Question about HP DeskJet 932c InkJet Printer
How to reset hp laserjet 1105 - HP DeskJet 932c InkJet Printer
HP laserjet pro m401 dne does not print
you replace toner cartridge 80 a then ask questions
Feb 20, 2017 | HP LaserJet Pro 400 M401DN Laser Printer
How to reset roller kit warning on hp laserjet
Hi the HP Laserjet CM6040 how to reset the document feed roller go to administration then go to reset menu then in reset menu scroll down until you see the new document feed roller select either yes or no. Hope this helps
Jun 10, 2014 | Premier Hp - ROLLER KIT CLJ MFP CP6015...
How to cold reset in HP LaserJet 1536 dnf mfp
Resetting the HP LaserJet Pro M1536dnf accomplishes the following:
  • Clears all data from the printer's memory (including unprinted data, downloaded fonts, and macros).
  • Stops any printing that is taking place and ejects the page.
  • Removes some error conditions.
  • Resets the printer to its factory default settings.
Reset Procedure:
  • Turn off the printer
  • Press and hold the Left arrow & Cancel while you turn on the printer
  • Once you see Permanent Storage Init you can release the buttons.
  • The printer should now start resetting.
Thanks,
HP Printer Support
Jun 10, 2014 | HP LaserJet M4345 MultiFunction Printer
Error 1105
trailing cable should not be bent in some places which cause porbleme of comminucation with Carriage PCA
Feb 11, 2013 | PrintCountry Ink Cartridge for HP...
Reset password HP LaserJet Pro 400
Where is the go button on the hp laserjet M425dn? I have been trying to reset to default setting, student put a password on the printer.
Dec 05, 2012 | HP Laserjet Pro 400 Mfp M425dn...
HP laserjet 4600dn printer. Replaced the HP C9724a transferkit, but the message "new transferkit" does not appear. How to simulate putting it to zero. Erik 22-06-2010
The printer counter needs to be reset by going into menu and finding resets. Then toggle down until you come across Transfer Kit & press ok.
Jun 22, 2010 | HP LaserJet 4600dn Color Printer
LaserJet M4345 MFP Printer: how to cold reset in HP LaserJet M4345 MFP...
walid_sayed@hotmail.com
To perform a cold reset
1 Turn the MFP off and then on.
2 When the memory count appears on the control-panel display, press and hold 6 until all three
LEDs flash once and then stay on. This might take up to 20 seconds.
3 Press 3 four times until COLD RESET appears on the control-panel display.
4 Press 6 one time. The MFP continues its initialization sequence.
May 07, 2010 | HP LaserJet M4345 MultiFunction Printer
Replacing Print Cartridge
Turns out there was an easy solution. I filed a support case and had an answer in half a day:
"Often this issue is caused by a sensor. â Therefore the first thing we should do is try to trigger the sensor.
1 Turn off the HP LaserJet 3050
2 Remove the toner cartridge from the HP LaserJet 3050
3 Remove all of the paper in the paper tray
4 Check the entire paper path for any obstructions
5 Reseat the toner cartridge and paper
6 Power on the HP LaserJet 3050
If the issue is still not resolved we will need to try some resets on the HP LaserJet 3050.
1. The first reset we can try is a soft reset, it is done by pressing the MENU key then holding *# together. â This will bring you into a Developers Menu. â Scroll through the options until you find reinit FFS and then press the ENTER key.
2. If this reset doesn't clear the issue we can try a harder reset. â We can do this by pressing MENU, scrolling over to SERVICE, pressing ENTER, scrolling over to RESTORE DEFAULTS and pressing ENTER to restore the defaults and ENTER to confirm.
WARNING: Restoring the defaults will clear your fax settings, phonebook numbers and headers so you may want to print a phonebook report and Config Report first. â We can do this by accessing the Reports menu.
3. If these two resets do not help there is a third reset we can try.This reset will completely put the HP LaserJet 3050 back to factory defaults.WARNING: Before doing this reset we will need to disconnect the power cord, the phone cable, and the USB cable from the back of the HP LaserJet 3050.We can do this reset by unplugging the power cord from the back of the HP LaserJet 3050 then holding down the MENU/ENTER key and * symbol at the same time,then powering the HP LaserJet 3050 back on with the keys compressed.We will release the keys as soon as PERMANENT STORAGE INIT appears on the display screen."
I tried all the steps in sequence; it took #3 to fix it. Fortunately I didn't have a big fax address book or custom settings, so a factory defaults reset didn't cause any extra problems. It retained the time and date, and now it works fine.
Mar 12, 2008 | HP LaserJet 3050 All-In-One Printer
HP DeskJet 932c InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
