Question about Cell Phones
How do i hard reset xdv files in htc one
Blank screen appears after switching on handset. soft keys and ******** work,
  • Paul Paluch Jan 14, 2013
    Screen is blank so I can not enter any codes
    Master:
  • Cell Phones Master
  • 520 Answers
Hello:::
It may happen that despite you have restored your mobile to factory setting, the error still exist. In this case, it is recommended that you opt for Hard reset
•Enter the code: *#7370# and press Yes to confirm initialization.
•Important Notice: It is recommended that you save all important information on your phone (e.g: memo, contacts etc)
•To make a Hard Reset on a Nokia phone that is not willing to turn on, just press simultaneously these 3 buttons:
•on/off + * + 3
•Before making a Hard reset better backup all your important information: contacts , memo...etc
Posted on Jan 14, 2013
4 Suggested Answers
  • 56 Answers
SOURCE: HTC Hero ringer/speakerphone doesnt work
check settings... check buzzer device... check contact of buzzer device to buzzer interface...
Posted on May 25, 2010
diodeic
  • 1622 Answers
SOURCE: I bought htc touch 2 T3320. mobile 7 month before.
The reason your phones touch screen is not working is simply because there is a problem with the flexi of the phone.
If the screen is not damaged in any way, then the assumption of it being the screen is absolutely correct.
To fix the flexi of the phone;
1. Get the appropriate screwdriver,
2. remove the battery, the battery cover, and your sim,
3. Turn the back of the phone,
4. you will see five rubbers,
5. pick them off with a pincher,you will see screws under them, unscrew the phone,
6. Get a credit card and slip it through the line around the phone then apply a little force in separating them apart,
7. you will see the panel of the phone, carefully lift it up,
8. you will see a flexi that runs through the screen to the panel, carefully detach the flexi from the panel,
9. unscrew the screen of the phone, remove the flexi connected to the screen also and replace it.
10. Reverse the process to reassemble the phone.
I hope this will help in solving the problem.....
Posted on Nov 25, 2010
SOURCE: How to soft reset or
hello i have htc smart f3188 how to reset soft
plz tell me thnx
Posted on Mar 26, 2011
E4 - Erros My uniden phone model TRU 9485 - 4WX after outage power, now on LCD screen appear E4 and it didn't respond to any button when i press. I read some help which they say press 3 button...
Hello
Connect the phone line and power UP the base unit. Place the handset on base to get charged. It must reset automatically when you place the handset on base to charge. If not; resetting both handset and base unit is necessary.
Resetting the Handset
You may need to reset your handset in the following instances:
You lose a handset and purchase a new one. When you try and register to your existing base you get registration
failure.
You are unable to register any handsets to the base.
You had a base which needed to be exchanged by the manufacturer. When you register your existing handsets
to the base, the handsets say #3 and #4, but you only have 2 handsets.
When you are instructed to by the one of the manufacturer's call center representatives.
To reset, do the following:
Press and hold [ ] and [#] for more than 5 seconds. Select DEREGISTER HS.
WHICH HANDSET? appears. Select the handset that you want to de-register, and press the OK soft key.
DEREGISTER HS appears. Select YES, and press the OK soft key.
ARE YOU SURE? appears. Select YES, and press the OK soft key. You will hear a confirmation tone. The
handset will clear its registration information from the base, and then delete its own base information.
MODELS VARY! PLACE HANDSET ON THE BASE FOR REGISTRATION OR REFER TO OWNER'S MANUAL. To
re-register the handset to the base (see page 25).
If the handset cannot contact the base, it will display OUT OF RANGE. Make sure the handset is in range of the
base and the base is connected to power.
Note: It is also possible to reset the handset back to its original factory settings. All changes including Caller ID information
will be erased. For more information on resetting the handset back to factory settings and when you need to
do this, see www.uniden.com or call our Customer Service Hotline. See back cover page for contact information.
Resetting the Handset without the Base
If your original base is not available for some reason (for example, it is lost or somehow incapacitated), you can still
reset the handset and use it with another base.
