Question about Brother HL3040CN Laser Printer
HOW TO RESET PF KIT 1 OF HL3040CN - Brother HL3040CN Laser Printer
SOURCE: Brother HL-5270DN PF Kit Problem
I found the answer in another group, from Sunshine3240:
Open the front cover and leave open while completing the following steps:
Turn the printer off.
Hold the 'go' button while turning the printer on. All panel lights should be on.
Release the 'go' button.
Press the 'go' button 2 times.
Pause.
Press the 'go' button 5 times.
The toner light should be off.
The paper light should be on.
Close cover. The ready light should be the only light on.
Posted on Mar 13, 2009
  • 215 Answers
SOURCE: Replace the PF KIT 1 On my MFC 8460 N
that refers to the automatic feed. in other words, your main paper cassette. the MP kit is for the manual bypass tray. if paper is feeding ok and your not having problems, you can reset the message by pressing "menu" " *2864" within 2 secs. now you are in maintenance mode. push "88" should show "parts replacement." using arrow buttons go to reset pf1 kit and press "ok" or "start" to reset. press "stop/clear" to back out to maintenance mode screen. press "99" to exit maint. mode. do not mess with any other settings in that mode as you could render your machine inop. however, you may want to reset the "fuser life" while you are in maintenance mode "88" as both of these messages are supposed to come up at 100,000 pages. chances are unless you've had fuser replaced, that message will be coming up soon also.
good luck,
razors
Posted on Mar 27, 2009
komguy
  • 2306 Answers
SOURCE: pf kit 1
Brothermall.com has all the Brother accessories.
Posted on Aug 20, 2009
SOURCE: Resetting "Replace PF Kit 1" message
Same with me on my MFC 8870DW. The procedure worked perfectly:
1) Turn off printer
2) Press and hold menu button and turn on. Keep holding button until you see maintenance on display.
3) Press 88. This brings up parts replacement menu.
4) Press Up arrow until you see the part you replaced (laser, fuser, pf kit1, pf kit mp).
5) Press the OK button.
6) Power off and restart printer.
But how do I know whether or not I really NEED to replace a PF Kit1? I guess I'll find out if it recurs soon.
Joe
Posted on Feb 08, 2010
angelo_mlc
  • 1035 Answers
SOURCE: how to reset brother mfc
Hi. Here's the procedure.
1) Turn off printer
Posted on Oct 23, 2010
How to reset pf kit mp of brother mfc-8460n?
Hello ,
First you have to enter in service mode , then to go to reset menu , and reset pf kit mp an then to live service mode
1. Service mode : menu*2864 , you have to make it fast until the lcd is on : maintenance mode
2. reset menu 88 , now you have to go to pf kit mp and reset
3. Live service menu with 99 or shut down the mfp and after 10 sec restart
Mar 03, 2016 | Brother MFC-8460N All-In-One Printer
NO NETWORK SETTING SHOW IN LCD PANEL IN BROTHER 8370DN AFTER RESET THE PF KIT 1 MESSAGE.
Hi gurjit: try this..
Reconnect the LAN cable to the hub to verify
that the cable and network connections are good. If possible, try connecting the
machine to a different port on your hub using a different cable. If the connections
are good, the lower LED of the back panel of the machine will be green.
sends me the result.
Nov 26, 2014 | Brother MFC-8370DN Laser Multifunction...
HL-5250 report shows fuser and laser life at 0% and PF kit 1 at 12%
The fuser is a separate component to the drum and toner in this printer. It has a much longer life than them but will run out eventually. Sadly a fuser unit is not a commercially available consumable for this printer either. I would recommend contatcing a printer technicain or Brother directly for a quote on replacing this part.
Apr 12, 2013 | Brother HL 5250DN Laser Printer
I need to replace "PF
Ah the Paper Feed Kit 1 on this unit is pretty easy,
If you remove the paper tray and put the printer on it's back you should see the rollers you're going to replace.. unfortunately the service manual doesn't show this procedure so I can't provide a picture.
If memory serves correctly there should be a long light-blue plastic piece that holds the PF Kit roller assembly in place. If you bend this towards the back of the machine the PF Kit should swing down and you just slide it out, replacement is the reverse of this.
Once you're done you'll have to reset the PF Kit counter by:
Press GO and + together,
you should see RESET PARTS LIFE on the LCD
You can then use the + / - to pick the PF Kit and press the SET key to reset the counter.
If you still have problems let me know via this question and I'll try to help further.
Jun 10, 2011 | Brother HL 5250DN Laser Printer
Have a Brother mfc 8460n reads replace PF kit 1 need to now what that is and how to replace it
Replace PF
Kit1
It is time to replace the paper
feeding kit for Tray 1.
Call Brother Customer Service to replace the
PF Kit 1.
You can read more by clicking here or copy and paste link to your browser address bar:
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002000/cv_mfc-8460n_usaeng_user_d.pdf
then go to page 110 (you can type 110 at the top of the page to quickly get to the page)
I hope this helps. Sorry for the small font
Mar 10, 2011 | Brother Office Equipment & Supplies
I am trying to buy a pf kit 1 for my brother MFC 8670 DM. Where can I purchase this?
Just clean the pick up rollers with water + a dash of meths and a drop of detergent, de-fluff the paper separation shoe and rollers on the paper trays. Reset the PF Kit 1 counter (PF = paper feed) and carry on.
Aug 16, 2010 | Brother Office Equipment & Supplies
How to replace the PF roller on a brother DCP 8065
1.Pull out the paper tray
2.turn the machine upside down
3.push the blue lift arm and pull out the pin of the PF roller
4.then slide the PF roller to the left and pull it out
5.replace it with new one put the pin of the new roller into the hole of the blue lift arm.
6. place the machine on its base.
P.S you need reset pf roller counter after replacement
press "MENU - START - 088"
LCD shows "PARTS REPLACEMENT"
go down with arrow till "reset PF kit T1?" PRESS "SET" key
all done.
Jan 31, 2010 | Brother DCP-8065DN Laser Printer
Mfc-9420cn pf-kit2 reset, how to reset the counter after installing new kit
Press Menu/Set, 7, 4. Press down arrow to select PF Kit 2 and press Menu/Set. The confirmation message appears on display PF Kit 2. Press 1 to reset or 2 to cancel. PRESS 1.
Nov 03, 2009 | Office Equipment & Supplies
Brother HL5150 D printer. PF Kit 1 shows zero left available, and I need to reset teh counter for PF Kit 1
Go here by copying and pasting this link
 http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000000/000026/faq000026_004.html?reg=us&c=us&lang=en&prod=hl5150d_all&Cat=4
 to see the visual aids for your machine at Brother Printer solutions center.
The website mentions that the use of the wrong type of paper could cause this problem.
Dec 10, 2008 | Brother HL 5150D Laser Printer
1) Turn off printer
Joe
Jun 18, 2008 | Brother MFC-8460N Laser Printer
Brother HL3040CN Laser Printer Logo
668 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
