it,( you will need some type of pipe to connect to the rubber pipe).this worked for me with the very same problem.
Mar 09, 2010 | Whirlpool Washing Machines
Front loading whirlpool machine WFS1072AW which needs pump clean
WFS1072AW has a clip in panel at the bottom across the front.
Removing this will reveal a black plug on the right.
Unscrew this and water will gush out along with (hopefully) the offending coins.
Feb 13, 2010 | Whirlpool Washing Machines
I get a message saying check outlet pipes. If
If you need to clean the filter, then remove the lower rear cover.
Remove large black hose fastened to drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here, and check inside the pump as well.
Hope this helps with your prob, Good luck.
Thankyou.
Nov 26, 2009 | Hotpoint Ultima WD72 Front Load...
Zanussi FS 1355 w Drum not turning
DEFF BRUSHES.JUST HAVE SAME PROBLEM MYSELF NOW AND TOUCHED BRUSH HOLDER SLIGHTLY AND RESTARTED..
Jan 01, 2009 | Zanussi FS1455W Front Load Washer
Machine will not drain at end of cycle - beeping at me
Yes it is a pump problem , if it has a filter, remove and clean same.
If you can't find a filter then you need to locate pump and check it.
The pump will have the drain hose connected to it, trace the hose back to the pump.
Dec 19, 2008 | Zanussi FLE1416W Front Load Washer
Washing machine
whilpool awo/d 4305 light onclean pump can i do this myself
Jul 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Water not draining-is it the pump?
get all the water you can out if possible remove dryer lean washer back against wall remove bottom panel pump is on right side remove hoses but watch for flood almost no way to avoid it unplug power to pump and washer remove bolts from pump clan make sure impeller in pump has not come loose from shaft if unable to clean from hose ports remove body screws around edge of pump to clean
May 05, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