Move the cursor to select BASE UNAVAILABLE and then press the OK soft key.
BASE UNAVAILABLE appears.
Move the cursor to select YES, and then press the OK soft key. ARE YOU SURE?
appears.
Move the cursor to select YES, and then press the OK soft key. You will hear a confirmation tone. The handset
will delete its own base information without trying to contact the base. When the base information is deleted,
the handset displays MODELS VARY! PLACE HANDSET ON THE BASE FOR REGISTRATION OR REFER
TO OWNER'S MANUAL. Register the handset to the new base (see page 25). of its user manaul.
OK.
Sep 12, 2011 | Uniden TRU9485 Cordless Phone
My HTC Desire HD has just frozen. The screen is now black and no buttons work. When I connect it to the battery to the mains I get the coloured welcome screen for a few sceconds but then it goes black...
Please reset the mobile ,
Resetting Your Device Soft reset Occasionally, you may need to reset your device. A soft(or normal) reset of your device clears all active program memory and shuts downall active programs. This can be useful when your device is running slower thannormal, or a program is not performing properly. A soft reset is also necessary afterthe installation of some programs. If a soft reset is performed when programs arerunning, unsaved work will be lost. To perform a soft reset 1. Remove theback cover. 2. Use the stylustip to press the RESET button located between the SIM card and the storage card slots. Your device restarts and displays the Home screen. Hard reset You can also perform a hard reset (also known as a fullreset). A hard reset should only be performed if a normal reset does not solve asystem problem. After a hard reset, the device is restored to its defaultsettings-the way it was when you first purchased it and turned it on. Any programs youinstalled, data you entered, and settings you customized on your device will be lost.Only Windows Mobile® software and other pre-installed programs will remain. Warning! Your device will be set back to factory default settings. Make sure thatany additional installed programs and/or user data have beenbacked up before you perform a hard reset. Managing Your Device Important IfEncrypt files when placed on a storage card is enabled, backup all files from the storage card before using Clear Storage, hard reset,or updating the ROM system software. Otherwise you will no longer be able toaccess the encrypted files on the storage card. Use ActiveSync or WindowsMobileDeviceCenter to transfer files between your storage card and computer. After theprocedure, copy your files back to the storage card. To perform a hard reset 1. With thedevice turned off, press and hold the VOLUME UP and VOLUME DOWN buttons, then briefly press the POWER button. 2. Continuepressing the VOLUME UP and VOLUME DOWN buttons until you see this message on the screen: This operation will delete all your personal data, and reset all settings to the manufacturer default settings. Press VolUp to restore manufacturer defaults, or press other keys to cancel. 3. Release theVOLUME UP and VOLUME DOWN buttons. 4. Press theVOLUME UP button to perform the hard reset, or press any other button to cancel the reset.
Hope this helps.
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
Thanks for using fixya .
Jan 26, 2011 | HTC Touch HD Smartphone
I fogot my password...how do i unlock my phone...i
I hope you have your contacts backed up because there is no way to unlock it without performing a Hard Reset. First hold down both soft keys and the soft reset hole at the bottom by the memory card slot simultaneously. The soft keys are the 2 dots to the left and right of the D-pad. If you do it correctly, on-screen prompts will appear on a white screen, just follow it from there!
Feb 18, 2010 | HTC PPC-6800 Smartphone
Htc p3400i hw to format window & reinstall it
Try a Hard Reset
Note: this will delete all data, so mack sure you have backedup anything you need to keep (ie addressbook, personal files)
Press and hold the left SOFT KEY and the right SOFT KEY, and at the same
time, use the stylus to press the RESET button at the middle left side of your device.
Release the stylus, but continue pressing the two SOFT KEYs until you see the following message on the screen:
all settings to manufacturer default. Press Send to restore
manufacturer default, or press other keys to cancel.
Now Release the two SOFT KEYs, and then press the TALK (Send) button
(Info from: http://www.efsoft.it/resetdev.htm)
Nov 19, 2009 | HTC Touch P3450 Smartphone
Stuck on windows boot up screen
Regarding with your HTC Viva / Elf
Try hard reset with phone in "OFF" state following this instructions if it will do;
1. Press and hold the TALK and END buttons, and at the same time, use the stylus to press the RESET button under the battery cover at the top
of the device.
