Question about IFB Washing Machines
Burning smell along with fumes came out after a ghastly spin of the drier. after that it can't be switched on. Mine is a front loading washing machine (IFB executive plus).
IFB Executive Plus..Front loading..
  • Ashutosh Jan 14, 2013
    can anybody tell me the reason which triggered this problem?? Thanks pam_thorl388 for ur advice..
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 127 Answers
Don't try to turn on again. Call a service agent for that brand of machine and leave it to them. Obviously a major problem and could cause major damage to your home if you force it on again
Posted on Jan 14, 2013
  • 1314 Answers
SOURCE: washing machine smells like burning rubber!
sounds like you have a broken motor coupling while your down to the pump check for something jamming the pump here is the procedure First unplug the washer and turn off the water. If you have a shop vac take the drain hose out of the drain,and through the drain hose vacuum the water out of your washer. If you don't have a shop vac go to the auto parts store and buy a pair of radiator hose clamps . Then facing the washer locate the two screws. They will either be in the front or rear of the control panel and back them out far as you can. Once you have done that pull the control panel slightly forward, and tilt it back on the hinges. Now unplug the lid switch wire but don't forget to plug it back when your done. Next locate at the rear of the washer body the two gold clips then push forward, and take careful note of how they fit. Then pop them out with a screw driver tilt the washer body forward at 45 degree angel and walk forward with the body, and set it down. Now you will see the white pump and motor assembly. You should see two clips holding the pump to the motor pop them off, and pull the pump off the motor shaft. Now if you fell the need to remove the pump use the radiator hose clamp. take them and clamp the hose coming from the tub but its not necessary for the repair. Next disconnect the wiring harness from the motor (note the position of the harness for reassembly). Remove the two 5/16 inch screws from the motor clamps and pop the clamps off. Once that is complete, remove the motor put the new coupling on the motor and transmission shaft. I use a socket and a hammer
Posted on Jan 20, 2008
  • 3 Answers
SOURCE: Kenmore Elite Front Load - smell of burning rubber while in use
I've never had a smell problem like this before, but I have had the rubber lining to the door "shred", leaving eraser shavings all over the laundry. This happened with my first HE3t and I complained at SEARS and they just sent out a brand new replacement. About a month or two later, the same thing happened. I had SEARS come out and replace that rubber seal, and haven't had a problem since.
Although I can't answer on the smell, I highly suggest you keep an eye out for shavings on your laundry. Also, with the door open, at the bottom you can pull back the rubber seal slightly and expose the drain to be sure nothing is clogged or getting caught in there.
Posted on Oct 16, 2008
  • 112 Answers
SOURCE: Burning smell, loud when spinning, bleach spots
Usually this is due to the tripod mount on the back of the drum cracking. Simply replacing the bearings does not help in most instances. The only true remedy is to replace the drum, along with the front and rear tubs. These are usually covered under warranty but the labor (6-8 hours) is a customer pay unless the unit is very new. Also, it is recommended that you replace the drain pump as well when performing this repair. It is a good idea to get this looked at as soon as possible as more damage can incur. I have seen them vibrate so violently that they break the control boards above the drum. If you give whirlpool an earfull, they may or may not offer some help on the bill.
Posted on Oct 23, 2008
SOURCE: Front Loading LG Washing Machine leaves smelly sludge in wash tub
This machine has a tub clean feature that you're supposed to run with bleach. I did this and it helped the smell s bit. Recently we had an error code and the repair man that came to fix it gave me some good tips. His experience has been that the smell is from too much soap causing build up in the seal and along the tub. His suggestion was to cut back on the amount of he detergent (he said a tablespoon is sufficient). His company recommends using a product called Whirlout (you can buy it at Home Depot). It was originally meant to clean scum out of hot tub jets. Apparently if you call LG they will recommend this product, but haven't bothered to suggest it in the owner's manual. I was told to put one to two capfuls directly into the tub (not the detergent bay) and run the tub clean cycle. I used it last night and it worked - no more musty, yucky smell!
Posted on Jul 09, 2009
  • 5 Answers
SOURCE: Kenmore HE2 front load washer. All cycle lights flashing plus spin and clothes clean lights on.
I'm sure this is probably too late, but hopefully it will help some else. I just had the same problem. First, unplug the power. Then take the lower front panel off and grabbed a bucket. Place the bucket under the large "plug" on your right. This is the drain. Slowly unscrew the drain plug, Hold your nose as it will probably smell. Allow the water and such to drain into the bucket. When you see the blob of wet lint drop into the bucket you will know why the machine refused to work. Make sure you clean the drain plug and screw it back in tightly. Put the lower panel back on and reconnect the power. I hope this resolves your issue.
Posted on Oct 10, 2009
What to do when h1 is flashed in ifb automatic front load washing machine
Cannot find anything about H1, but error code E01 is door not closed properly. An instrument at work sometimes reads "h1" and this indicates a "high" reading, but don't know if that is really relevant here. Sorry I can't help any further. Good luck.
May 19, 2015 | IFB Washing Machines
Ifb wasjing machime show on display Un bl
take some of the clothes out and rearrange the rest retry Un BL means unbalanced load
Mar 22, 2015 | IFB Washing Machines
In IFB front washingmechain AC h1 error is coming what to do
AC h1 is actually AC hi error which means input voltage is too high. Wait for sometime for voltage to stabilize Washing machine will automatically start. If not call electrician to check electrical fault for high voltage
Jul 03, 2014 | Kenmore Elite 45986 Front Load Washer
IFB washing machine front load Showing ' Lo' what
Error code LO normally means the filter is blocked. this would be the best place to start. refer to your owners manual for instructions on cleaning this.
Aug 10, 2013 | IFB Washing Machines
Ac voltage become hihg or low when start ifb washing machine
We got a IFB front loading washing machine last week only after 3 time wash 4 th day it is showing AC-LOW message . the service people came and went but nothing is done what is the next solution?
Same point top loading Godrej 6.5 kgs working fine but water consumption is more in that compared to front loading machine so pls sugeest good solution at the earliest.
Sep 30, 2012 | IFB Washing Machines
Jamed in front loaded IFB washing machine tell the solution
Plz forward contact no. contact name, address. So we can contact with you. also you can visit our website www.ifbappliances.com for more details.
Regards,
IFB customer care
Jun 07, 2012 | IFB Washing Machines
There is a cockrach in the idicator of my IFB front load washing machine. How do i remove it?
this is always a problem with all electronic lcd when around little cockroaches an expert would take the panel off and clean as well as spray the unit from the inside but short of that he will event die and hopfully fall away from the lcd
Apr 20, 2010 | Indesit W 123 Front Load Washer
Washing Machines Logo
140 people viewed this question
Top IFB Washing Machines Experts
Raj Patel
ray gallant
Are you an IFB Washing Machine Expert? Answer questions, earn points and help others
