Question about Vacuums
Dont have very much suction
The thing was given to me i dont have a manual for it it dont have very good suction and the brush light came on i check everything out but nothing thank you
This is the manual on line
http://www.dirtdevil.com/CustomerService/Manuals/DirtDevilManual.aspx?ManID=325fa4dd-0a38-48aa-b0b0-516143a0875a
Posted on Jan 24, 2009
Problems with suction on floor of vac
Often times when people bring a vac in for repairs and say it has no suction at the floor it has good suction but not good agitation. Make sure the belts in the clutch are new (some people are selling used clutches with stretched out belts) and the brush roll is good. If the agitation from the brush roll is not good it will not pick up even light soils like hair and lint.
Oct 08, 2017 | Dyson DC14 Animal Bagless Upright Cyclonic...
Turbo tool used only once or twice, already brush moves so slowly it stops when I try to use. Brush can actually be stopped by hand. Manual says nothing at all about the brush ie. HOW to take apart to see...
It takes a lot of suction to spin the brush. First make sure the suction is good. Make sure the bag and/ or filters are clean. Replace if necessary. Most turbo tools can be opened up to clean. Most have a lever that allows you to open it up to clean hair, dust, etc from the fan and fan shaft and other areas inside the tool. The tools pick up a lot of hair and debris and some will wrap around the moving parts building pup to the point the brush will not spin fast enough. The same thing can happen to the brush roll on your vacuum so be sure to clean it too and replace the belt at least twice per year.
Oct 31, 2013 | Eureka Vacuums
Need Kirby Generation 3 Vacuum cleaner manual. Vacuum is not picking up dirt from floor. Seems to have enough suction to inflate the bag, but when you check the suction under the vacuum, there seems to...
If your brush roll is turning and your bag is not overly full, then the only other thing it can be is a clog where the bag connects to the vacuum. Turn the plastic part out away from vacuum and lift off to see if you have something clogging it. It would have to be something big, but not so big that it could not get past the fan. As a rule of thumb, KIRBY never clogs. I suspect that your belt is stretched out and your brush roll is not turning while on the carpet so the brush roll is just in the way rather than brushing your carpet to pick up dirt.
Jun 08, 2010 | Kirby Generation 3 Bagged Upright Vacuum
Great suction through handle, no clogs anywhere,
OK - there are two obvious things to check: 1. Make sure the brush is rotating. The DC14 has a 'brush control system" operated by a knob on the base in front of the right side wheel. Make sure this hasn't accidentally been moved to the "off" position. With it in the "on" position, switch the machine on, tilt the handle back and check that the brush roll is rotating. If it isn't, then there's a broken belt or a problem with the clutch mechanism in the brush control system. 2. If the brush is rotating, switch the machine off (and unplug it), turn it over and you will see a short length of clear plastic hose with spiral reinforcing that runs from the brush area to the motor. That hose often develops a split (which lets air in and reduces suction around the brush). Take that hose off (pull it off from the motor end and then unscrew it from the brush end) and inspect it carefully for any damage. If it is damaged, get a new one - don't try and repair the old one, it's not worth it.
I hope this helps - if so, please remember to rate my response. If you need more help, just post a reply here and I'll see what more I can do. Good luck!
Feb 10, 2010 | Dyson DC14 Full Access Bagless Upright...
The brushes and the belt are not rotating. The power seems fine and there is suction. I have no other history on this problem since I was given this almost new unit over Thanksgiving. Where should I be...
If you've got suction, but the brushes and belt are not rotating, then either the belt has come off the motor shaft, or the belt is broken and just looks OK.
Remove the bottom cover off the floor head and check that the brush roller turns freely. If it does, then check the belt.
Let me know if you need additional repair information.
Dec 16, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
The performance indicator light will not go out. I have cleaned the bag, filter and hose. there does not seem to be enough suction.
you are clogged somewhere ...
no suction?
performance indicator says no suction?
find and remove the clog.
id be looking in the hose about 4 inches from where the dirt enters the brush but dont limit your looking. The entire system should be checked for a clog. Remove it and you willbe back in business.
I have 'trash picked' more than 100 vacuums this summer, off the curb. 90 were clogged. I cleaned then and turned them into $.
Oct 13, 2009 | Vacuums
Suction is so light when using attachments will not pick up anyth
If there is no obstructions, its probably the motor has burnt out or shorted, causing loss of suction. Good luck.
Aug 28, 2009 | Dyson DC14 All floors Bagless Upright...
Brush spin,good suction at hose, no suction at
Air passage from back of brush head, through the joint, and up to bag, may be blocked.
Jul 11, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
No suction when carpet cleaning. Also won't stand upright
Its possible that it may be blocked in the foot of the vaccum. try going through your instruction manual to locate details on how to disassemble the suction brush and connecting ducts. If you dont have one then use this link to download it. http://ubermanuals.com/node/1870
Let me know how you got on
Cheers
Jun 10, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