2. Release the stylus, but continue pressing the TALK and END buttons until you see this message on the screen:
Warning! Your device will be set back to factory default settings. Please ensure any additional installed programs and/or user data have
been backed up before a hard reset is performed.
3. Release the TALK and END buttons, and then press ENTER on your device.
Mar 03, 2009 | HTC Touch P3450 Smartphone
HTC screen will not show
Have you tried just pulling the battery out for a few seconds, and replacing it. Letting it reboot and start again. You do wanna do this at least three-four times a week.
If the powercycle doesn't do thte trick, you'll wanna do the hard/master reset. As per www.htcwiki.com
Hard/Master Reset for a HTC Pocket PC: Warning: Performing a Hard/Master Reset will remove all of your data (settings, files, 3rd party applciations, etc.) from your device and will only reload the Windows Mobile Software and components. The method for Hard Resetting/performing a Master Reset on HTC devices can vary by model. Below are the instructions for the most common method. If these steps do not work for you, consult your user manual or contact your wireless carrier for additional assistance.
  • With the device powered on, press and hold the Left and Right Soft Keys.
  • Whilst holding the Left and Right Soft Keys, perfrom a Soft Reset on the device by inserting the stylus into the reset hole.
Feb 03, 2009 | HTC PPC-6800 Smartphone
Hard reset
Occasionally, you may need to reset your device. A normal (or soft) reset of your device clears all active program memory and shuts down all active programs. This can be useful when your device is running slower than normal, or a program is not performing properly. A soft reset is also necessary after the installation of some programs. If a soft reset is performed when programs are running, unsaved work will be lost.
You can also perform a hard reset (also known as a full reset). A hard reset should be performed only if a normal reset does not solve a system problem. After a hard reset, the device is restored to its default settings — the way it was when you first purchased it and turned it on. Any programs you installed, data you entered, and settings you customized on your device will be lost. Only Windows Mobile software and other pre-installed programs will remain.
Use the stylus to press the RESET button found on the lower left side of your device. Your device restarts and displays the Today screen.
  1. Press and hold the Left SOFT KEY and the Right SOFT KEY, and at the same time, use the stylus to press the RESET button at the lower left side of your device.
  2. Release the stylus, but continue pressing the two soft key buttons. Release them only when you see the following message on your device screen: “Press Send to restore manufacturer default, or press other keys to cancel.“
  3. Press on your device. Warning! Your device will be set back to factory default settings. Please ensure any additional installed programs and/or user data have been backed up before a hard reset is performed.
Oct 29, 2008 | HTC P3300 Smartphone
Imate jasjam have problem
I think the files you installed were not compatiable with your cell or were corrupt try a hard reset here is the procedure;
Hard reset: Press and hold the Left SOFT KEY and Right SOFT KEY, and at the same time, use the stylus to press the RESET button at the bottom of your device. You will be presented with a menu saying 'press R to reset, X to exit', if you press R Your device will be set back to factory default settings.
(The L/R soft keys are the "- -" keys just above the start and OK buttons)
Aug 31, 2008 | HP iPAQ H1940 Pocket PC
Touch screen & key board with stick does not respond
try aligning the screen...
settings > screen > general > Align Screen
If that doesn't work try hard reset... i.e.
press the two soft keys and the reset button using stylus...
If its still not working do soft reset:
settings > system > Clear storage
but remember to take back up of phone before doing this..as it will erase all your data...
and do tell me if it worked or not...
Jun 25, 2008 | HTC P3300 Smartphone
Out of range shows on main handset of cordless phone
Unplug the battery. Hold down The * (star) and the #(hash) keys simultaneously. Re-connect the battery, phone will beep and screen will be blank. Press the voicemail (righthand silver key under the lcd screen). As above EEPROM/RAM message will appear. Place handset on base and your problem is solved.
Jan 13, 2008 | Uniden 5.8GHz Cordless Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
