Question about DeLonghi Magnifica Coffee Makers & Espresso Machines
DeLonghi Magnigifca ESAM4200 not grinding - just makes a knocking sound
Our coffee maker has stopped grinding the beans it makes a knocking noise instead, and the beans jump around in the hopper - but don't fall through to the grinder and grind. It works find with a scoop of pre-ground coffee, but that's not the point. The same problem happened about a year ago, and we sent it off under warranty - but it's nearly 2 years old now, so I'm reluctant to pay to post it off just to get a quote to fix it. Does anyone know what might cause it - could I fix it myself - or how much might it cost to get done? Many thanks
5 Suggested Answers
espressodoc
  • 29 Answers
SOURCE: Bean hopper is full, grinder is grinding...but NO COFFEE!
Sometimes the chamber between the grinder and brewer will clog up. Try: Open the grind all the way up to the highest number. Push the grind button and while grinding move the dose knob (the one with the + - sign toward minus. If it does not kick in and dose try it again. If it does take off then leave it on the high number for 3 coffees. Then while the grinder is turning move the two knobs back to whre they were. If this does not work you can reomve the brew unit and right above where it sits in the machine there is a trap door that you can open. Open it and shove someting like a straw up toward the grinder and you should get a bunch of grounds droppiing down. Then try the above procedure a couple more times. If this does not work you may need to google "Saeco repair" and send it to an authorized repair center.
Posted on Aug 15, 2007
SOURCE: My Saeco won't grind the beans
There's moisture in the grinder & it's clogged - just dismantle the grinder & clean it, then ensure you don't splash water into the bean hopper when you fill the water tank.
Posted on Apr 03, 2008
EsWorld
  • 1618 Answers
SOURCE: Incanto Sirius - grinds but cannot hear coffee getting ground
The chute is clogged or the grind is too fine on the machine. To clean chute remove the brew unit and check to the right, clean chute.
Posted on Oct 07, 2009
SOURCE: ground coffee will not dispense
The beans are hanging up in the hopper and not falling down into the grinder...... wiggle it, give the beans a push, or go to a bean that is not so sticky....
Posted on Jul 31, 2010
DELONGHI ESAM 5500 WON'T MAKE CAPPUCCINO SAYS GRINDS TOO FINE, BUT WILL GRIND AND MAKE REGULAR COFFEE
have you tried cleaning it as described in your user manual,, can you hit the button for regular grind? there are alternatives, a coffee grinder if failry cheap at 10 dollars US,,
Jun 07, 2016 | DeLonghi Perfecta ESAM5500 Fully Automatic...
How do i fix my esam 3400 coffee grinder quantity?
I have change grinding from 7 to 1 ( it depends from coffee beans) and quality of coffee get much better (knob located inside the bean container).
Mar 09, 2016 | DeLonghi ESAM Coffee Makers & Espresso...
Delonghi problems
Do you have dry coffee in the waist bin? do you have water coming ? I can offer you coffee but I can't give you because I don't have it
Aug 16, 2014 | DeLonghi Magnifica 3300 Espresso Machine
Delonghi problems
I had a similar problem which was solved by replacing the infusor. I was able to find a new one on eBay for about $40. Hope this helps.
Jul 28, 2014 | De'Longhi Magnifica Esam4200 15-Bar Bean...
Where can I get my delonghi coffee machine serviced please, I live in Northern Ireland
Kenilworth Electrical Spares and Repairs 253 Harolds Cross Road, Dublin 6w. Ireland email: kenilworthelec@eircom.net phone: +353 (0)1 4968036
May 06, 2014 | DeLonghi Coffee Makers & Espresso Machines
The machine makes a very loud noise when grinding the coffee beans. * Magnifica Espresson Machine *
Even a properly operating super automatic DeLonghi espresso machine makes enough coffee grinder noise to scare your pets and wake you next door neighbors. It's LOUD, no doubt about it. Only if your grinder makes more noise than that do you have a problem.
Jun 23, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Coffee machine Delonghi Magnifica grinding function not working
There are two reasons for this usually. Either the grinder is jammed or the grinding wheel or wheels have broken. Your machine needs to go to a repair shop to be looked at.
Jan 13, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Coffee Grinder on the EAM3500
We just went through the same situation. We opened the top the Magnifica to get to the grinder and removed the four screws to seperate the grinding pieces. Inside we discovered two black fosilized beans/stones! We removed those, cleaned out all the bean dust and it is working like new! Took about an hour.
Aug 31, 2008 | DeLonghi EAM3500 Espresso Machine/Coffee...
DeLonghi automatic espresso machine
do you use the machine often oil in coffee create residue and can accumulate on the grinder and the residue is so thick that it does not let coffee trus remove the coffee bean and were the beans go u should see the grinder teet use a little tootbrush or anything that might fit in there remove the residue and try it it should be good thanks for using fixya pierre
Feb 07, 2008 | Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
158 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
